  3. Ethernet Gateway On Arduino Mega 2056 Issues
15 Posts 5 Posters 6.0k Views 5 Watching
  • sundberg84S sundberg84
    @wergeld - Maybe this can give you some hints? https://forum.mysensors.org/topic/1245/building-an-ethernet-gateway-on-an-arduino-mega/3
    W
    W
    wergeld
    @sundberg84
    I had read that. But, to be honest I could not make heads or tails about what the posters said did or did not work. There was no definitive answer on that thread. Some said try pins x/y/z and other said to try a/b/c. Yet, no one said "hey, this actually works". Closest was the comment by spugna85. But, looking at the v2 libraries it was already done (hence me using A0-2 pins).
    • W wergeld
      @sundberg84
      sundberg84S
      sundberg84S
      @wergeld - ok, to bad :( give google search a go, it might help you find other threads.
      I cant help you more, not a mega user myself. By the way, ethernet gw works great on Uno or Nano as well.
      W 1 Reply Last reply
        W
        W
        wergeld
        @sundberg84
        Yea, by my UNO is used for templating projects for my slimNode. I am only making the ethernet gateway because the direct-connection of the nrf to the RPi is not yet supporting v2 library. Just seems silly to include extra hardware (uno/mega and ethernet shield) when the RPi has GPIO and the nrf can be connected to it. I am using domoticz on the RPi using serial gateway but only with v1.4.
        • FotoFieberF
          FotoFieberF
          FotoFieber
          wrote on last edited by FotoFieber
          Try with following defines and wire accordingly:
          #define MY_RF24_CE_PIN 40
          #define MY_RF24_CS_PIN 53
          • FotoFieberF FotoFieber
            W
            W
            wergeld
            @FotoFieber
            Builds and still I get the error:
            0;255;3;0;9;TSM:INIT
            0;255;3;0;9;!TSM:RADIO:FAIL
            0;255;3;0;9;!TSM:FAILURE
            0;255;3;0;9;TSM:PDT
            • tlpeterT
              tlpeterT
              tlpeter
              I have this error also with a ENC28J60 module.
              I have used the 1.6.8/9 and 11 ide but that doesn't matter.
              This was on an Nano by the way.
              • W wergeld
                @FotoFieber
                0;255;3;0;9;TSM:PDT
                FotoFieberF
                FotoFieberF
                FotoFieber
                @wergeld
                My gateway is based on a mega 2560 with following wiring:
                40 CE
                51 MOSI
                50 MISO
                52 SCK
                53 CSN
                and the defines from above:
                Do you have this wiring?
                  @wergeld
                  40 CE
                  51 MOSI
                  50 MISO
                  52 SCK
                  53 CSN
                  W
                  W
                  wergeld
                  @FotoFieber, no. As I stated above this is my wiring:
                  A2 --> MISO
                  A1 --> MOSI
                  A0 --> SCK
                  6 --> CSN
                  5 --> CE
                  When I changed CSN/CE to the 2 pins you mentioned above it was and I was still getting this error:
                  A2 --> MISO
                  A1 --> MOSI
                  A0 --> SCK
                  53 --> CSN
                  40 --> CE
                  To use your wiring I would need to modify the rest of the pin definitions in the code, yes?
                  korttomaK 1 Reply Last reply
                  • W wergeld
                    A2 --> MISO
                    A1 --> MOSI
                    A0 --> SCK
                    6 --> CSN
                    5 --> CE
                    A2 --> MISO
                    A1 --> MOSI
                    A0 --> SCK
                    53 --> CSN
                    40 --> CE
                    korttomaK
                    korttomaK
                    korttoma
                    Wiring like this does not apply for the Mega 2056
                    A2 --> MISO
                    A1 --> MOSI
                    A0 --> SCK
                    If you see from here -> https://arduino-info.wikispaces.com/file/view/Mega2-900.jpg/421499040/Mega2-900.jpg
                    Pinout for Mega 2056:
                    51 MOSI
                    50 MISO
                    52 SCK
                    You need to change your wiring.
                    • Tomas
                    • korttomaK korttoma
                      A2 --> MISO
                      A1 --> MOSI
                      A0 --> SCK
                      51 MOSI
                      50 MISO
                      52 SCK
                      W
                      W
                      wergeld
                      @korttoma, excellent! I will try this out when I get home from work.
                      • W
                        W
                        wergeld
                        @korttoma
                        Success! Got this ethernet gateway up and running! Thank you very much.
