  3. Ethernet Gateway On Arduino Mega 2056 Issues
15 Posts 5 Posters 6.0k Views 5 Watching
  • sundberg84S
    sundberg84S
    @wergeld - Maybe this can give you some hints? https://forum.mysensors.org/topic/1245/building-an-ethernet-gateway-on-an-arduino-mega/3
    W 1 Reply Last reply
    • sundberg84S sundberg84
      W
      W
      wergeld
      @sundberg84
      I had read that. But, to be honest I could not make heads or tails about what the posters said did or did not work. There was no definitive answer on that thread. Some said try pins x/y/z and other said to try a/b/c. Yet, no one said "hey, this actually works". Closest was the comment by spugna85. But, looking at the v2 libraries it was already done (hence me using A0-2 pins).
      • W wergeld
        @sundberg84
        sundberg84S
        sundberg84S
        @wergeld - ok, to bad :( give google search a go, it might help you find other threads.
        I cant help you more, not a mega user myself. By the way, ethernet gw works great on Uno or Nano as well.
          W
          W
          wergeld
          @sundberg84
          Yea, by my UNO is used for templating projects for my slimNode. I am only making the ethernet gateway because the direct-connection of the nrf to the RPi is not yet supporting v2 library. Just seems silly to include extra hardware (uno/mega and ethernet shield) when the RPi has GPIO and the nrf can be connected to it. I am using domoticz on the RPi using serial gateway but only with v1.4.
          • FotoFieberF
            FotoFieberF
            FotoFieber
            wrote on last edited by FotoFieber
            Try with following defines and wire accordingly:
            #define MY_RF24_CE_PIN 40
            #define MY_RF24_CS_PIN 53
            • FotoFieberF FotoFieber
              W
              W
              wergeld
              @FotoFieber
              Builds and still I get the error:
              0;255;3;0;9;TSM:INIT
              0;255;3;0;9;!TSM:RADIO:FAIL
              0;255;3;0;9;!TSM:FAILURE
              0;255;3;0;9;TSM:PDT
              • tlpeterT
                tlpeterT
                tlpeter
                I have this error also with a ENC28J60 module.
                I have used the 1.6.8/9 and 11 ide but that doesn't matter.
                This was on an Nano by the way.
                • W wergeld
                  @FotoFieber
                  0;255;3;0;9;TSM:PDT
                  FotoFieberF
                  FotoFieberF
                  FotoFieber
                  @wergeld
                  My gateway is based on a mega 2560 with following wiring:
                  40 CE
                  51 MOSI
                  50 MISO
                  52 SCK
                  53 CSN
                  and the defines from above:
                  Do you have this wiring?
                    @wergeld
                    40 CE
                    51 MOSI
                    50 MISO
                    52 SCK
                    53 CSN
                    W
                    W
                    wergeld
                    @FotoFieber, no. As I stated above this is my wiring:
                    A2 --> MISO
                    A1 --> MOSI
                    A0 --> SCK
                    6 --> CSN
                    5 --> CE
                    When I changed CSN/CE to the 2 pins you mentioned above it was and I was still getting this error:
                    A2 --> MISO
                    A1 --> MOSI
                    A0 --> SCK
                    53 --> CSN
                    40 --> CE
                    To use your wiring I would need to modify the rest of the pin definitions in the code, yes?
                    korttomaK 1 Reply Last reply
                    • W wergeld
                      A2 --> MISO
                      A1 --> MOSI
                      A0 --> SCK
                      6 --> CSN
                      5 --> CE
                      A2 --> MISO
                      A1 --> MOSI
                      A0 --> SCK
                      53 --> CSN
                      40 --> CE
                      korttomaK
                      korttomaK
                      korttoma
                      Wiring like this does not apply for the Mega 2056
                      A2 --> MISO
                      A1 --> MOSI
                      A0 --> SCK
                      If you see from here -> https://arduino-info.wikispaces.com/file/view/Mega2-900.jpg/421499040/Mega2-900.jpg
                      Pinout for Mega 2056:
                      51 MOSI
                      50 MISO
                      52 SCK
                      You need to change your wiring.
                      • Tomas
                      • korttomaK korttoma
                        A2 --> MISO
                        A1 --> MOSI
                        A0 --> SCK
                        51 MOSI
                        50 MISO
                        52 SCK
                        W
                        W
                        wergeld
                        @korttoma, excellent! I will try this out when I get home from work.
                        • W
                          W
                          wergeld
                          @korttoma
                          Success! Got this ethernet gateway up and running! Thank you very much.
