  2. Announcements
  3. 💬 Building a MQTT Gateway
81 Posts 30 Posters 48.3k Views 28 Watching
  • G Guillermo Schimmel
    Hi guys. I'm using an Arduino Uno+5100 based MQTT gateway. It works fine for it's gateway function but I'm not beeing able to send local sensor data. Is that possible?
    #61
    @guillermo-schimmel it should be possible to call present() and send() just like on a regular node. Could you share your sketch and the debug output?
    G 1 Reply Last reply
      G Offline
      G Offline
      Guillermo Schimmel
      @mfalkvidd thanks. I just did that on a dedicated post. It's driving me crazy.
      https://forum.mysensors.org/topic/10109/ethernet-mqtt-gateway-slow-to-connect
        @guillermo-schimmel ok, lets discuss there then so we don't split the effort and information in separate threads.
        • E Offline
          E Offline
          evb
          Hi, receiving an upvote on a relatively old topic of mine, did remember me that this information could help others searching to build a MQTT gateway with a RFM69 radio, a W5100 Ethernet shield and a simple Arduino UNO R3.
          https://forum.mysensors.org/topic/10358/solved-mqtt-gateway-based-on-arduino-uno-uno-compatible-w5100-ethernet-shield-rfm69hw-radio
          People starting with MySensors, normally read as first step, the documentation available.
          Every open source project is structurally a bit different and sometimes it is difficult to know how to contribute to the project.
          For example, the open source project HomeAssistant (a possible controller for MySensors) uses a standard git repository for its documentation where anyone can make a pull request with their contribution. The moderators then review each contribution and either accept it or not. You have the official documentation and the 'user guides' documentation.
          @mfalkvidd, maybe a workflow to consider? It can help to keep the documentation up to date faster and assess contributions better and faster.
          Most open source projects run on volunteers who spend their free time on these projects, so I'm happy to return some knowledge.
          In the meantime, I've learned here and realized that under every documentation page, there is a forum topic.
          Unfortunately, documentation is usually not really up to date and the topic can be very long. Very hard to read for beginners. :-(
          That's why I created some forum topics with my first steps in the Mysensors world to overcome some outdated documentation. But of course these are hard to find among all the other topics and if you don't know anything about their existence, it's even harder.
          And like everything, my topic is also already outdated, because, if I am correct, today a W5200 Ethernet shield is existing...
          (for your information, my mqtt gateway is still alive and kicking ;-) )
          • T Offline
            T Offline
            tssk
            wrote on last edited by tssk
            #65
            Does anyone know if it would be possible to add static information that would be available over HTTP (default port 80)?
            My idea is to put some kind of description/useful information in the MQTT GW itself. So in case Controller fails. There is some information resource what is the purpose, functionality and how to use it in some limited/emergency way eg. from phone or any computer.
            EDIT: Thinking of it - it might also provide some kind of configuration interface...
            fritsF 1 Reply Last reply
            • T tssk
              fritsF Offline
              fritsF Offline
              frits
              @tssk Nice idea! This should work, at the cost of some other feature which doesn't fit into ATMega's flash anymore.
              Here's my gateway:
              #define BUILD_MQTT_GATEWAY // either build mqtt gateway or ethernet gateway
              // #define USE_SIGNING
              #define MY_RADIO_RF24
              // #define MY_RADIO_RFM69
              #define WEBFRONTEND // provide a webfrontend at port 80 that shows gateway config
              #define SN "MySensors W5100 Gateway"
              #define SV "0.2"
              #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mysgw1-out"
              #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mysgw1-in"
              #define MY_MQTT_CLIENT_ID "mysgw1"
              #define MY_MQTT_CONTROLLER_IP_ADDRESS 192, 168, 99, 20
              #define MY_MQTT_PORT 1883
              #define MY_MYSGW_PORT 5003
              #define MY_IP_ADDRESS 192,168,99,13
              #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBA, 0xBE, 0x99, 0x13
              #define MY_SIGNING_ATSHA204_PIN 17
              #define MY_RFM69_NETWORKID (200)
              #define MY_RFM69_TX_POWER_DBM 20
              #define MY_SERIALDEVICE Serial
                #define MY_SOFTSPI
                #define MY_SOFT_SPI_SCK_PIN (14)
                #define MY_SOFT_SPI_MISO_PIN (16)
                #define MY_SOFT_SPI_MOSI_PIN (15)
              #ifdef MY_RADIO_RF24
                #define MY_RF24_CE_PIN (5)
                #define MY_RF24_CS_PIN (6)
              #elif defined MY_RADIO_RFM69
                #define MY_IS_RFM69HW
                #define MY_RFM69_NEW_DRIVER
                #define MY_RF69_SPI_CS (14)
              #else
                #error "only rfm24 or rf69 supported"
              #ifdef BUILD_MQTT_GATEWAY
                #define MY_PORT MY_MQTT_PORT
                #define MY_CONTROLLER_IP_ADDRESS MY_MQTT_CONTROLLER_IP_ADDRESS
              #else
                #define MY_GATEWAY_W5100
                #define MY_PORT MY_MYSGW_PORT
              #ifdef USE_SIGNING
                #define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
              void printIpAddress ( Stream &s, uint8_t a, uint8_t b, uint8_t c, uint8_t d )
                s.print ( a );
                s.print ( "." );
                s.print ( b );
                s.print ( "." );
                s.print ( c );
                s.print ( "." );
                s.print ( d );
              void printMacAddress ( Stream &s, uint8_t a, uint8_t b, uint8_t c, uint8_t d, uint8_t e, uint8_t f )
                s.print ( a, HEX );
                s.print ( ":" );
                s.print ( b, HEX );
                s.print ( ":" );
                s.print ( c, HEX );
                s.print ( ":" );
                s.print ( d, HEX );
                s.print ( ":" );
                s.print ( e, HEX );
                s.print ( ":" );
                s.print ( f, HEX );
              void printConfig ( Stream &s, char * lineBreak )
                s.print ( F ( "***********************************************" ) );
                s.print ( lineBreak );
                s.print ( SN );
                s.print ( "Version " );
                s.print ( SV );
                s.print ( F("own mac address: ") );
                printMacAddress ( s, MY_MAC_ADDRESS );
                s.print ( F("own network address: ") );
                printIpAddress ( s, MY_IP_ADDRESS );
                  s.print ( F("Gateway type: mqtt" ) );
                  s.print ( F ( "mqtt controller address: " ) );
                  printIpAddress ( s, MY_CONTROLLER_IP_ADDRESS );
                  s.print ( F ( "mqtt controller port: " ) );
                  s.print ( MY_MQTT_PORT );
                  s.print ( F ( "mqtt client id: " ) );
                  s.print ( MY_MQTT_CLIENT_ID );
                  s.print ( F ( "mqtt publish prefix: " ) );
                  s.print ( MY_MQTT_PUBLISH_TOPIC_PREFIX );
                  s.print ( F ( "mqtt subscribe prefix: " ) );
                  s.print ( MY_MQTT_SUBSCRIBE_TOPIC_PREFIX );
              #else
                  s.print ( F ( "Gateway type: MysGW" ) );
                  s.print ( F ( "network port: " ) );
                  s.print ( MY_MYSGW_PORT );
                s.print ( F ( "Radio type: " ) );
                  s.print ( F ( "NRF24" ) );
                  s.print ( F (  "RFM69" ) );
                  s.print ( F ( "network id: " ) );
                  s.print ( MY_RFM69_NETWORKID );
              #else
                  s.print ( F ( "bad radio defined" ) );
                s.print ( F ( "signing: " ) );
              #ifdef USE_SIGNING
                  s.print ( "yes" );
              #else
                  s.print ( "no" );
              #include <Ethernet.h>
              #ifdef WEBFRONTEND
                byte mac[] = { MY_MAC_ADDRESS };
                IPAddress ip ( 192,168,99,13 );
                EthernetServer server ( 80 );
                uint32_t enter = hwMillis();
                while (hwMillis() - enter < (uint32_t)500);
                while(!MY_SERIALDEVICE); // For USB enabled devices, wait for USB enumeration before continuing
                printConfig( MY_SERIALDEVICE, "\n" );
              #ifdef WEBFRONTEND
                Ethernet.begin(mac, ip);
              void presentation() { }
              #ifdef WEBFRONTEND
                // listen for incoming clients
                EthernetClient client = server.available();
                if (client) {
                  Serial.println("new client");
                  // an http request ends with a blank line
                  boolean currentLineIsBlank = true;
                  while (client.connected()) {
                    if (client.available()) {
                      char c = client.read();
                      Serial.write(c);
                      // if you've gotten to the end of the line (received a newline
                      // character) and the line is blank, the http request has ended,
                      // so you can send a reply
                      if (c == '\n' && currentLineIsBlank) {
                        // send a standard http response header
                        client.println("HTTP/1.1 200 OK");
                        client.println("Content-Type: text/html");
                        client.println("Connection: close");  // the connection will be closed after completion of the response
                        client.println();
                        client.println("<!DOCTYPE HTML>");
                        client.println("<html>");
                        printConfig ( client, "<br />" );
                        client.println("</html>");
                        break;
                      if (c == '\n') {
                        // you're starting a new line
                      } else if (c != '\r') {
                        // you've gotten a character on the current line
                        currentLineIsBlank = false;
                  // give the web browser time to receive the data
                  delay(1);
                  // close the connection:
                  client.stop();
                  Serial.println("client disconnected");
              It will deliver this website to the browser:
              Version 0.2
              own mac address: DE:AD:BA:BE:99:13
              own network address: 192.168.99.13
              Gateway type: mqtt
              mqtt controller address: 192.168.99.20
              mqtt controller port: 1883
              mqtt client id: mysgw1
              mqtt publish prefix: mysgw1-out
              mqtt subscribe prefix: mysgw1-in
              Radio type: NRF24
              signing: no
              T 1 Reply Last reply
              • fritsF frits
                Here's my gateway:
                #define SV "0.2"
                  #define MY_SOFTSPI
                #else
                #else
                #ifdef USE_SIGNING
                  s.print ( a );
                  s.print ( "." );
                  s.print ( b );
                  s.print ( "." );
                  s.print ( c );
                  s.print ( "." );
                  s.print ( d );
                  s.print ( a, HEX );
                  s.print ( ":" );
                  s.print ( b, HEX );
                  s.print ( ":" );
                  s.print ( c, HEX );
                  s.print ( ":" );
                  s.print ( d, HEX );
                  s.print ( ":" );
                  s.print ( e, HEX );
                  s.print ( ":" );
                  s.print ( f, HEX );
                  s.print ( SN );
                  s.print ( SV );
                #else
                #else
                #ifdef USE_SIGNING
                    s.print ( "yes" );
                #else
                    s.print ( "no" );
                #ifdef WEBFRONTEND
                #ifdef WEBFRONTEND
                #ifdef WEBFRONTEND
                  if (client) {
                        Serial.write(c);
                          client.println();
                          break;
                        if (c == '\n') {
                    delay(1);
                    client.stop();
                Version 0.2
                Gateway type: mqtt
                Radio type: NRF24
                signing: no
                T Offline
                T Offline
                tssk
                @frits Cool! So you already had this?
                I was exactly thinking of using most simple HTTP server example from Arduino examples (although you have it nicely dynamic using the defines etc.). But I was not sure if it would not interfere with mysensors library in some way or if maybe mysensors already had such functionality build-in (because if I remember correctly Ethernet gateway return some data to browser of you call the 5003 port).
                • fritsF Offline
                  fritsF Offline
                  frits
                  @tssk said in 💬 Building a MQTT Gateway:
                  no, not as a webserver. I only print some node information to Serial.
                  Webserver seems to work and not to interfere with mysensors core. My (MQTT-)Gateway doesn't act as a server, so there's only one listener. But multiple listeners (webserver on port 80 and Ethernet Gateway on port 5003 for example) should also be possible. I've not tested this though.
                  • L Offline
                    L Offline
                    linkinpio
                    I'm new here so sorry if this is not the right place for this question.
                    But I am trying to build Arduino MQTT GW to act as a relay/light controller and report/interact with HomeAssistant.
                    I think I have worked out most of my problems and got it running as I wanted to, but I was testing failover senarios as the controller should be able to work independently of any other device as long it has power.
                    My config is kind of simple Arduino Mega with W5500 Ethernet module configured as MQTT GW
                    And the problem is that when network or HA/MQTT broker is unavailable when Arduino is restarted/booting it tries to reconnect to MQTT broker constantly and interupts the main loop everytime for around 3s which makes board basically unresponsive.
                    00:45:07.094 -> 549536 !GWT:RMQ:FAIL
                    00:45:07.094 -> Loop count = 179
                    00:45:07.094 -> 549538 GWT:TPC:IP=192.168.11.111
                    00:45:08.107 -> 550542 GWT:RMQ:CONNECTING...
                    00:45:10.130 -> 552547 !GWT:RMQ:FAIL
                    00:45:10.130 -> Loop count = 180
                    00:45:10.130 -> 552550 GWT:TPC:IP=192.168.11.111
                    Any ideas how I could disable reconnect function if that happens for example after 3 attempts? So the controller can work normally even if there is no connection to MQTT broker?
                    OldSurferDudeO electrikE 2 Replies Last reply
                    • L linkinpio
                      OldSurferDudeO Offline
                      OldSurferDude
                      @linkinpio
                      I don't have a solution, but I, too, may run into that problem. So I'm curious how it can be resolved.
                      Perhaps post in the Hardware or Development sections. Fortunately, some really knowledgeable people (eg. @mfalkvidd and @NeverDie ) monitor pretty much all of the forum subjects.
                      OSD
                      • L linkinpio
                        electrikE Offline
                        electrikE Offline
                        electrik
                        @linkinpio in the pubsubclient library, you can change the timeout on connecting to the mqtt broker. Default it is 15s, reducing it to e.g. 2s will increase the availability of the main loop.
                        L 1 Reply Last reply
                        • OldSurferDudeO OldSurferDude
                          @linkinpio
                          OSD
                          #72
                          @OldSurferDude yes I have read it already. But unfortunately my impression is that my knowledge of how the code works is woefully insufficient.
                          • electrikE electrik
                            L Offline
                            L Offline
                            linkinpio
                            @electrik thank you for your suggestion, but are you talking about MQTT_SOCKET_TIMEOUT ?
                            If yes I did set this to 1s
                            #define MQTT_SOCKET_TIMEOUT 1
                            and did not change a thing
                            21:32:05.081 -> Loop count = 153
                            21:32:05.081 -> 471258 GWT:TPC:IP=192.168.11.111
                            21:32:06.098 -> 472262 GWT:RMQ:CONNECTING...
                            21:32:08.071 -> 474266 !GWT:RMQ:FAIL
                            21:32:08.071 -> Loop count = 154
                            If not please do let me know what you had in mind so I can check it out.
                            @OldSurferDude thanks for confirming that I have not missed anything when doing a resarch on this matter, if there will be no new suggestions I think I might have to post it to Development as dont see anyone suggesting any good workaround or a solution.
                            • electrikE Offline
                              electrikE Offline
                              electrik
                              No, you're right, it doesn't solve your issue. It does increase the availability of the main loop though.
                                L Offline
                                L Offline
                                linkinpio
                                @electrik
                                Have you tested this in your enviroment/sketch?
                                Did it increase availability for your sketch?
                                If yes what was the single loop time before and after changing this?
                                I did test is on my example and it does not increase the availability for the main loop for my sketch, also you can see the printout from the serial monitor, the loop is run in the same 3s intervals like before, so maybe I am doing something wrong?
                                • electrikE Offline
                                  electrikE Offline
                                  electrik
                                  Yes, that's what I meant. But the value seems to be 2 seconds in your log. Where have you placed the define?
                                  You can also use
                                  setSocketTimeout(1)
                                  On the pubsubclient object.
                                    You can also use
                                    setSocketTimeout(1)
                                    L Offline
                                    L Offline
                                    linkinpio
                                    @electrik I've put the
                                    in the beginning where all other #defined constants are and it does not seeams to take this config.
                                    I tried to use
                                    setSocketTimeout(1)
                                    but I can't seems to get the sketch to work with <PubSubClient.h>
                                    I've added
                                    EthernetClient ethClient;
                                    PubSubClient client(ethClient);
                                    client.setSocketTimeout(1);
                                    but getting following error.
                                    GatewayW5x00MQTTClient.ino:172:1: error: 'client' does not name a type
                                    exit status 1
                                    Compilation error: 'client' does not name a type
                                    any ideas?
                                    • electrikE Offline
                                      electrikE Offline
                                      electrik
                                      @linkinpio said in 💬 Building a MQTT Gateway:
                                      That is the right syntax, but you have to move the line in setup()
                                        L Offline
                                        L Offline
                                        linkinpio
                                        @electrik
                                        tried it but also no luck
                                        C:\Users\p.\Documents\Arduino\GatewayW5x00MQTTClient\GatewayW5x00MQTTClient.ino: In function 'void setup()':
                                        C:\Users\p.\Documents\Arduino\GatewayW5x00MQTTClient\GatewayW5x00MQTTClient.ino:213:10: error: 'class PubSubClient' has no member named 'setSocketTimeout'
                                        exit status 1
                                        Compilation error: 'class PubSubClient' has no member named 'setSocketTimeout'```
                                        • electrikE Offline
                                          electrikE Offline
                                          electrik
                                          This looks like you're not using the latest (development) version of the mysensors library. That has the latest pubsubclient library included.
                                          Looking at the intervals between the errors again, I'm doubtful if it will make a big difference though. The mysensors library will need to be modified to fulfill your request I guess
