Update my controller to MySensors 2.0
Updated my controller to MySensors 2.0.
I switched to a serial gateway (no code changes needed, only added serial input and output to the flow), as handling one tcp channel is not as reliable, as I need it.
Found some bugs, nobody reported.... (wrong IDs of V_ and S_) :smile:
I really would like to post the code but....
Please enter a shorter post. Posts can't be longer than 32767 character(s).If someone is interested, I will find a solution to post the code.
It is my :smile: controller, not the module from tbowmo:
https://forum.mysensors.org/topic/700/node-red-as-controller/28
The code that is here:"https://github.com/tbowmo/node-red-contrib-mysensors" as a problem with latest mysensors with arduino 1.6.13 and NodeRed v0.15.02.
These line:
pl = msg.nodeId + ";" + msg.childSensorId + ";" + msg.messageType + ";" + msg.ack + ";" + msg.subType + ";" + msg.payload;Should be:
pl = msg.nodeId + ";" + msg.childSensorId + ";" + msg.messageType + ";" + msg.ack + ";" + msg.subType + ";" + msg.payload + "\n";This way the message gets to the node, the first one doesn't get there.
Thanks,
Rui.
