  2. Announcements
  3. 💬 Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 73.8k Views 51 Watching
    wrote on last edited by hek
    This thread contains comments for the article "Building a WiFi Gateway using ESP8266" posted on MySensors.org.
    ramoncarranzaR 1 Reply Last reply
    • Fat FlyF
      Fat FlyF
      Fat Fly
      Small question. How to connect this gw to Domoticz ? Over lan and in Domoticz ?
      B 1 Reply Last reply
      • breimannB
        breimannB
        breimann
        Yes would this work with a Rasp Pi controller running Domoticz? Just connect over WIFI to the same network the Controller is connected to?
        • Fat FlyF
          Fat FlyF
          Fat Fly
          Yes. Network is same.
          • popP
            popP
            pop
            Can the esp8266Gateway be used as an MQTT gateway too? Is it a config issue or does more code need porting first?
              Yes,
              The configuration and example can be found here:
              https://www.mysensors.org/build/mqtt_gateway
              • popP
                popP
                pop
                Fantastic. Thanks.
                • Patrik SöderströmP
                  Patrik SöderströmP
                  Patrik Söderström
                  Uploaded this sktech to a NodeMcu yesterday, i can add it in domoticz. When i try to add a light sensor, it shows up as a light sensor node in domoticz under the Mysensors lan gateway. but it does not show any device. Anyone who have an idea?
                    Please use the development branch until 2.0.1 has been released.
                    It allows presentation on gateway attached devices.
                      Patrik SöderströmP
                      Patrik Söderström
                      Cool, I downloaded it and replaced the old master brach.
                      Still get the same effect.
                      I paste my sketch here, all except the wifi part, that works. Tell me if I should include it here as well. But I feel its something in this below part that is failing on me
                      //###################### LIGHT SENSOR #####################
                      #define CHILD_ID_LIGHT 0
                      #define LIGHT_SENSOR_ANALOG_PIN 0
                      int lastLightLevel;
                      void presentation() {
                      sendSketchInfo("Light Sensor", "1.0");
                        int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                        Serial.println(lightLevel);
                            send(msg.set(lightLevel));
                            lastLightLevel = lightLevel;
                        sleep(SLEEP_TIME);
                      • bgunnarbB
                        bgunnarbB
                        bgunnarb
                        A couple of ESP-12E modules arrived in the mail last Friday and I uploaded the ESP8266 MQTT GW sketch. It worked immediately. Fantastic!
                        I am using a cloudserver MQTT broker on cloudmqtt.com and the OpenHab controller subscribes to that as well.
                        Just a question... I tried to enable the LED BLINKING feature but it seems there are no free pins on the ESP-12 module. I've tried the not connected pins but whatever pin I select (0,1,3,4,9,10) this seems to stop the GW from starting. Ideas anyone?
                        I have never been so busy since I retired!
                        • bgunnarbB bgunnarb
                          @bgunnarb great that you got it working so quickly!
                          Not sure which numbering scheme you are using (there are unfortunately many ways to number the ESP pins) but many of the pins have special use and are therefore hard to utilize. Some of my notes on the subject:
                          GPIO0, gpio2 an gpio15 are tricky but can be used if special care is taken: http://www.instructables.com/id/ESP8266-Using-GPIO0-GPIO2-as-inputs/?ALLSTEPS
                          gpio16 also seems special, see http://bbs.espressif.com/viewtopic.php?t=632
                          GPIO6-GPIO11 are typically used to interface with the flash memory ICs on most esp8266 modules, so these pins should not generally be used.
                          http://www.esp8266.com/wiki/doku.php?id=esp8266_gpio_pin_allocations has lots of information on the pins.
                          Kolban's book on ESP has a nice clear and color-coded table describing which pins are "safe" to use without any hassle.
                          • siodS
                            siodS
                            siod
                            This post is deleted!
                            • siodS
                              siodS
                              siod
                              • FotoFieberF
                                FotoFieberF
                                FotoFieber
                                Please add a wiring diagram for the RFM69.
                                I found this:
                                https://forum.mysensors.org/topic/3061/solved-esp8266-gateway-with-rfm69-wdt-issues/4
                                But I miss the CE in that post.
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  There is no CE pin on the RFM69
                                  https://www.mysensors.org/build/connect_radio
                                  • Tomas
                                  FotoFieberF 1 Reply Last reply
                                  • Fat FlyF
                                    Fat FlyF
                                    Fat Fly
                                    Please look right connection diagram. Not nrf24l01+. and you see how to connect. If you do not see you van watch with glasses.
                                    • korttomaK korttoma
                                      FotoFieberF
                                      FotoFieberF
                                      FotoFieber
                                      @korttoma
                                      :open_mouth:
                                      Shame on me... I am using a NRF2RFM69 adapter with a CE pin and didn't realize it has no function.
                                      • E
                                        E
                                        emc2
                                        I'm currently adding some wifi gateways at work, I was wondering:
                                        • is ATSHA204 signing support something planned, or will it stay on soft-sign only mode?
                                        • is IRQ support something planned too?
                                        It's mostly to see if I need to plan to add these features on the PCB for later, or not.
                                        Thanks!
                                        • G
                                          G
                                          gmccarthy
                                          @FotoFieber Did you come right with the RFM69? I also struggling to get it working and need to confirm the wiring diagram.
