  3. Ethernet Gateway with W5100: radio error [solved]
3 Posts 2 Posters 1.9k Views 2 Watching
  • B Offline
    B Offline
    bisschopsr
    wrote on last edited by bisschopsr
    All,
    I know its hasbeen discussed many times on the forum , but I'm completly stuck with my GW.
    I have build the gateway acoording to the instructions https://www.mysensors.org/build/ethernet_gateway.
    The problem I now have is that the radio fails. I checked the wiring many time, changed out all the part, same result over and over again radio fail. I'using the new 2.0.0 library's and took the sketch from the download example.
    My settings are:
    #include <MyConfig.h>
    #define MY_DEBUG_VERBOSE_RF24
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    The error code are:
    Opening port
    Port open
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;RF24:write register, reg=0, value=14
    0;255;3;0;9;RF24:write register, reg=3, value=3
    0;255;3;0;9;RF24:write register, reg=4, value=95
    0;255;3;0;9;RF24:write register, reg=5, value=76
    0;255;3;0;9;RF24:write register, reg=6, value=39
    0;255;3;0;9;RF24:read register, reg=6, value=255
    0;255;3;0;9;RF24:read register, reg=5, value=255
    0;255;3;0;9;RF24:Sanity check failed: configuration mismatch! Check wiring, replace module or non-P version
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    0;255;3;0;9;RF24:write register, reg=0, value=12
    0;255;3;0;9;RF24:power down
    I tried to change the myconfig.h (softspi) and without, result the same all the time.
    So questions are:
    Do I need to enable softspi in myconfig.h?
    Is the pinout still as in the instructions?
    Thanks for any help, puzzeling with this for days now.
    Ralph
    Domoticz, P1 meter interface, MySensors and more to come!
    • mfalkviddM Offline
      I think the problem is that MySensors.h is included before defining what MySensors should do.
      Add
      after the defines. And I don't think you should include MyConfig.h at all. It is included by MySensors.
      B 1 Reply Last reply
        Add
        B Offline
        B Offline
        bisschopsr
        @mfalkvidd Thx: sometimes life is so simple. I totally did not notice that this slipped in...
        Problem solved!
        And to answer my other question myself: I don't need to enable softspi in the MyConfig.h I guess. Works without it apperently.
