  3. Node-RED
  4. Update my controller to MySensors 2.0
Scheduled Pinned Locked Moved Node-RED
5 Posts 4 Posters 3.0k Views 3 Watching
  • FotoFieberF
    FotoFieberF
    FotoFieber
    Updated my controller to MySensors 2.0.
    I switched to a serial gateway (no code changes needed, only added serial input and output to the flow), as handling one tcp channel is not as reliable, as I need it.
    Found some bugs, nobody reported.... (wrong IDs of V_ and S_) :smile:
    I really would like to post the code but....
    Please enter a shorter post. Posts can't be longer than 32767 character(s).
    If someone is interested, I will find a solution to post the code.
      If you find a bug in the nodered module, you should create a pull request to @tbowmo repository found here:
      https://github.com/tbowmo/node-red-contrib-mysensors
      • tbowmoT
        tbowmoT
        tbowmo
        @FotoFieber
        Just published a new module version, with the latest message ids added in mysensors 2.0.1 (dev branch)
        • FotoFieberF
          FotoFieberF
          FotoFieber
          It is my :smile: controller, not the module from tbowmo:
          https://forum.mysensors.org/topic/700/node-red-as-controller/28
          • rcaridadeR
            rcaridadeR
            rcaridade
            The code that is here:"https://github.com/tbowmo/node-red-contrib-mysensors" as a problem with latest mysensors with arduino 1.6.13 and NodeRed v0.15.02.
            These line:
            pl = msg.nodeId + ";" + msg.childSensorId + ";" + msg.messageType + ";" + msg.ack + ";" + msg.subType + ";" + msg.payload;
            Should be:
            pl = msg.nodeId + ";" + msg.childSensorId + ";" + msg.messageType + ";" + msg.ack + ";" + msg.subType + ";" + msg.payload + "\n";
            This way the message gets to the node, the first one doesn't get there.
            Rui.
