  2. Announcements
  3. 💬 Building a MQTT Gateway
81 Posts 30 Posters 49.7k Views 28 Watching
  • L
    L
    linkinpio
    I think I'm ussing the latest one
    but as you said I don't think it will fix my issue though.
    But looking at the examples I found that they have a connect function which then can be used to reconnect whenever needed not constantly like it happens now,
    But not sure how I could integrate that functionality in this sketch though, as I'm not that experienced with programming :/
    To you think it will be possible?
     Reconnecting MQTT example - non-blocking
     This sketch demonstrates how to keep the client connected
     using a non-blocking reconnect function. If the client loses
     its connection, it attempts to reconnect every 5 seconds
     without blocking the main loop.
    #include <Ethernet.h>
    #include <PubSubClient.h>
    // Update these with values suitable for your hardware/network.
    byte mac[]    = {  0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
    IPAddress ip(172, 16, 0, 100);
    IPAddress server(172, 16, 0, 2);
    void callback(char* topic, byte* payload, unsigned int length) {
      // handle message arrived
    EthernetClient ethClient;
    PubSubClient client(ethClient);
    long lastReconnectAttempt = 0;
    boolean reconnect() {
      if (client.connect("arduinoClient")) {
        // Once connected, publish an announcement...
        client.publish("outTopic","hello world");
        // ... and resubscribe
        client.subscribe("inTopic");
      return client.connected();
      client.setServer(server, 1883);
      client.setCallback(callback);
      Ethernet.begin(mac, ip);
      delay(1500);
      if (!client.connected()) {
        long now = millis();
        if (now - lastReconnectAttempt > 5000) {
          lastReconnectAttempt = now;
          // Attempt to reconnect
          if (reconnect()) {
      } else {
        // Client connected
        client.loop();
