  3. Domoticz
  4. Mysensors Ethernet GW w5100 problem
45 Posts 7 Posters 13.1k Views 7 Watching
  • mrc-coreM
    mrc-coreM
    mrc-core
    Hi. I'm having a problem since i have upgrade to mysensors 2.0.0
    The problem it's this:
    2016-08-16 21:27:41.811 MySensors: connected to: 10.8.1.201:5003
    2016-08-16 21:27:42.811 MySensors: Connection reset!
    2016-08-16 21:27:42.811 TCP: Reconnecting in 30 seconds...
    2016-08-16 21:28:12.814 TCP: Reconnecting...
    2016-08-16 21:28:13.814 MySensors: connected to: 10.8.1.201:5003
    2016-08-16 21:28:17.815 MySensors: Connection reset!
    2016-08-16 21:28:17.815 TCP: Reconnecting in 30 seconds...
    And i can't pass from here don't now what to do.
    Can anyone give me a help on this?
    • tlpeterT
      tlpeterT
      tlpeter
      I have had that with a serial gateway where is used a radio with external antenna.
      After switching to a normal radio the problems where gone.
      I had it connected to a RPI3 and it seemed to be a power issue as it was working fine connected to my laptop.
      • mrc-coreM
        mrc-coreM
        mrc-core
        Hi.
        have change the switch the external radio antena for a normal radio but problem still continuos....
        I had domoticz runing on a RPI3 and just for debuging change it for a RPI2 but the problem still persists...
        I don't understand this error.
        With the mysensors 1.5 i had all runing OK on RPI3 with the same ethernet gateway.
        Other problem i'm having also no it's flashing the code into the arduinos all OK on the code but when i'm flashing it into the arduino gives a error at the end... and all this start hapening on this version 2.0.0.
          A Former User
          I has the same issue with my Ethernet gateway.
          Which version of the arduino idea are you using?
          I found that both 1.6.9 and 1.6.10 would cause this issue. Uploading the code with 1.6.8 works perfectly.
          • mrc-coreM
            mrc-coreM
            mrc-core
            arduino with mysensorv version 1.5.4 was the last one i had used and all was working OK.
            now i'm truing to use the mysensors 2.0.0 but hav this strange problem.
            I don't want to go back to version 1.5.4 and stay on the new version 2.0.0 but i want to still have the ethernet gateway because my gateway is located outside my house for better received all my sensors outside.
            Is there any fix for this problem? is this a bug?
              A Former User
              There seems to be a problem with mysensors 2.0 and the arduino IDE version 1.6.9 and1.6.10.
              On the arduino website you can download old versions of the IDE. Try version 1.6.8.
              • mrc-coreM
                mrc-coreM
                mrc-core
                Ok. problem with the arduino IDE fix, i can upload the code without errors thanks Jason37.
                But i still have the problem with the ethernet gateway no connecting to domoticz, same error, reconnecting.....
                • tlpeterT
                  tlpeterT
                  tlpeter
                  Can you show the sketch?
                  I succesfully connected a ENC28J60 gateway and connected fine.
                  mrc-coreM 2 Replies Last reply
                  • tlpeterT tlpeter
                    mrc-coreM
                    mrc-coreM
                    mrc-core
                    wrote on last edited by mrc-core
                    @tlpeter
                    I'm using the sketch that can be found on the test folder from the library 2.0.0
                    #define MY_GATEWAY_W5100
                    //#define MY_W5100_SPI_EN 4
                    // radio on the same spi bus.
                      #define MY_SOFTSPI
                    #ifndef MY_RF24_CE_PIN
                      #define MY_RF24_CE_PIN 5
                    #ifndef MY_RF24_CS_PIN
                      #define MY_RF24_CS_PIN 6
                    // Enable to UDP
                    //#define MY_USE_UDP
                    #define MY_IP_ADDRESS 10,8,1,201   // If this is disabled, DHCP is used to retrieve address
                    #define MY_PORT 5003
                    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
                    // Flash leds on rx/tx/err
                    #define MY_LEDS_BLINKING_FEATURE
                    // Set blinking period
                    // Enable inclusion mode
                    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                    //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                    #if defined(MY_USE_UDP)
                      #include <EthernetUdp.h>
                    #include <Ethernet.h>
                    2016-08-18 11:45:08.681 MySensors: Can not connect to: 10.8.1.201:5003
                    2016-08-18 11:45:08.681 TCP: Connection problem (Unable to connect to specified IP/Port)
                    2016-08-18 11:45:08.681 TCP: Reconnecting in 30 seconds...
                    2016-08-18 11:45:38.687 TCP: Reconnecting...
                    AnticimexA 1 Reply Last reply
                    • tlpeterT
                      tlpeterT
                      tlpeter
                      Can you ping it?
                      • mrc-coreM
                        mrc-coreM
                        mrc-core
                        Yes i can, but i can see some lag on the ping today, on the last 2 days this was not happening....
                        Pinging 10.8.1.201 with 32 bytes of data:
                        Request timed out.
                        Reply from 10.8.1.201: bytes=32 time<1ms TTL=128
                        Request timed out.
                        Reply from 10.8.1.201: bytes=32 time=1ms TTL=128
                        Request timed out.
                        Request timed out.
                        Request timed out.
                        • mrc-coreM
                          mrc-coreM
                          mrc-core
                          Funny now the ping does not have any lag since i hade done a reeboot to the gateway
                          • tlpeterT
                            tlpeterT
                            tlpeter
                            Can you still ping when it is disconnected? (IP conflict)
                            Maybe power related?
                            mrc-coreM 1 Reply Last reply
                            • mrc-coreM mrc-core
                              @tlpeter
                                #define MY_SOFTSPI
                              // Enable to UDP
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @mrc-core The sketches under the test folder in the mysensors git (the library) is intended for CI evaluations. They are not examples to be used on target.
                              • tlpeterT tlpeter
                                mrc-coreM
                                mrc-coreM
                                mrc-core
                                @tlpeter Have tryed no ip conflit thats ok
                                arduino ide debug i get this
                                0;255;3;0;9;TSP:MSG:READ 5-5-0 s=9,c=1,t=14,pt=2,l=2,sg=0:55
                                0;255;3;0;9;TSM:INIT
                                0;255;3;0;9;TSM:RADIO:OK
                                0;255;3;0;9;TSM:GW MODE
                                0;255;3;0;9;TSM:READY
                                IP: 10.8.1.201
                                • AnticimexA Anticimex
                                  mrc-coreM
                                  mrc-coreM
                                  mrc-core
                                  @Anticimex so i have to get my old code and remake it with the code from sensors 2.0.0
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @mrc-core Examples have moved to a different repo: https://github.com/mysensors/MySensorsArduinoExamples
                                      mrc-coreM
                                      mrc-coreM
                                      mrc-core
                                      @Anticimex Thanks going to see yhe examples and tried to fix this problem.
                                      • mrc-coreM
                                        mrc-coreM
                                        mrc-core
                                        I'm getting this error on IDE
                                        :\Users\marco\Documents\Arduino\libraries\MySensors/MySensors.h:233:5: error: #error UDP mode is not available for ENC28J60
                                        YveauxY mfalkviddM 2 Replies Last reply
                                          YveauxY
                                          YveauxY
                                          @mrc-core I think the error is quite clear : you enabled UDP which is not supported in combination with ENC
