  2. Announcements
  3. 💬 Dimmable LED Actuator
59 Posts 27 Posters 31.0k Views 27 Watching
  • J jeti
    so this works now like a charm:
    #define MY_NODE_ID 153
    #define SN "MultiDimmableLED"
    #define SV "1.1"
    #define noLEDs 3
    const int LED_Pin[] = {3, 5, 6};
    #define FADE_DELAY 25  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    static int currentLevel = 0;  // Current dim level...
    MyMessage dimmerMsg(noLEDs, V_DIMMER);
    MyMessage lightMsg(noLEDs, V_LIGHT);
     * Dimmable LED initialization method
      // not sure this works
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
    for (int sensor=1; sensor<=noLEDs; sensor++){
      request( sensor, V_DIMMER );
    void presentation() {
     present(sensor, S_DIMMER);
     wait(2);
      sendSketchInfo(SN, SV);
     *  Dimmable LED main processing loop
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
        requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
        // Clip incoming level to valid range of 0 to 100
        Serial.print( "Changing LED " );
        Serial.print(message.sensor);
        Serial.print(", PIN " );
        Serial.print( LED_Pin[message.sensor] );
        Serial.print(" level to " );
        Serial.print( ", from " );
        Serial.println( currentLevel );
        fadeToLevel( requestedLevel, message.sensor );
        send(lightMsg.set(currentLevel > 0 ? 1 : 0));
        // hek comment: Is this really nessesary?
        send( dimmerMsg.set(currentLevel) );
     *  This method provides a graceful fade up/down effect
    void fadeToLevel( int toLevel, int ledid ) {
      int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
      while ( currentLevel != toLevel ) {
        currentLevel += delta;
        analogWrite(LED_Pin[ledid-1], (int)(currentLevel / 100. * 255) );
        wait( FADE_DELAY );
    thank you :thumbsup:
    PlantexP Offline
    PlantexP Offline
    Plantex
    wrote on last edited by Plantex
    #41
    This post is deleted!
    • I Offline
      I Offline
      itbeyond
      Ah I have just built a test bed with this setup however it appears the circuit diagram in the Fritizing is actually not 100% correct. The red wire from the protoboard is connected to the GND of the Pro Mini - this confused me as I was using the GND/RAW pins to identify the cable color. If you flip the red/blue connections on the Pro Mini it will be right. Small issue I know but I had to reference another image to get the circuit to work.
      • K Offline
        K Offline
        KoenP
        Hi Folks,
        I have build this in combination with a ethernet gateway. Works perfect, however, when for whatever reason the network fails, I cannot control my lights anymore.
        Is there a possibilty toi have it working also "stand alone" when the network fails?
        Grtz.
        KoenP
        • vladimirV Offline
          vladimirV Offline
          vladimir
          Hi all!
          I'm using OpenHAB 2, and I have some problems with the sketch code "DimmableLightWithRotaryEncoderButton".
          1. When the encoder button is pressed, the switch in OpenHAB does not respond.
          2. When you turn the encoder knob one step, the value changes in two steps.
          Maybe you have encountered such a problem? Or maybe you can share a more modern sketch?
          • vladimirV vladimir
            Hi all!
            In case anyone can help @vladimir, please post in https://forum.mysensors.org/post/93111 so we keep the discussion focused in one place.
            • vladimirV Offline
              vladimirV Offline
              vladimir
              Does anyone use this sketch "DimmableLightWithRotaryEncoderButton"? I take it from the site (https://www.mysensors.org/build/dimmer) and it does not work with OpenHAB 2.
              • M Offline
                M Offline
                mateos78
                does anyone have working sketch -> DimmableLightWithRotaryEncoderButton.ino with Mysensor USB under DOMOTICZ + Arduino ? unfortunatelly phisical button dosn't work (no switch on / off) and there is no feedbeck from domoticz to Arduino to set level of dim. I have been straggling with the sketch for weeks, but haven't figured out , how to fix it. Mybe something has changed since lat update od sketch... and sorry for my english I'm not a native speaker:)
                H 1 Reply Last reply
                • M mateos78
                  H Offline
                  H Offline
                  hard-shovel
                  @mateos78 See https://forum.mysensors.org/topic/9670/problem-with-dimmable-led-actuator-with-encoder/11
                  • M Offline
                    M Offline
                    mateos78
                    @hard-shovel I've already used this sketch, but still no feedback from domoticz to arduino (it does not dim) and the physical button doesn't work :( ehh...
                    • M Offline
                      M Offline
                      mateos78
                      wrote on last edited by mateos78
                      #50
                      here is what I use now->
                      As I can see When I change the dim level or click the switch in domoticz the yellow led on arduino blink but it changes nothing..
                       * Version 1.0 - Developed by Bruce Lacey and GizMoCuz (Domoticz)
                       * Version 1.1 - Modified by hek to incorporate a rotary encode to adjust
                       *                                light level locally at node
                       * This sketch provides an example how to implement a dimmable led light node with a rotary
                       * encoder connected for adjusting light level.
                       * The encoder has a click button which turns on/off the light (and remembers last dim-level)
                       * The sketch fades the light (non-blocking) to the desired level.
                       * Default MOSFET pin is 3
                       *  Arduino      Encoder module
                       *  5V           5V (+)
                       *  GND          GND (-)
                       *  4            CLK (or putput 1)
                       *  5            DT  (or output 1)
                       *  6            SW (Switch/Click)
                      //#define MY_RADIO_NRF24
                      // Enable debug prints
                      #define MY_GATEWAY_SERIAL
                      #define MY_INCLUSION_MODE_BUTTON_PIN 8
                      #include <Bounce2.h>
                      #include <Encoder.h>
                      #define LED_PIN 3           // Arduino pin attached to MOSFET Gate pin
                      #define KNOB_ENC_PIN_1 4    // Rotary encoder input pin 1
                      #define KNOB_ENC_PIN_2 5    // Rotary encoder input pin 2
                      #define KNOB_BUTTON_PIN 6   // Rotary encoder button pin
                      #define FADE_DELAY 10       // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                      #define SEND_THROTTLE_DELAY 400 // Number of milliseconds before sending after user stops turning knob
                      #define SN "DimmableLED /w button"
                      #define SV "1.3"
                      #define CHILD_ID_LIGHT 1
                      #define EEPROM_DIM_LEVEL_LAST 1
                      #define EEPROM_DIM_LEVEL_SAVE 2
                      #define LIGHT_OFF 0
                      #define LIGHT_ON 1
                      int dimValue;
                      int fadeTo;
                      int fadeDelta;
                      byte oldButtonVal;
                      bool changedByKnob=false;
                      bool sendDimValue=false;
                      unsigned long lastFadeStep;
                      unsigned long sendDimTimeout;
                      char convBuffer[10];
                      MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
                      MyMessage statusMsg(CHILD_ID_LIGHT, V_STATUS);    // Addition for Status update to OpenHAB Controller
                      Encoder knob(KNOB_ENC_PIN_1, KNOB_ENC_PIN_2);
                      Bounce debouncer = Bounce();
                        // Set knob button pin as input (with debounce)
                        pinMode(KNOB_BUTTON_PIN, INPUT);
                        digitalWrite(KNOB_BUTTON_PIN, HIGH);
                        debouncer.attach(KNOB_BUTTON_PIN);
                        debouncer.interval(5);
                        oldButtonVal = debouncer.read();
                        // Set analog led pin to off
                        analogWrite( LED_PIN, 0);
                        // Retreive our last dim levels from the eprom
                        fadeTo = dimValue = 0;
                        byte oldLevel = loadLevelState(EEPROM_DIM_LEVEL_LAST);
                        Serial.print("Sending in last known light level to controller: ");
                        Serial.println(oldLevel);
                        send(dimmerMsg.set(oldLevel), true);
                        Serial.println("Ready to receive messages...");
                        present(CHILD_ID_LIGHT, S_DIMMER);
                        // Check if someone turned the rotary encode
                        checkRotaryEncoder();
                        // Check if someone has pressed the knob button
                        checkButtonClick();
                        // Fade light to new dim value
                        fadeStep();
                          // Incoming on/off command sent from controller ("1" or "0")
                          int lightState = message.getString()[0] == '1';
                          int newLevel = 0;
                          if (lightState==LIGHT_ON) {
                            // Pick up last saved dimmer level from the eeprom
                            newLevel = loadLevelState(EEPROM_DIM_LEVEL_SAVE);
                          // Send dimmer level back to controller with ack enabled
                          send(dimmerMsg.set(newLevel), true);
                          // We do not change any levels here until ack comes back from gateway
                          return;
                        } else if (message.type == V_PERCENTAGE) {
                          // Incoming dim-level command sent from controller (or ack message)
                          fadeTo = atoi(message.getString(convBuffer));
                          // Save received dim value to eeprom (unless turned off). Will be
                          // retreived when a on command comes in
                          if (fadeTo != 0)
                            saveLevelState(EEPROM_DIM_LEVEL_SAVE, fadeTo);
                        saveLevelState(EEPROM_DIM_LEVEL_LAST, fadeTo);
                        Serial.print("New light level received: ");
                        Serial.println(fadeTo);
                        if (!changedByKnob)
                          knob.write(fadeTo<<1);             //### need to multiply by two (using Shift left)
                        // Cancel send if user turns knob while message comes in
                        changedByKnob = false;
                        sendDimValue = false;
                        // Stard fading to new light level
                        startFade();
                      void checkRotaryEncoder() {
                        long encoderValue = knob.read()>>1 ;      //### Divide by 2 (using shift right)
                        if (encoderValue > 100) {
                          encoderValue = 100;
                          knob.write(200);                        //### max value now 200 due to divide by 2
                        } else if (encoderValue < 0) {
                          encoderValue = 0;
                          knob.write(0);
                        if (encoderValue != fadeTo) {
                          fadeTo = encoderValue;
                          changedByKnob = true;
                          startFade();
                      void checkButtonClick() {
                        debouncer.update();
                        byte buttonVal = debouncer.read();
                        byte newLevel = 0;
                        if (buttonVal != oldButtonVal && buttonVal == LOW) {
                          if (dimValue==0) {
                            // Turn on light. Set the level to last saved dim value
                            int saved = loadLevelState(EEPROM_DIM_LEVEL_SAVE);
                            newLevel = saved > 1 ? saved : 100;           // newLevel = saved > 0 ? saved : 100;
                          send(dimmerMsg.set(newLevel),true);
                          send(statusMsg.set(newLevel>0 ? "1" : "0")); // Addition for Status update to OpenHAB Controller,   No Echo
                        oldButtonVal = buttonVal;
                      void startFade() {
                        fadeDelta = ( fadeTo - dimValue ) < 0 ? -1 : 1;
                        lastFadeStep = millis();
                      // This method provides a graceful none-blocking fade up/down effect
                      void fadeStep() {
                        unsigned long currentTime  = millis();
                        if ( dimValue != fadeTo && currentTime > lastFadeStep + FADE_DELAY) {
                          dimValue += fadeDelta;
                          analogWrite( LED_PIN, (int)(dimValue / 100. * 255) );
                          lastFadeStep = currentTime;
                          Serial.print("Fading level: ");
                          Serial.println(dimValue);
                          if (fadeTo == dimValue && changedByKnob) {
                            sendDimValue = true;
                            sendDimTimeout = currentTime;
                        // Wait a few millisecs before sending in new value (if user still turns the knob)
                        if (sendDimValue && currentTime > sendDimTimeout + SEND_THROTTLE_DELAY)  {
                           // We're done fading.. send in new dim-value to controller.
                           // Send in new dim value with ack (will be picked up in incomingMessage)
                          send(dimmerMsg.set(dimValue), true); // Send new dimmer value and request ack back
                      // Make sure only to store/fetch values in the range 0-100 from eeprom
                      int loadLevelState(byte pos) {
                        return min(max(loadState(pos),0),100);
                      void saveLevelState(byte pos, byte data) {
                        saveState(pos,min(max(data,0),100));
                      • M mateos78
                         *  5V           5V (+)
                         *  GND          GND (-)
                        #define SV "1.3"
                        #define LIGHT_OFF 0
                        #define LIGHT_ON 1
                        int dimValue;
                        int fadeTo;
                        int fadeDelta;
                        byte oldButtonVal;
                          checkButtonClick();
                          fadeStep();
                            int newLevel = 0;
                            return;
                            if (fadeTo != 0)
                          if (!changedByKnob)
                          startFade();
                            encoderValue = 100;
                            encoderValue = 0;
                            knob.write(0);
                            startFade();
                          debouncer.update();
                          byte newLevel = 0;
                            if (dimValue==0) {
                        void startFade() {
                        void fadeStep() {
                        H Offline
                        H Offline
                        hard-shovel
                        wrote on last edited by hard-shovel
                        #51
                        @mateos78
                        Attached is a sketch that i have just tried with domoticz (running on a windows test machine) It works fine when used as a node with a gateway. Encoder/ Switch and webpage slider/switch operating.
                        However when set up as a single gateway node as your sketch, only the encoder function works, you can vary the lamp level from the slider or the encoder, but the domaticz on/off or the button does not operate correctly. it seems to be the way the messages are acknowledged
                        I also find that when i change the led dimmer from the encoder the led changes quickly, but it take about ten seconds before the dormoticz web page updates to show each new slider position.
                        The following Sketch needs the #define OPENHAB2 defined for use with openhab and undefined for Dormoticz
                         *  5V           5V (+)
                         *  GND          GND (-)
                         *  For OpenHAB2  enable @define OPENHAB2
                         *  NOTE
                         *  PROBLEM:
                         *  Using as a Gateway Node With Dormoticz the SWITCH ON/OFF DOES not work correcly either from the controller or by the Encoder
                         *  Using as a normal node all functions operate correctly.
                        //#define MY_DEBUG
                        // --- Enable Serial Gateway Transport
                        //#define MY_INCLUSION_MODE_BUTTON_PIN 8
                        // --- Enable RS485 transport layer
                        //#define MY_RS485
                        // Define this to enables DE-pin management on defined pin
                        //#define MY_RS485_DE_PIN 12
                        // Set RS485 baud rate to use
                        //#define MY_RS485_BAUD_RATE 9600
                        #define SV "1.3a"
                        // #define OPENHAB2                      // Use Define if using OPENHAB2
                        #define LIGHT_OFF 0
                        #define LIGHT_ON 1
                        int dimValue;
                        int fadeTo;
                        int fadeDelta;
                        byte oldButtonVal;
                          checkButtonClick();
                          fadeStep();
                            #ifdef MY_DEBUG
                            // This is called when a message is received
                            Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", type: "); Serial.print(message.type); Serial.print(", Message: ");
                            int newLevel = 0;
                            } else {
                            return;
                            if (fadeTo != 0)
                          #ifdef MY_DEBUG
                          if (!changedByKnob)
                          startFade();
                            encoderValue = 100;
                            encoderValue = 0;
                            knob.write(0);
                            startFade();
                          debouncer.update();
                          byte newLevel = 0;
                            if (dimValue==0) {
                            #ifdef OPENHAB2
                        void startFade() {
                        void fadeStep() {
                            #ifdef MY_DEBUG
                        I maybe overlooking something obvious as i only have a couple of hours experience with domoticz.
                        • M Offline
                          M Offline
                          mateos78
                          #52
                          @hard-shovel thanks a lot for you post and effort to test it!, I've tested also the version of sketch without rotary encoder and this one works fine.
                          • M Offline
                            M Offline
                            mateos78
                            So, does anybody use "Example with Rotary Encoder" with DOMOTICZ? I'm trying to force the sketch to work, but for time being without any result:(
                            • S Offline
                              Sarg666
                              could someone possibly add a relay to the sketch? Have with all my dimmer problems so that they often dont turn off the LEDs. Maybe it's up to my controller software. And my programming skill are not really good.
                              Thx Sarg666
                              • ZwaZoZ Offline
                                ZwaZoZ Offline
                                ZwaZo
                                #55
                                when compiling the standard example https://github.com/mysensors/MySensors/blob/master/examples/DimmableLEDActuator/DimmableLEDActuator.ino
                                on the IDE 1.8.12 :
                                Return this error :
                                C:\Users\James\Documents\Arduino\sketch_may16a-test\sketch_may16a-test.ino: In function 'void receive(const MyMessage&)':
                                sketch_may16a-test:88:15: error: 'const class MyMessage' has no member named 'getType'; did you mean 'setType'?
                                   if (message.getType() == V_LIGHT || message.getType() == V_DIMMER) {
                                               setType
                                sketch_may16a-test:88:47: error: 'const class MyMessage' has no member named 'getType'; did you mean 'setType'?
        setType
                                sketch_may16a-test:94:33: error: 'const class MyMessage' has no member named 'getType'; did you mean 'setType'?
                                     requestedLevel *= ( message.getType() == V_LIGHT ? 100 : 1 );
        setType
                                exit status 1
                                Can someone help?
                                All the best!
                                BearWithBeardB 1 Reply Last reply
                                • ZwaZoZ ZwaZo
                                  on the IDE 1.8.12 :
                                  Return this error :
                                                 setType
        setType
        setType
                                  exit status 1
                                  Can someone help?
                                  All the best!
                                  BearWithBeardB Offline
                                  BearWithBeard
                                  @ZwaZo
                                  The example compiles for me in IDE 1.8.12
                                  Sketch uses 14338 bytes (46%) of program storage space. Maximum is 30720 bytes.
                                  Global variables use 503 bytes (24%) of dynamic memory, leaving 1545 bytes for local variables. Maximum is 2048 bytes.
                                  Please verify that you are using the latest version of the MySensors library (2.3.2).
                                  • ZwaZoZ Offline
                                    ZwaZoZ Offline
                                    ZwaZo
                                    @ZwaZo said in 💬 Dimmable LED Actuator:
                                    meon
                                    Nope, I'm still on 2.2.2
                                    • ZwaZoZ Offline
                                      ZwaZoZ Offline
                                      ZwaZo
                                      @BearWithBeard I have upgraded the library V.2.3.2 and it compiles now. :)
                                      Thanks for your help!
                                      • A Offline
                                        A Offline
                                        adds666
                                        Does this need a resistor between the Arduino digital pin and the Gate of the MOSFET? To limit current draw?
