  2. Announcements
  3. 💬 Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 71.7k Views 51 Watching
  • rejoe2R rejoe2
    Sorry, I'm not familiar with the ESP32; perhaps you have a look around for other more powerful platforms on MySensors, starting here: https://forum.mysensors.org/topic/6961/nrf5-action.
    The problem within MySensors afaik is a double one:
    • First you have to make sure the GW get's the message. Eg. in FHEM, this is a problem, as one node basically is only identified by it's NodeID. As already described, internally there's a distinction between the GW part and the Sensor (node-) part. And the Sensor part gets unavoidably (at least afaik) the NodeID 0 - so for the controller all the Children are located at the same Node.
      As the controller notes just one IO (aka GW) per Node, Messages to the "unified" Node 0 will always be routed to the same GW. If this is different when using MQTT as transport layer and not serial or IP communication? (could be, as more clients can subscribe to a "Node 0"-topic...)
    • Second thing then is to make sure to not mess up messages intented for different GW's when doing some "broadcasting" by MQTT. Means: use different ChildID's for all the GW's sensors and actuators.
    Best success!
    I
    I
    Inso
    @rejoe2
    You´re absolutely right.
    After 4+ hours debugging the MQTT gateway + ~10h trying to get MySensors MQTT on ethernet working properly, I tried a different way:
    installed NoteRed on the RPi and an asynchronous MQTT client on the ESP32, and within ~1 hour I had a fast and stable way to send messages from and to my nodes. Adding JSON parser on the ESP, and I can perfectly communicate with dummy Domoticz devices.
    Also, except of you and one very helpful guy within a private chat, noone preplied to MQTT-questions and ESP-stuff. Seems working with ESPs is reluctantly seen here on the forum.?
    So I assume a different way then using MySensors for everything except (battery-powered) Arduinos is the best I can do, to also have no problems in the future..
    rejoe2R 1 Reply Last reply
    • I Inso
      @rejoe2
      rejoe2R
      rejoe2R
      rejoe2
      @inso
      Thanks for the feedback, sorry for your ineffective messin around with mysensors. I completely agree to your conclusion using MQTT directly on more powerfull boards able to communicate directly via WiFi.
      @inso said in 💬 Building a WiFi Gateway using ESP8266:
      I can only speak for myself :grin: but indeed, I absolutely dislike having (regular) WiFi devices integrated in my home automation. My personal concept is to use as much wires as possible (thus I really love the RS485 stuff here!) and use different RF technologies whereever possible - and connect the corresponding GW's using a USB plug!
      So atm I exactly have 2 ESP8266-based devices integrated: One is a bridge for my MiLight stuff (avoid that type of devices, but in case if, use the sidoh-firmware!), one is a IR-Device to play around...
      But everybody has to find his own way. Just my personal thoughts on that topic :smirk:
        I am running nrf24 and rfm69 gateways on the raspberry directly, so I don't have the need for additional hw. I am planning to use the esp32 as a presence detector though
        • MasMatM
          MasMatM
          MasMat
          wrote on last edited by MasMat
          #84
          I built a ESP8266 (Lolin V3) gw with RFM69 868mhz according to instructions.
          I flashed NodeMCU with EspTool without problems. I then uploaded my sketch. It started first OK, but after I set a fixed IP with my router, it will not connect anymore (to router??).
          Debug:
          $l⸮⸮`,ld⸮p :Y⸮56 MCO:BGN:INIT GW,CP=RRNGE---,REL=255,VER=2.3.1
          108 TSF:LRT:OK
          124 TSM:INIT
          137 TSF:WUR:MS=0
          157 TSM:INIT:TSP OK
          scandone
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 7
          cnt
          connected with Neptune, channel 11
          dhcp client start...
          323 TSM:INIT:GW MODE
          346 TSM:READY:ID=0,PAR=0,DIS=0
          378 MCO:REG:NOT NEEDED
          406 TSM:READY:NWD REQ
          1840 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
          scandone
          1923 GWT:TPC:CONNECTING...
          2452 GWT:TPC:CONNECTING...
          2980 GWT:TPC:CONNECTING...
          3508 GWT:TPC:CONNECTING...
          4036 GWT:TPC:CONNECTING...
          4564 GWT:TPC:CONNECTING...
          5092 GWT:TPC:CONNECTING...
          5620 GWT:TPC:CONNECTING...
          6148 GWT:TPC:CONNECTING...
          6676 GWT:TPC:CONNECTING...
          7204 GWT:TPC:CONNECTING...
          7732 GWT:TPC:CONNECTING...
          8260 GWT:TPC:CONNECTING...
          8788 GWT:TPC:CONNECTING...
          9316 GWT:TPC:CONNECTING...
          9844 GWT:TPC:CONNECTING...
          pm open,type:2 0
          10372 GWT:TPC:CONNECTING...
          10901 GWT:TPC:CONNECTING...
          11430 GWT:TPC:CONNECTING...
          11959 GWT:TPC:CONNECTING...
          12488 GWT:TPC:CONNECTING...
          13017 GWT:TPC:CONNECTING...
          Sketch:
          #define MY_BAUD_RATE 9600
          #define MY_RADIO_RFM69
          #define MY_RFM69_FREQUENCY RFM69_868MHZ // Set your frequency here
          #define MY_IS_RFM69HW // Omit if your RFM is not "H"
          #define MY_RFM69_IRQ_PIN D1
          #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN
          #define MY_GATEWAY_ESP8266
          #define MY_MQTT_PUBLISH_TOPIC_PREFIX "domoticz/in/mysenRFM69"
          #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "domoticz/out/mysenRFM69"
          #define MY_MQTT_CLIENT_ID "mysenRFM69"
          #define MY_MQTT_USER "ZZZZ"
          #define MY_MQTT_PASSWORD "YYYYYYYY"
          #define MY_WIFI_SSID "Neptune"
          #define MY_WIFI_PASSWORD "XXXXXXXXXXXX"
          #define MY_HOSTNAME "mqtt-ESP8266-gateway"
          #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 51
          #define MY_PORT 1883
          // Flash leds on rx/tx/err
          #include <ESP8266WiFi.h>
          Sketch or router problem?
          Powered with computer usb + 800mA 5V charger at the moment.
          • pkriekP
            pkriekP
            pkriek
            wrote on last edited by pkriek
            #85
            Hi I just have build this GW. and it is working. But as you can see in the screenshots, I get really strange readings from my sensors. The serial connected GW is working good.
            the first screenshot, strange temperature. no idea from where this is coming. second screen shot also strange temperature, and a battery reading.....
            I know from which sensors this is coming since the serial GW is also logging them. and these values are simply wrong. any idea what I should change?
            thanks
            • D
              D
              DenisJ
              @MasMat said in 💬 Building a WiFi Gateway using ESP8266:
              Sorry if I ask a noob question... I'm new and just arrived at MySensors
              This screenshot, where is from please ? I mean What software you use ?
              Thanks a lot
              Denis
              • D
                D
                DenisJ
                Hi there all,
                I'm new here and for first think I'll like to thanks a lot for this wonderful MySensors
                I just folow step-by-step the guide here: Building a WiFi Gateway using ESP8266
                • use all this on a NodeMcu
                • I opened the sketch from Arduino Ide from File>Examples>My Sensors> GatewayESP8266
                • I edited my WiFi credentials, compiled, and write it on the NodeMcu
                • I opened the serial console and watch...
                This is what I see on the NodeMcu log:
                2216 GWT:TIN:CONNECTING...
                scandone
                state: 0 -> 2 (b0)
                3982 GWT:TIN:CONNECTING...
                state: 2 -> 3 (0)
                state: 3 -> 0 (12)
                reconnect
                5068 GWT:TIN:CONNECTING...
                6096 GWT:TIN:CONNECTING...
                7124 GWT:TIN:CONNECTING...
                scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 0 (12)
                This NodeMcu was always connecting on my WiFi LAN.
                Someone can help me please ?
                Thanks in advance
                Denis
                • D
                  D
                  DenisJ
                  I finally understand with was the problem...
                  My WiFi Mesh LAN accepted only 802.11.g+n radio... now that I have set 802.11.b+g+n it's ok
                  Strange this think cause an all other WiFi Arduino schetch the 802.11.g+n radio was always accepted.
                  Anyway... now it's work :-)
                  Denis
                  • G
                    G
                    Gerard_Tlse
                    I have a small problem: I am using the Gateway Mysensor EPS8266 WIFi.
                    Everything is correctly working except the leds:
                    in the code mysensor code , there is:
                    // Flash leds on rx / tx / err
                    // Led pins used if blinking feature is enabled above
                    I replaced by:
                    #define MY_DEFAULT_ERR_LED_PIN 1 // Error led pin
                    #define MY_DEFAULT_RX_LED_PIN 3 // Receive led pin
                    #define MY_DEFAULT_TX_LED_PIN 4 // the PCB, on board LED
                    and it does not work: the LEDs are always half-on.
                    can You tell me if these pins are used for other things and only PIN16 is available for the user ?
                    Thanks for your help
                    Gerard
                    • Z
                      Z
                      Zwer2k
                      I have been using MySensors for a long time. First with serial gateway now with ESP8266 gateway. For months everything worked fine except for small dropouts. Due to dropouts I wanted to switch to current development branch, since then I can not get the gateway to work.
                      The ESP delivers only the following output:
                       ets Jan  8 2013,rst cause:2, boot mode:(3,6)
                      load 0x4010f000, len 3460, room 16
                      tail 4
                      chksum 0xcc
                      load 0x3fff20b8, len 40, room 4
                      tail 4
                      chksum 0xc9
                      csum 0xc9
                      v00051da0
                      ~ld
                      I use ESP07 with RFM69 and Standard Sketch. Compiled the code with Arduino IDE as well as with VS code, always with the same result.
                      I disconnected RFM69 and checked the supply voltage. Have even used other calculator.
                      Have also tested ESP12e.
                      Erase Flash I have also already done.
                      However, when I run other code on the ESP, it runs without problems.
                      I just don't understand it.
                      #define MY_BAUD_RATE 115200
                      #define MY_WIFI_SSID "my ssid"
                      #define MY_WIFI_PASSWORD "my pw"
                      #define MY_HOSTNAME "MySensors-GW"
                      #define MY_PORT 5003
                      #define MY_GATEWAY_MAX_CLIENTS 3
                      YveauxY 1 Reply Last reply
                      • Z Zwer2k
                        tail 4
                        chksum 0xcc
                        tail 4
                        chksum 0xc9
                        csum 0xc9
                        v00051da0
                        ~ld
                        YveauxY
                        YveauxY
                        @Zwer2k please don't crosspost!
                        • Z
                          Z
                          Zwer2k
                          Sorry for crosspost.
                          I found out that the error was due to too new version of espressif8266. I had version 3.1.0 installed, but MySensors seems to work only with versions < 3.0.0. Otherwise the error comes up. Unfortunately I did not find any hint about this anywhere.
                          • Serj SamS
                            Serj SamS
                            Serj Sam
                            Hello! I'm trying to run ESP8266 gateway with nrf24l01 radio module, but when I run it I don't see any logs, I've enebled debugging mode, but still no logs (and it doesn't run gateway either). I've checked connection between this board end esp32 - they communicate well. Don't know what to do else.
                            YveauxY mfalkviddM 2 Replies Last reply
                            • Serj SamS Serj Sam
                              YveauxY
                              YveauxY
                              @Serj-Sam logs are available through serial port. You mention esp8266 and esp32; which one is it?
                                @Serj-Sam you mention "connection between this board and esp32". What board are you referring to, and what type of connection? Wifi?
                                Serj SamS 1 Reply Last reply
                                  Serj SamS
                                  Serj SamS
                                  Serj Sam
                                  @mfalkvidd I have esp8266 NodeMCU v3. I've connected it to esp32 devkit via nrf24l01 using simple test code where I sending and reading constant string. It's just to exclude problems with nrf24l01 and esp8266.
                                  @Yveaux I don't have any logs through serial port related to the MySensors. When I remove MySensors lib (and the code related to it) I'm able to print messages in setup() and loop() section, but with MySensors lib it stuckted somewhere without logs and do not execute code in setup() and loop() sections.
                                    YveauxY
                                    YveauxY
                                    @Serj-Sam you could very well have run into the incompatibility of mysensors with the latest esp arduino core 3.x (see eg https://github.com/mysensors/MySensors/issues/1496)
                                    Easiest solution is to downgrade the esp arduino core to 2.x
                                    • YveauxY Yveaux
                                      Serj SamS
                                      Serj SamS
                                      Serj Sam
                                      @Yveaux said in 💬 Building a WiFi Gateway using ESP8266:
                                      Thank you @Yveaux ! It works now! Have you heard anything about long-term solution? Looks like this will be overwritten once I update MySensors lib.
                                        YveauxY
                                        YveauxY
                                        @Serj-Sam there is a pull request included in that pr. Once this is merged it will be available in development, later in the next release.
                                        If you just downgraded the core, that is persistent until you upgrade the core to 3.x again.
                                          maddhin
                                          I would like to add sendSketchInfo to my gateway.
                                          I added
                                          const char* sketch_name = "GatewayESP8266OTA_v3";
                                          const char* rev = "1.01";
                                          at the beginning of the sketch and
                                          sendSketchInfo(sketch_name, rev);
                                          in the presentation part.
                                          but this doesn't seem to work. Am I doing anything wrong? Any suggestion on how to do it right? Many thanks in advance!
