  2. Announcements
1.1k Posts 173 Posters 1.5m Views 131 Watching
  • H hawtcher
    Is it possible to have the RPi4B, that is being used as the Webthings Gateway, also be the My Sensor controller once I add a NRF24L01+ module and follow steps above?
    H
    H
    hawtcher
    To clarify, I have the Mozilla Webthings Controller and I want to know if I can use the instructions above to make the same RPi4B to be the MySensors gateway. Any help would be greatly appreciated.
    • I
      I
      iguaan
      In case someone has similar issue:
      Running everything latest up to date.
      Raspberry pi zero w with nrf24 connected directly on GPIO and domoticz. Had to have startup delay on mysgw service since domoticz wouldn't or couldn't start automatically on boot.
      So i added to:
      sudo nano /etc/systemd/system/mysgw.service
      [Service]
      ExecStartPre=/bin/sleep 10
      Maybe 10 seconds is overkill, but at least it works now.
      With raspberry pi 3b+ there wasn't that issue.
      Also in domoticz had to use raspi ip address, when setting up mysensors LAN gateway address, instead of localhost 127.0.0.1
      And myscontroller OTA updates are working too.🙂
      • OldSurferDudeO
        OldSurferDudeO
        OldSurferDude
        #1063
        I'm new to MySensors. I'm trying to build an MQTT gateway with an nRF24 radio on my RPi 3B+. I follow the instructions here,
        My radio is connected with CE on physical pin 15 (GPIO22) and CSN on physical pin 24 (GPIO8) I am confident this works has I was able to run the tMRH20 examples
        I follow the instructions here on this web page
        I configured with:
        ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=rf24
        I run make but quickly error with "missing stropts.h" for which I found a fix "sudo touch /usr/include/stropts.h". I run make again after a many warnings it stops with Error 1. The last few lines:
        re/Linux/drivers/core/compatibility.o build/hal/architecture/Linux/drivers/core/EthernetClient.o build/hal/architecture/Linux/drivers/core/EthernetServer.o build/hal/architecture/Linux/drivers/core/GPIO.o build/hal/architecture/Linux/drivers/core/interrupt.o build/hal/architecture/Linux/drivers/core/IPAddress.o build/hal/architecture/Linux/drivers/core/noniso.o build/hal/architecture/Linux/drivers/core/Print.o build/hal/architecture/Linux/drivers/core/SerialPort.o build/hal/architecture/Linux/drivers/core/SoftEeprom.o build/hal/architecture/Linux/drivers/core/SPIDEV.o build/hal/architecture/Linux/drivers/core/StdInOutStream.o build/hal/architecture/Linux/drivers/core/Stream.o build/examples_linux/mysgw.o build/hal/architecture/Linux/drivers/BCM/bcm2835.o build/hal/architecture/Linux/drivers/BCM/BCM.o build/hal/architecture/Linux/drivers/BCM/RPi.o build/hal/architecture/Linux/drivers/BCM/SPIBCM.o build/hal/architecture/Linux/drivers/BCM/Wire.o
        /usr/bin/ld: build/examples_linux/mysgw.o: in function `.LANCHOR1':
        /home/appian3344/MySensors/./hal/architecture/Linux/drivers/core/config.h:39: multiple definition of `conf'; build/hal/architecture/Linux/drivers/core/config.o:/home/appian3344/MySensors/hal/architecture/Linux/drivers/core/config.h:39: first defined here
        collect2: error: ld returned 1 exit status
        make: *** [Makefile:80: bin/mysgw] Error 1
        OK, what didn't I do right?
        • OldSurferDudeO OldSurferDude
          I configured with:
          @OldSurferDude loos like it could be the same problem as https://github.com/mysensors/MySensors/pull/1454
          In that case, applying the suggested fix manually, or using the development branch (where the fix is already included) should work.
          OldSurferDudeO 1 Reply Last reply
            OldSurferDudeO
            OldSurferDudeO
            OldSurferDude
            @mfalkvidd I implemented your suggestion of running the development branch. This didn't work for a different reason. Below my questions is what I did.
            Questions:
            o Is the gateway trying to connect to a controller such as Home Assistant (HA)?
            o The IP address of 127.0.0.1 implies the controller is on the same machine. Would the gateway connect to a docker containerized HA?
            o What example programs will connect to the RF24 radio side of the gateway? We could start off with a simple ONoff switch and progress to that node controlling a relay on another node. (passing the request through an MQTT broker?)
            o Note that I made the assumption that the gateway doesn't distinguish between wired ethernet or WiFi. Is that a good assumption?
            Hardware RPi 3B+, nRF24 wired with CE to physical pin 15
            OS: Raspbian GNU/Linux 11 (bullseye)
            It is assumed that deleting the MySensors folder will uninstall the existing master branch. (probably a bad assumption)
            1. sudo rm -r MySensors
            2. git clone https://github.com/mysensors/MySensors.git --branch development
            3. cd MySensors
            4. ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=rf24
              note: It is stated that the default configuration is ethernet port 5003 (./configure --my-gateway=ethernet --my-port=5003)
              It is assumed that the software doesn't distinguish between ethernet and WiFi
            5. make
              many compiler warnings
            6. Start gateway with
              sudo ./bin/mysgw
              which results in:
              Apr 04 12:12:37 INFO Config file /etc/mysensors.conf does not exist, creating new file.
              Apr 04 12:12:37 INFO Starting gateway...
              Apr 04 12:12:37 INFO Protocol version - 2.4.0-alpha
              Apr 04 12:12:37 INFO EEPROM file /etc/mysensors.eeprom does not exist, creating new file.
              Apr 04 12:12:37 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
              Apr 04 12:12:37 DEBUG TSF:LRT:OK
              Apr 04 12:12:37 DEBUG TSM:INIT
              Apr 04 12:12:37 DEBUG TSF:WUR:MS=0
              Apr 04 12:12:37 DEBUG TSM:INIT:TSP OK
              Apr 04 12:12:37 DEBUG TSM:INIT:GW MODE
              Apr 04 12:12:37 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
              Apr 04 12:12:37 DEBUG MCO:REG:NOT NEEDED
              Apr 04 12:12:37 DEBUG MCO:BGN:STP
              Apr 04 12:12:37 DEBUG MCO:BGN:INIT OK,TSP=1
              followed by repeating:
              Apr 04 12:12:37 DEBUG GWT:RMQ:CONNECTING...
              Apr 04 12:12:37 ERROR connect: Connection refused
              Apr 04 12:12:37 ERROR failed to connect
              Apr 04 12:12:38 DEBUG !GWT:RMQ:FAIL
              Apr 04 12:12:38 DEBUG TSM:READY:NWD REQ
              Apr 04 12:12:40 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            Assumed that it failed to connect to an MQTT broker and the my-controller-ip-address is a broker address
            Changed the --my-controller-ip-address to that of my MQTT broker (It is assumed that the default MQTT port is used)
            repeat step 4. with the change and step 5. and 6.
            no joy same output
            Restarted with step 1 with changes
            no joy same output
            E 1 Reply Last reply
              @OldSurferDude said in 💬 Building a Raspberry Pi Gateway:
              Yes, a controller or a mqtt broker.
              I think it depends on how the docker is set up, but I don't have enough knowledge about docker to say for sure.
              You could build any of the nodes on the build page, or use https://github.com/mysensors/MySensors/tree/development/examples/MockMySensors or just create a local sensor on the gateway (if you don't need to test the nrf24 communication).
              In the case of the Raspberry Pi gateway yes. It will use the Pi's networking, regardless of type.
                Questions:
                3. cd MySensors
                5. make
                  sudo ./bin/mysgw
                  which results in:
                no joy same output
                no joy same output
                E
                E
                ejlane
                @OldSurferDude I don't see a password in your configure settings. Since it is saying that the connection is refused from your MQTT broker, that was the first thing that popped out to me. Do you have access control set up on the broker? I'm assuming that you have the IP address and port set up correctly.
                I'm not sure if there would be a different message for other things, but when I had the access control on and messed up the username or password it would tell me connection refused or at least something very similar.
                • E ejlane
                  OldSurferDudeO
                  OldSurferDudeO
                  OldSurferDude
                  @ejlane @mfalkvidd
                  I installed an MQTT broker on another linux machine. I did not set up access control(username, password) If I install mosquitto-clients I can pub/sub to the broker without username and password. In addition, on my windows box, I installed MQTT Explorer and can monitor the broker, again without username and password. (should I specify --my-mqtt-user="" and --my-mqtt-password=""?)
                  I have HA on the RPi. I can access it on my windows box with http://192.168.sss.sss:8123. It requires a user password. but I don't see any parameter that refers to a password for an ethernet controller.
                  I'll try those programs, but first I think I need to get MySensors working.
                  Has anyone developed a cookbook? http://tmrh20.github.io/ has many examples of using the RF24 with combinations of RPi and Arduinos. These examples start with very basic connection to very complex. I built a for Arduino Nodes, 1 RPi master system that has been running well for two years. But I decided I need MQTT to exchange data with other devices. Alas, the MQTT client example works, but the computational load on the Arduino was too much and therefore unusable.
                  I'm looking to MySensors because it appears that the computational load for sensor nodes is tolerable. and it appears to have an MQTT gateway.
                  Cookbook? working examples?
                    @ejlane @mfalkvidd
                    OldSurferDudeO
                    OldSurferDudeO
                    OldSurferDude
                    @ejlane @mfalkvidd
                    A bit more thrashing and found that I would need an integration set up on HA.
                    I tried a TCP connection and HA could not connect. I then then set up a TCP configuration on MS (./configure --my-transport=rf24 --my-gateway=ethernet --my-controller-ip-address=127.0.0.1) and while it was streaming error messages, I tried to connect HA.
                    The I tried an HA/MS connecting using MQTT at address 127.0.0.1 but HA failed to connect (you have to install the HA MQTT integration before installing the HA MS integration.) With the same ip address on the MS configuration (./configure --my-transport=rf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1) still failed to connect,
                    Some joy was found when I set the ip address to that of my MQTT broker. Neither HA nor MS reported any error messages.
                    OK, now onto the Arduino side of things.
                    OSD
                      @ejlane @mfalkvidd
                      OSD
                      OldSurferDudeO
                      OldSurferDudeO
                      OldSurferDude
                      @ejlane @mfalkvidd
                      On the RPi: MySensors and running HA in a docker container. Another linux box is running the MQTT broker. MQTT Explorer is running on a windows PC.
                      MySensors has the configuration: (./configure --my-transport=rf24 --my-gateway=mqtt --my-controller-ip-address=192,.168.sss.sss --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1) where 192,.168.sss.sss is the ip address of my MQTT broker
                      HA has the integration of MQTT: ip 192,.168.sss.sss; sub mysensors-out pub mysensors-in and MySensors is configure to MQTT.
                      HA can send to, and receive from, the broker. This was determined by the MQTT Explorer.
                      For my Arduino program I took the relay example with button. My Arduino is a RF-NANO so I had to add the pointers to the CE and CSN
                      #define MY_RF24_CS_PIN 9
                      #define MY_RF24_CE_PIN 10
                      The Arduino doesn't seem to send to the broker. See messages below messages, and MS doesn't seem to be receiving them (see below, below)
                      OK, why isn't the status of the switch being received by MS and passed onto the MQTT broker:
                      Repeating Arduino output
                      36190 ?TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      38197 !TSM:FPAR:NO REPLY
                      38199 TSM:FPAR
                      38203 ?TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      40211 !TSM:FPAR:NO REPLY
                      40213 TSM:FPAR
                      40217 ?TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      42225 !TSM:FPAR:NO REPLY
                      42227 TSM:FPAR
                      42231 ?TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      44239 !TSM:FPAR:FAIL
                      44240 TSM:FAIL:CNT=3
                      44242 TSM:FAIL:DIS
                      44244 TSF:TDI:TSL
                      54248 TSM:FAIL:RE-INIT
                      54250 TSM:INIT
                      54256 TSM:INIT:TSP OK
                      54258 TSF:SID:OK,ID=11
                      54260 TSM:FPAR
                      Output from mysgw:
                      sudo bin/mysgw
                      Apr 07 19:35:16 INFO Starting gateway...
                      Apr 07 19:35:16 INFO Protocol version - 2.4.0-alpha
                      Apr 07 19:35:16 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
                      Apr 07 19:35:16 DEBUG TSF:LRT:OK
                      Apr 07 19:35:16 DEBUG TSM:INIT
                      Apr 07 19:35:16 DEBUG TSF:WUR:MS=0
                      Apr 07 19:35:16 DEBUG TSM:INIT:TSP OK
                      Apr 07 19:35:16 DEBUG TSM:INIT:GW MODE
                      Apr 07 19:35:16 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                      Apr 07 19:35:16 DEBUG MCO:REG:NOT NEEDED
                      Apr 07 19:35:16 DEBUG MCO:BGN:STP
                      Apr 07 19:35:16 DEBUG MCO:BGN:INIT OK,TSP=1
                      Apr 07 19:35:16 DEBUG GWT:RMQ:CONNECTING...
                      Apr 07 19:35:16 DEBUG connected to 192.168.1.142
                      Apr 07 19:35:16 DEBUG GWT:RMQ:OK
                      Apr 07 19:35:16 DEBUG GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                      Apr 07 19:35:16 DEBUG TSM:READY:NWD REQ
                      Apr 07 19:35:17 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      Apr 07 19:50:16 DEBUG TSF:SAN:OK
                      Apr 07 19:55:16 DEBUG TSM:READY:NWD REQ
                      Apr 07 19:55:17 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      Apr 07 20:05:16 DEBUG TSF:SRT:OK
                      Apr 07 20:05:16 DEBUG TSF:SAN:OK
                        @ejlane @mfalkvidd
                        38199 TSM:FPAR
                        40213 TSM:FPAR
                        42227 TSM:FPAR
                        44242 TSM:FAIL:DIS
                        44244 TSF:TDI:TSL
                        54250 TSM:INIT
                        54260 TSM:FPAR
                        Output from mysgw:
                        sudo bin/mysgw
                        E
                        E
                        ejlane
                        @OldSurferDude It looks like your gateway is set to send to the wrong topic? In the debug log it looks like the gateway is sending to the 'out' topic, while you mentioned that that was output from mysensors. But in your text you said you had it set the other way, so ??
                        I don't have a system set up with MQTT now. I used it for a while, but got tired of having to remember to update the RPi that was doing the gateway work. I kept letting it get way out of date and that's a bit of a security issue. So I switched to a serial port connection that's powered by the HA server and plugged into a USB port from it.
                        But have you used the log parser? https://www.mysensors.org/build/parser
                        It can help a ton with understanding all the messages that you're getting.
                        But double check your topic settings is the only idea I have right now after seeing those log messages. It looks like the gateway sent to the 'out' topic, rather than just listening to it.
                        • E ejlane
                          OldSurferDudeO
                          OldSurferDudeO
                          OldSurferDude
                          @ejlane
                          I saw the log parser. Like the last comment in log parser, my output doesn't work with it. :(
                          I discovered my problem, and this has always be a challenge. I had the RF24 CE connected to RPi(physical15/GPIO22). When I changed it over to (physical22/GPIO24) there were no error messages.
                          Thanks for noting the in-out issue. I'm dyslexic so that's always a tough one for me. I made the assumption that, like serial, TX goes to RX and RX to TX, but then, I could have screwed that up, too. Now I'm really confused! But then, it's only "two wires" to swap.
                          Thanks for your help.
                            @ejlane
                            E
                            E
                            ejlane
                            @OldSurferDude :+1: :+1: :+1:
                            Glad to hear that you got it working!
                            • B
                              B
                              badisensors
                              Hello. I had built the Rpi gateway serial and it was working fine in core installation in homeassistant. Now i decided to make installation of homeassistant in docker and although i map the port as dev/ttyUSB020:/dev/ttyUSB020 it is impossible to connect in gateway. The gateway is starting fine and create the port /dev/ttyUSB020. Maybe its something to do with pty option in gateway? My configuration is ./configuration --my-transport=rf24 --my-gateway=serial --my-serial-is-pty --my-serial-port=/dev/ttyUSB020 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-rf24-irq-pin=15
                              How do you think i can fix it?
                              monteM 1 Reply Last reply
                              • B badisensors
                                monteM
                                monteM
                                monte
                                @badisensors try ethernet gateway instead of serial. You won't need to pass anything to docker and it works just fine.
