  3. Ethernet Gateway On Arduino Mega 2056 Issues
15 Posts 5 Posters 6.0k Views 5 Watching
  • W
    W
    wergeld
    I have the SEEEDstudio ethernet shield W5200 and am using the ethernet gateway code found here. This works fine with SOFTSPI enabled under Mysensors v2 library on my UNO. However, when I build the code out for my Mega 2056 i get this error on the serial monitor:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    What am I missing here?
    • FotoFieberF
      FotoFieberF
      FotoFieber
      The SPI Pins are different on the MEGA2560 than on a 328-Arduino.
      How is your wiring of the NRF24L01+?
      • W
        W
        wergeld
        I am using the following hookup on the ethernet shield to the nrf+:
        A2 --> MISO
        A1 --> MOSI
        A0 --> SCK
        6 --> CSN
        5 --> CE
        • sundberg84S
          @wergeld - Maybe this can give you some hints? https://forum.mysensors.org/topic/1245/building-an-ethernet-gateway-on-an-arduino-mega/3
          W 1 Reply Last reply
          • sundberg84S sundberg84
            W
            W
            wergeld
            @sundberg84
            I had read that. But, to be honest I could not make heads or tails about what the posters said did or did not work. There was no definitive answer on that thread. Some said try pins x/y/z and other said to try a/b/c. Yet, no one said "hey, this actually works". Closest was the comment by spugna85. But, looking at the v2 libraries it was already done (hence me using A0-2 pins).
            • W wergeld
              @sundberg84
              @wergeld - ok, to bad :( give google search a go, it might help you find other threads.
              I cant help you more, not a mega user myself. By the way, ethernet gw works great on Uno or Nano as well.
                W
                W
                wergeld
                @sundberg84
                Yea, by my UNO is used for templating projects for my slimNode. I am only making the ethernet gateway because the direct-connection of the nrf to the RPi is not yet supporting v2 library. Just seems silly to include extra hardware (uno/mega and ethernet shield) when the RPi has GPIO and the nrf can be connected to it. I am using domoticz on the RPi using serial gateway but only with v1.4.
                • FotoFieberF
                  FotoFieberF
                  FotoFieber
                  wrote on last edited by FotoFieber
                  Try with following defines and wire accordingly:
                  #define MY_RF24_CE_PIN 40
                  #define MY_RF24_CS_PIN 53
                  • FotoFieberF FotoFieber
                    W
                    W
                    wergeld
                    @FotoFieber
                    Builds and still I get the error:
                    0;255;3;0;9;TSM:PDT
                    FotoFieberF 1 Reply Last reply
                    • tlpeterT
                      tlpeterT
                      tlpeter
                      I have this error also with a ENC28J60 module.
                      I have used the 1.6.8/9 and 11 ide but that doesn't matter.
                      This was on an Nano by the way.
                      • W wergeld
                        @FotoFieber
                        0;255;3;0;9;TSM:PDT
                        FotoFieberF
                        FotoFieberF
                        FotoFieber
                        @wergeld
                        My gateway is based on a mega 2560 with following wiring:
                        40 CE
                        51 MOSI
                        50 MISO
                        52 SCK
                        53 CSN
                        and the defines from above:
                        Do you have this wiring?
                          @wergeld
                          40 CE
                          51 MOSI
                          50 MISO
                          52 SCK
                          53 CSN
                          W
                          W
                          wergeld
                          @FotoFieber, no. As I stated above this is my wiring:
                          A2 --> MISO
                          A1 --> MOSI
                          A0 --> SCK
                          6 --> CSN
                          5 --> CE
                          When I changed CSN/CE to the 2 pins you mentioned above it was and I was still getting this error:
                          A2 --> MISO
                          A1 --> MOSI
                          A0 --> SCK
                          53 --> CSN
                          40 --> CE
                          To use your wiring I would need to modify the rest of the pin definitions in the code, yes?
                          korttomaK 1 Reply Last reply
                          • W wergeld
                            A2 --> MISO
                            A1 --> MOSI
                            A0 --> SCK
                            6 --> CSN
                            5 --> CE
                            A2 --> MISO
                            A1 --> MOSI
                            A0 --> SCK
                            53 --> CSN
                            40 --> CE
                            korttomaK
                            korttomaK
                            korttoma
                            Wiring like this does not apply for the Mega 2056
                            A2 --> MISO
                            A1 --> MOSI
                            A0 --> SCK
                            If you see from here -> https://arduino-info.wikispaces.com/file/view/Mega2-900.jpg/421499040/Mega2-900.jpg
                            Pinout for Mega 2056:
                            51 MOSI
                            50 MISO
                            52 SCK
                            You need to change your wiring.
                            • Tomas
                            • korttomaK korttoma
                              A2 --> MISO
                              A1 --> MOSI
                              A0 --> SCK
                              51 MOSI
                              50 MISO
                              52 SCK
                              W
                              W
                              wergeld
                              @korttoma, excellent! I will try this out when I get home from work.
                              • W
                                W
                                wergeld
                                @korttoma
                                Success! Got this ethernet gateway up and running! Thank you very much.
