  3. A beginners question
11 Posts 5 Posters 3.7k Views 4 Watching
  • HilltanH
    HilltanH
    Hilltan
    wrote on last edited by TheoL
    I have put a DHT22 sensor to my serial gateway, and in the sketch code for the DHT22 sensor there is sleeping “code”, static const uint64_t UPDATE_INTERVAL = 60000; and on the end sleep(UPDATE_INTERVAL); . Will this affect the gateway forcing it to sleep or will this only affect the DHT sensor? My sketch:
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #include <DHT.h>
    //DHT Begin
    #define DHT_DATA_PIN 8
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 10
    #define CHILD_ID_TEMP 11
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("Getway+DHT", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      metric = getConfig().isMetric;
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
    TheoLT 1 Reply Last reply
    • HilltanH Hilltan
      #include <DHT.h>
      //DHT Begin
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      TheoLT
      TheoLT
      TheoL
      @Hilltan If you use sleep, an Arduino will go to sleep and is not able to receive any message. By using this
      Your gateway will go to sleep and will not receive messages from other nodes. Which is kind of the main task of a gateway.
      It should be
      wait( UPDATE_INTERVAL );
      Basic rule is. Use sleep only on battery powered nodes that don't have any incoming message. Use wait in all other circumstances.
      ps. I put your sketch between 4 `
      • HilltanH
        HilltanH
        Hilltan
        Thanks for a replay. I change sleep to wait then. What I was concerned about was to “read” to often from the DHT sensor. But I believe "static const uint64_t UPDATE_INTERVAL = 60000; " in the beginning will regulate this, so my gateway will not over read the DHT sensor?
        • HilltanH Hilltan
          @Hilltan the wait call will not return until the specified number of milliseconds has passed. So yes it will prevent from reading the dht too often.
          • meanmrgreenM
            meanmrgreenM
            meanmrgreen
            About to built a dht / pir / repeater.
            Since i cant Sleep it do i need to change all sleep with wait?
            In the dht example there is a Sleep to let the sensor settle before Reading. Should this be a wait instead then?
            • meanmrgreenM meanmrgreen
              @meanmrgreen yes
              meanmrgreenM 1 Reply Last reply
                @meanmrgreen yes
                meanmrgreenM
                meanmrgreenM
                meanmrgreen
                @mfalkvidd
                Hmm i have a combined sketch of the pir and dht example that works fine on a node that Can Sleep for a bit and interrupt with change on the pir.
                But if i take that sketch and change the Sleep with interrupt to a wait(sleep_time) the pir is not registrering movement between wait Times'.
                FIf i remove the wait alltoghter the pir is reporting the status every ms instead with the result that the dht can't read the temp!
                  @mfalkvidd
                  @meanmrgreen could you post your sketch?
                  • meanmrgreenM
                    meanmrgreenM
                    meanmrgreen
                    this is it.
                    https://create.arduino.cc/editor/meanmrgreen/e7e0219e-139a-4e89-88da-e02f0864e9c6/preview
                    not sure of link worksge. on phone atm. will paste it from comp later if its not working.
                    • meanmrgreenM
                      meanmrgreenM
                      meanmrgreen
                       * Version 1.0 - Henrik Ekblad
                       * Motion Sensor example using HC-SR501
                       * http://www.mysensors.org/build/motion
                      //Enable Repeater
                      #define MY_REPEATER_FEATURE
                      // Enable debug prints
                      #include <DHT.h>
                      #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                      #define DHT_DATA_PIN 4
                      #define CHILD_ID_MOT 1   // Id of the sensor child
                      #define CHILD_ID_HUM 0
                      #define CHILD_ID_TEMP 2
                      static const uint64_t UPDATE_INTERVAL = 120000;
                      float lastTemp;
                      float lastHum;
                      bool metric = true;
                      // Initialize motion message
                      MyMessage msg(CHILD_ID_MOT, V_TRIPPED);
                      DHT dht;
                      void presentation()  {
                        sendSketchInfo("PIR_DHT_REPEATER", "1.0");
                        present(CHILD_ID_MOT, S_MOTION);
                        wait(dht.getMinimumSamplingPeriod());
                        // Read digital motion value
                        Serial.println(tripped);
                        send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                        // Force reading sensor, so it works also after wait()
                          if (!metric) {
                          nNoUpdatesTemp = 0;
                          #ifdef MY_DEBUG
                        } else {
                          nNoUpdatesTemp++;
                          lastHum = humidity;
                          nNoUpdatesHum = 0;
                          #ifdef MY_DEBUG
                        } else {
                          nNoUpdatesHum++;
                        // wait until interrupt comes in on motion sensor. Send update every two minute.
                        wait(SLEEP_TIME);
                      m26872M 1 Reply Last reply
                        //Enable Repeater
                        #include <DHT.h>
                        float lastTemp;
                        float lastHum;
                        bool metric = true;
                        DHT dht;
                            if (!metric) {
                            nNoUpdatesTemp = 0;
                            #ifdef MY_DEBUG
                          } else {
                            nNoUpdatesTemp++;
                            lastHum = humidity;
                            nNoUpdatesHum = 0;
                            #ifdef MY_DEBUG
                          } else {
                            nNoUpdatesHum++;
                          wait(SLEEP_TIME);
                        m26872M
                        m26872M
                        m26872
                        @meanmrgreen You should use non-blocking code with millis() and if{}. Look e.g. at
                        https://forum.mysensors.org/topic/461/motion-sensor
                        https://forum.mysensors.org/topic/2717/repeater-node-with-sensor/12
