  2. Announcements
  3. 💬 Building a MQTT Gateway
81 Posts 30 Posters 48.3k Views 28 Watching
  • S Offline
    stephenmhall
    Not sure if you want to leave the GPS on there unless that isn't your house with the double hot tub in tha back garden :)
    • Mountek AngelM Offline
      Mountek Angel
      Hi, is it possible to configure the MQTT gateway to let me in to port 5003 via telnet and read the communication message (not MQTT payloads) there also?
      M 1 Reply Last reply
      • proddyP Offline
        proddyP Offline
        proddy
        Not sure if this helps but for debugging I use MQTT spy (https://github.com/eclipse/paho.mqtt-spy/wiki) for tracking the comms
          There is also mqtt fx that can be used to see what's going on on the mqtt server
          Mountek AngelM 1 Reply Last reply
            Mountek Angel
            I know what is going on the MQTT server and I am subscribed to the topics the Mysensors gateway created and publish data to it.
            But, I want to know what is going on the GATEWAY as well. I'd like to see messages like these when I telnet to the gateway on port 5003 (that's the default as I remember)
            0;255;3;0;9;TSM:INIT
            0;255;3;0;9;TSM:RADIO:OK
            0;255;3;0;9;TSM:GW MODE
            0;255;3;0;9;TSM:READY
            IP: 192.168.0.109
            0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
            0;255;3;0;9;TSP:MSG:BC
            0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
            0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
            0;255;3;0;9;TSP:MSG:GWL OK
            0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
              There is the tool MYSController that connects to the gateway and shows all the messages
              • S Offline
                Samuel235
                My gateway seems to be constantly repeating the following on the serial monitor:
                IP: 192.168.0.22
                0;255;3;0;9;MQTT connected
                0;255;3;0;9;Sending message on topic: Gateway1-out/0/255/0/0/18
                0;255;3;0;9;Message arrived on topic: Gateway1-in/4/1/1/0/2
                0;255;3;0;9;TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                IP: 192.168.0.22
                IP: 192.168.0.22
                Does this look like its in a reset loop or would you say there is some other issue going on?
                If needed, my config is a Arduino Mega 2560 witha w5100 shield on top. I have specified the IP address of itself, the subnet, gateway, mqtt client IP (Controller), the mqtt topics, port, changed my LED pins.
                I have a node with a button next to me, when i press it the message is picked up by the gateway. Below is what happens in the serial monitor when i press the node button.
                IP: 192.168.0.22
                0;255;3;0;9;TSF:MSG:READ,3-3-0,s=3,c=1,t=2,pt=2,l=2,sg=0:1
                0;255;3;0;9;Sending message on topic: Gateway1-out/3/3/1/0/2
                I'm a little confused at what point to troubleshoot here because I seem to think that for some reason it keeps refreshing its connection to the MQTT server. Not too sure why it is pushing a message to the topic of "Gateway1-out/0/255/0/0/18" either.
                MySensors 2.1.1
                mfalkviddM 2 Replies Last reply
                • S Samuel235
                  IP: 192.168.0.22
                  IP: 192.168.0.22
                  IP: 192.168.0.22
                  IP: 192.168.0.22
                  @Samuel235 see if the solution suggested by tekka in https://forum.mysensors.org/post/47225 can help (downgrade board definitions to 1.6.11)
                  • S Samuel235
                    IP: 192.168.0.22
                    IP: 192.168.0.22
                    IP: 192.168.0.22
                    IP: 192.168.0.22
                    In case anyone needs to know where to downgrade: Tools -> Boards ->Boards Manager -> Select version for Arduini AVR Boards.
                    S 1 Reply Last reply
                      Samuel235
                      @mfalkvidd - It is still seeming to repeatedly reconnect to the MQTT server. I've issued a ping command to the arduino from the mqtt server and its constantly pinging without an issue, even while the serial monitor shows that its reconnecting. I'de be interested to know if anyone else is running the MQTT client gateway with MySensors V2.1. I used to run it when it was first introduced into the development environment in 1.6 and its been fine for over a year, but i upgraded to V2.1 and now i get this. So, i don't actually know if it is supposed to keep reconnecting to the MQTT server. I have read somewhere here that it sends a wake/refresh packet/message to the mqtt server just to keep it alive, but they said that was every 15 seconds by default. This is happening every 5/6 seconds.
                      IP: 192.168.0.22
                      IP: 192.168.0.22
                      IP: 192.168.0.22
                      MySensors 2.1.1
                        i think you need to post your code just to make more complete info.
                        • S Offline
                          Samuel235
                          I would like to know if anyone else's MQTT Gateway does this?
                          If this is the normal procedure I can carry on with config work for the nodes. Its pretty weird, the serial monitor is showing this but the gateway seems to be functioning. Nodes are talking to it. I'm not sure on that output topic though, why would it be sending something to Gateway1-out/0/255/0/0/18?
                          MySensors 2.1.1
                            Samuel235
                            #33
                            @gohan - I have not touched the MySensors.h or MyConfig.h but the sketch is below:
                             * Version 1.0 - Henrik Ekblad
                             * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
                             * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
                             * LED purposes:
                             * nRF24L01+  ESP8266
                             * VCC        VCC
                             * CE         GPIO4
                             * CSN/CS     GPIO15
                             * SCK        GPIO14
                             * MISO       GPIO12
                             * MOSI       GPIO13
                              * Inclusion mode button:
                            #define MY_MQTT_PUBLISH_TOPIC_PREFIX "Gateway1-out"
                            #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "Gateway1-in"
                            // Set MQTT client id
                            //#define MY_W5100_SPI_EN 4
                            // radio on the same spi bus.
                            #define MY_SOFTSPI
                            #ifndef MY_RF24_CE_PIN
                            #define MY_RF24_CE_PIN 5
                            #ifndef MY_RF24_CS_PIN
                            #define MY_RF24_CS_PIN 6
                            #define MY_IP_ADDRESS 192,168,0,22
                            #define MY_IP_GATEWAY_ADDRESS 192,168,0,1
                            #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 21
                            #define MY_PORT 1883
                            // Enable inclusion mode
                            // Set blinking period
                            // Flash leds on rx/tx/err
                            #define MY_DEFAULT_ERR_LED_PIN 11  // Error led pin
                            #define MY_DEFAULT_RX_LED_PIN  12  // Receive led pin
                            #define MY_DEFAULT_TX_LED_PIN  13  // the PCB, on board LED
                            #include <Ethernet.h>
                            EDIT: My issue was resting on the MQTT Server, had OpenHAB and MySensors gateway using same ClientID.
                            MySensors 2.1.1
                            • Mountek AngelM Mountek Angel
                              M Offline
                              M Offline
                              mlava
                              @Gabor-Bognar I also need to be able to do this.
                              Is there a solution to have a port 1883 for MQTT and port 5003 for telnet?
                              • G Offline
                                G Offline
                                Gefkuz
                                There is a missing parameter in your sketch :
                                // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
                                #define MY_MAC_ADDRESS 0x90, 0xA2, 0xDA, 0x10, 0xEB, 0x1D
                                In normal way, this line is note really important.
                                But if you want to use two separate MQTT on the same network, you should add this line and modify the mac adress on the two MQTT...
                                Bye
                                • S Offline
                                  scottdube
                                  Is it possible to have a single device acting as a ethernet gateway and an mqtt gateway?
                                    No, but if you really really need the 2 connections you could use node-red to read data from the ethernet gateway and mirror them to mqtt
                                    • S Offline
                                      scottdube
                                      I am wondering why you cannot built the ethernet gateway and combine the mqtt client sketch into it? I am trying to shift towards mqtt (experiment) while still having sensors available in Vera. I have the MQTT plugin on vera but have not yet figured out how to use the child device to control devices via MQTT. It seems like a waste to control the MQTT device only through Vera and I would never be able to shift away from vera that way. I'm new to this so I am still trying to understand the entire picture.
                                      Thanks!
                                      • S scottdube
                                        Thanks!
                                        #39
                                        @scottdube my guess is that nobody with sufficient knowledge has had enough motivation and time to see if it can be done - especially since other solutions (nodered, myscontroller) already exist.
                                          scottdube
                                          @mfalkvidd I am missing something, the reason I want it to do both is that I want the flexibility to use Node Red and my Vera controller. I was thinking that as I built new sensors they would run through node red but be available to vera as well. I'm sure I just don't yet understand how people are designing their hybrid systems yet. My solution was to have the mysensors gateway also put the sensors values out to the mqtt broker and vice versa but there must be another way I am not seeing yet...
                                          Thanks!
