  3. Problem with RFM69 on homemade board
15 Posts 5 Posters 6.5k Views 4 Watching
  • voximdoV
    voximdoV
    voximdo
    Hello there,
    I recently build PCB board for mysensor node with Atmega328P. Microcontroller is working great with no problem. But there is no connection to RFM module. I have tried to debugg in on my own and get to this that is stucking on this line:
    do writeReg(REG_SYNCVALUE1, 0xaa); while (readReg(REG_SYNCVALUE1) != 0xaa)
    And nothing happens next. No serial communication, nothing. What can be the problem? I checked connections between the micro and RFM69 and everything seems okay.
    It's connected of course through level converter to get 3.3V (but I have to say that accidentaly I connected if for 1-2 minutes to 5V pins - But I don't know - it could cause my rfm module break?).
    Thank your for help. I am fighting with that for last 3 days :(
    TheoLT 1 Reply Last reply
    • voximdoV voximdo
      Hello there,
      TheoLT
      TheoLT
      TheoL
      @voximdo I;m not sure how well the RFM69 handles the 5V. I do know that the NRF doesn't like that, I fried one of those one time ;-).
      I know it doesn't sound tempting. But replacing the RFM with a new one might be the best solution. Unless someone else can help you with this.
      • voximdoV
        voximdoV
        voximdo
        I got myself a new one RFM69 and unfortunately it haven't changed anything. Still the same problem. Any other ideas? :/
        • carlierdC
          carlierdC
          carlierd
          What is the source of the 3,3 ? I got some issues with poor voltage converter. Using an arduino uno board which provides 5 and 3,3V solved my problem.
          David.
          • voximdoV
            voximdoV
            voximdo
            For now I am using Arduino Board as a supply for 5V and 3.3V. I tried also voltage converter. And no effect.
            • voximdoV
              voximdoV
              voximdo
              This 1K omh resistors on SPI line could cause problem or they shouldn't?
              • scalzS
                scalzS
                wrote on last edited by scalz
                @voximdo
                you don't give enough details...
                • your board: what looks like your level converter? on your schematic we don't see it. Is it your 1K res ??? if so, that's not a level converter! and you can't use a voltage regulator for this. you need to use mosfets.
                • which arduino board are you using for your tests? if uno/nano, atmel is powered through 5v, so dataline would be all 5v. The 16mhz crystal is a good indicator when you're not sure ;)
                I always try to power my circuit with 3v if rfm69. and if 5v, there are booster or charge pump.. Like this, it's easier to handle because there are much more things working at 3v than 5v, and then if you need level converter for each, pain begins.
                but in case, about level converter : https://www.sparkfun.com/products/12009
                • voximdoV
                  voximdoV
                  voximdo
                  I don't have level converter on my board, I forget about it, so I connected it outside the board. So MOSI, MISO, SCK and NSS goes to level converter and then to Atmega328p which is powered with 5V. Exactly that one from your link.
                  I am using Arduino UNO board for testing. I am powering circuit with 5V because I don't have any programmer (only Arduino board). So RX/TX for communication and programming have also 5V.
                  YveauxY 1 Reply Last reply
                  • voximdoV voximdo
                    YveauxY
                    YveauxY
                    @voximdo is there any pull up on ss line? If not, and you have more devices connected to spi interface, that might cause issues during startup if not all ss lines are set to high state before initialization starts.
                    • voximdoV
                      voximdoV
                      voximdo
                      I didn't have pullup, but I don't have any more SPI decives also. But still - I added it as you sugested and still the same.
                      I have also one node which is working (Arduino PRO Mini connected with RFM69 module. And I tried test radio module also with that code:
                      https://learn.adafruit.com/adafruit-rfm69hcw-and-rfm96-rfm95-rfm98-lora-packet-padio-breakouts/rfm69-test. I used working node as transmitter and my homemade board as receiver.
                      And instead of "Hello World" I am getting some trash data:
                      • voximdoV
                        voximdoV
                        voximdo
                        And when I changed it - PRO Mini as reciever and my homeboard as transmitter I got nothing. Homeboard is claiming that it is sending something, but it isn't getting to working node. Even trash data.
                        • voximdoV voximdo
                          YveauxY
                          YveauxY
                          @voximdo I think you're only receiving ones over the spi interface, hence the 255 rssi values. Maybe you swapped mosi & miso signals (edit: seems ok in your schematics)
                          Do you have a scope or logic analyzer you can attach to the spi bus to check correct functioning?
                          • voximdoV
                            voximdoV
                            voximdo
                            I could borrow scope for the weekend. Could you tell me what should I searching for in this signals?
                            • voximdoV voximdo
                              YveauxY
                              YveauxY
                              @voximdo the ss line (normally high) should go low when the avr is talking to the rfm.
                              The clk signal is the clock from the avr to the rfm, to trigger exchange of bits.
                              Miso is data going from rfm to avr, mosi is data in the other direction.
                              You could trace the data from the startup of mysensors, until the check on which it fails and see what happens.
                              There's not much more I can do as I don't have an rfm setup...
                              • voximdoV
                                voximdoV
                                voximdo
                                Thank you very much for suggestions. I will try to check that over the weekend, then I will let you know about my results. In the meantime if someone has any other ideas why it doesn't work or how to debug it somehow I would appreciate.
