  3. Domoticz
  4. Mysensors Ethernet GW w5100 problem
45 Posts 7 Posters 13.5k Views 7 Watching
  • mrc-coreM
    mrc-coreM
    mrc-core
    This is my GW with the mini ENC28J60 runing.
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 10.8.1.201
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;Eth: 0;0;3;0;2;
    0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
    0;255;3;0;9;Eth: 0;0;3;0;18;PING
    0;255;3;0;9;TSP:MSG:READ 5-5-0 s=9,c=1,t=14,pt=2,l=2,sg=0:55
    • tlpeterT
      tlpeterT
      tlpeter
      wrote on last edited by tlpeter
      #42
      In your previous example you use pin 14,15 and 16 next to 5 and 6.
      This is what the example on the site says:
      Arduino NRF24L01 Radio Ethernet module
      GND GND GND
      3.3V VCC VCC
      13 SCK SCK
      12 MISO MISO/SO
      11 MOSI MOSI/SI
      10 SS/CS
      6 CSN
      5 CE
      Use the pinout on the gateway example page.
      mrc-coreM 1 Reply Last reply
      • tlpeterT tlpeter
        GND GND GND
        3.3V VCC VCC
        13 SCK SCK
        12 MISO MISO/SO
        11 MOSI MOSI/SI
        10 SS/CS
        6 CSN
        5 CE
        mrc-coreM
        mrc-coreM
        mrc-core
        @tlpeter
        Ok it's fix i cant ping the gw ip but domoticz can see the new arduino gw.
        Now at the gw i'm getting this message:
        0;255;3;0;9;TSP:MSG:READ 192-1-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
        0;255;3;0;9;!TSP:MSG:PVER mismatch
        I don't undestand this mismatch
        tlpeterT 1 Reply Last reply
        • mrc-coreM
          mrc-coreM
          mrc-core
          Has i can see this GW is not to stable...
          here's my log over domoticz:
          2016-08-18 14:48:17.667 MySensors: connected to: 10.8.1.201:5003
          2016-08-18 14:48:18.669 MySensors: Node: 0, Sketch Name: Ethernet GW
          2016-08-18 14:48:18.671 MySensors: Node: 0, Sketch Version: 1,0
          2016-08-18 14:53:23.808 MySensors: Connection reset!
          2016-08-18 14:53:23.808 TCP: Reconnecting in 30 seconds...
          2016-08-18 14:53:53.814 TCP: Reconnecting...
          2016-08-18 14:53:54.816 MySensors: connected to: 10.8.1.201:5003
          2016-08-18 14:53:55.818 MySensors: Node: 0, Sketch Name: Ethernet GW
          2016-08-18 14:53:55.820 MySensors: Node: 0, Sketch Version: 1,0
          2016-08-18 14:54:36.836 MySensors: Node: 3, Sketch Name: TemperatureAndHumidity
          2016-08-18 14:54:36.839 MySensors: Node: 3, Sketch Version: 1.1
          Reconnecting isues ???
          • mrc-coreM mrc-core
            @tlpeter
            tlpeterT
            tlpeterT
            tlpeter
            @mrc-core said:
            @tlpeter
            I think VER is for version and maybe (a wild guess) the P for protocol???
            Which version Domoticz are you running? try the latest beta.
            Is/are your gateway(s) upgraded too?
