  2. Announcements
  3. 💬 Rain Gauge
💬 Rain Gauge
61 Posts 17 Posters 27.2k Views 16 Watching
  • F flopp
    I am using version 1.5.?
    I have not opened the rain-box for at least 4 month and not changed the code.
    Maybe this error have been there since day one but I have not checked so often.
    But now I am checking daily because of other nodes that I added recently and then I noticed this
    P Offline
    P Offline
    petewill
    @flopp What other types of nodes is this happening on? I'd definitely suggest updating to the latest version of the Beta code if you're having interrupt issues.
    F 1 Reply Last reply
    • P petewill
      F Offline
      F Offline
      flopp
      @petewill
      I have never seen it on other nodes and I don't think I had this error when it was cold
      • U Offline
        U Offline
        user2684
        wrote on last edited by user2684
        #23
        As for myself, I'm using an over-simplified version of your code (https://github.com/mysensors/NodeManager/blob/v1.5-dev/NodeManager.cpp#L585) but the principle should be the same I hope (btw I didn't have the chance to tell you what a great project you put together!). I'm with the latest beta release but since using the arduino's attachInterrupt() in a non-sleeping board, the mysensors' library should not have an impact in my scenario I guess.
        Something I want to check that may cause my issue I think is the power supply. I have a (chinese) USB wall plug connected to a (chinese) USB TTL connected to my arduino board. I wonder if a fluctuating power would generate this behavior (while indoor, it was connected to a different power supply). I'll try this way and report back.
        Out of curiosity those are the logs from my controller (0.11 is 1 interrupt). So this is happening at every hour, up to 9 times per hour so the heat cannot be the issue I might say:
        [2017-05-19 16:22:18] [plugin_mysensors.py:250 - process_inbound()] INFO: [serial_1][5][1] presented as S_RAIN
        [2017-05-19 17:22:07] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.88
        [2017-05-19 19:21:45] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-19 20:21:35] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.66
        [2017-05-19 21:21:25] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.33
        [2017-05-19 22:21:16] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-19 23:21:07] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.66
        [2017-05-20 00:21:00] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.33
        [2017-05-20 01:20:53] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-20 02:20:47] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-20 03:20:41] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-20 04:20:33] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-20 05:20:28] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-20 06:20:24] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-20 07:20:18] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-20 08:20:12] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-20 09:20:04] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-20 10:19:56] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.77
        [2017-05-20 11:19:48] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.22
        [2017-05-20 12:19:37] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.44
        [2017-05-20 13:19:23] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.22
        [2017-05-20 14:19:09] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.22
        [2017-05-20 15:18:55] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.99
        [2017-05-20 16:18:43] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-20 17:18:31] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-20 18:18:21] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-20 19:18:12] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-20 20:18:03] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-20 21:17:55] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-20 22:17:50] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-20 23:17:44] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-21 00:17:39] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 01:17:32] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-21 02:17:24] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 03:17:16] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-21 04:17:10] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-21 05:17:05] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 06:16:58] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-21 07:16:52] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 08:16:45] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 09:16:38] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 10:16:32] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-21 11:16:25] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 12:16:16] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-21 13:15:53] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 14:15:30] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-21 15:15:15] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-21 16:15:02] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 17:14:47] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 18:14:35] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 19:14:23] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
        [2017-05-21 20:14:11] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 20:14:12] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
        [2017-05-21 21:14:01] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.44
        [2017-05-21 22:13:49] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.44
        • I Offline
          I Offline
          itbeyond
          I had fake interupts on my device - would work great on test bench then with a 5v dc converter that was noisey plus a longer cable to the bucket I was getting a lot of trips. My fix which solved all the issues was a 0.1uF ceramic cap from ground to the signal pin of the bucket (right at the adruino) coupled with an inline resistor 330ohm to the bucket and a 1Kohm resistor from +5v to the signal pin. This is a basic pull up and debounce system and it manages to hold the 5V via the cap with 100% reliability thus far for 3 weeks including a lot of rain over the last few days. I would draw a circuit diagram if someone could tell me the best program to use?
          U P 2 Replies Last reply
          • I itbeyond
            U Offline
            U Offline
            user2684
            @itbeyond cool thanks! I'll try to put together something similar and report back the results. I guess in this way you don't need INPUT_PULLUP when setting up the pin since already there right? Thanks
            I 1 Reply Last reply
            • F Offline
              F Offline
              flopp
              Last 5 days all of them are fake, always during noon(12:00) isn't that strange?
              • U user2684
                I Offline
                I Offline
                itbeyond
                @user2684 Yes make the line:
                pinMode(TIP_SENSOR_PIN, INPUT);
                I did make one other modification of installing an RF Choke and cap circuit on the input power supply but I am sure the cap & resistor mods made all the difference. Good luck and let me know how it goes!
                U 1 Reply Last reply
                • I itbeyond
                  P Offline
                  P Offline
                  petewill
                  wrote on last edited by petewill
                  #28
                  @itbeyond I don't know if it's the best but I use Fritzing to do my diagrams. It is very easy to learn and easy for new people to understand.
                  @user2684 I am powering my with a good power supply and I believe it's on the vcc pin (not using the ftdi adapter). Maybe you want to try that?
                  @flopp based on what others are saying here I suggest you try changing the power supply as well. Also, are you powering the radio from the arduino or from the power source? If you don't have one already I would add a 100uF capacitor on the radio.
                  • I itbeyond
                    U Offline
                    U Offline
                    user2684
                    #29
                    @itbeyond I've put together today the changes you recommended to my project and see what will happen overnight and tomorrow before moving on and considering replacing the power supply. So far so good since during the last 4 hours I had 0.00 which never happened 4 times in a row so far before applying the resistors and the cap. Btw, my project is 3.3v powered and not 5v like yours, should I use different resistors/capacitors. I'm asking because I'm not 100% sure how you got there ;-) Thanks!
                    • U user2684
                      I Offline
                      I Offline
                      itbeyond
                      @user2684 Those values should be ok - maybe the 330 inline with the switch could be a little smaller but it should be fine with all those values. See how you go.
                      I kept my noisy power supply after making these and an RF Choke mod. The RF Choke if you are interested is a 330uH choke inline with the power supply and a cap at 22uF (I used electro) on the inbound power supply just as it hits the board.
                      Good luck and do let me know how it is going. I am sure it will sort it.
                      • I itbeyond
                        U Offline
                        U Offline
                        user2684
                        @itbeyond I can say it is working perfectly now, thanks! Always 0.00 during the night, I force two triggers this morning and I had the correct equivalent of rain.
                        @petewill I'd add this as a note on https://www.mysensors.org/build/rain, even if it is not a common issue, at least for those who will experience it can have a solution ready to use.
                        So if I understand correctly (which rarely happens), in a no rain situation it is like the bucket is unplugged and the pin is connected to Vcc through the 1k resistor (to limit the current right?) and also charging the capacitor. When it rains, it is like the bucket would connect the input pin to ground and I guess the capacitor and 330R resistor would smooth this so to actually debounce the signal. Is it the case? Thanks
                        • U user2684
                          I Offline
                          I Offline
                          itbeyond
                          @user2684 That is great news - your understanding is basically correct. When no rain the 1K is providing the pull up to 3.3/5v and charging the cap at the same time (current limit is really for when you go to ground not to hold the pin up). When the bucket tips the cap is discharged via the resistor to ground (bucket switch) and thus the pin goes low. Yes - simple and effective pull up and debounce system which works every time - in fact I use this on all interrupt triggered pins for all my projects.
                          @petewill it would be good to include something like this on most of the projects, would have saved me a lot of early angst in having faulty triggered interrupts. I suspect different cloned Arduino boards have different to zero internal pull ups (3 different ones I have tried seem to have none) and to be 100% sure it is much better to document an external arrangement. It will really help the beginners to get it right first time and keep some hair regardless of the quality of the board they are using. I needed this on my irrigation controller also - same problem with a 10cm cable to a push button.
                          • I itbeyond
                            U Offline
                            U Offline
                            user2684
                            @itbeyond thanks for the explanation! Last question even if not necessarily mysensors related: how did you size the cap the resistors? Thanks!
                            • I itbeyond
                              P Offline
                              P Offline
                              petewill
                              #34
                              @itbeyond said in 💬 Rain Gauge:
                              Interesting. I haven't experienced this behavior with any of my devices yet. I do power most of my sensors with my whole house power supply though so I guess that would explain it.
                              I will update the rain gauge page and also add this info to the troubleshooting section. Thanks for your help with this!
                              If anyone needs a visual of what @itbeyond described above here is the wiring diagram.
                              • EnfeetE Offline
                                EnfeetE Offline
                                Enfeet
                                Hi friends,
                                here is my replica of Rain Guage MySensors project
                                photos:
                                https://goo.gl/photos/4kA7T4d8SsDBRrrS7
                                The sketch is adopted for 'Adafruit Unified Sensor by Adafruit' + 'DHT sensor library' just uncomment both DHT_ON and DHT_ADAFRUIT
                                and last version of Arduino IDE 1.8.3
                                ...and Yes, I'm using rfm69hw radio with encryption enabled ;-)
                                #define MY_RFM69_ENABLE_ENCRYPTION
                                 Arduino Tipping Bucket Rain Gauge
                                 April 26, 2015
                                 Version 2.0
                                 Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
                                 gateway you can measure and sense local rain.  This sketch will create two devices on your
                                 Vera controller.  One will display your total precipitation for the last 5 days.  The other,
                                 a sensor that changes state if there is recent rain (up to last 120 hours)  above a threshold.
                                 Both these settings are user definable.
                                 There is a build overview video here: https://youtu.be/1eMfKQaLROo
                                 This sketch features the following:
                                 * Allows you to set the rain threshold in mm
                                 * Allows you to determine the tripped indicator window up to 120 hours.
                                 * Displays the last 5 days of rain in Variable1 through Variable5
                                   of the Rain Sensor device
                                 * Configuration changes to Sensor device updated every hour
                                 * Should run on any Arduino
                                 * Will retain Tripped/Not Tripped status and data in a power interruption, saving small amount
                                   of data to EEPROM (Circular Buffer to maximize life of EEPROM)
                                 * LED status indicator
                                 * Optional Temp/Humidity (DHT-22 or DHT-11) and Light LUX (BH1750) sensors. To use, uncomment
                                   #define DHT_ON  and/or #define LUX_ON
                                 * Optionally send total accumulation of each day's rainfall or send only individual days rainfall totals.
                                   Uncomment #define USE_DAILY to display individual daily rainfall.  If it is commented out it will display
                                   a cumulative total rainfall (day4 = day1+day2+day3+day4 etc)
                                 by @BulldogLowell and @PeteWill for free public use
                                //#define MY_DEBUG
                                //#define MY_DEBUG_VERBOSE
                                #define MY_NODE_ID AUTO
                                //#define MY_RADIO_NRF24
                                #define MY_RADIO_RFM69
                                #define MY_IS_RFM69HW
                                #define MY_RFM69_NETWORKID 100
                                #define MY_RFM69_TX_POWER 31
                                #include <math.h>
                                #include <TimeLib.h>
                                #define SKETCH_NAME "Rain Gauge"
                                #define SKETCH_VERSION "2.0"
                                #define DWELL_TIME 40  // this allows for radio to come back to power after a transmission, ideally 0
                                //#define DEBUG_ON  // Rain gauge specific debug messages.
                                #define DHT_ON // uncomment out this line to enable DHT sensor
                                // 20170621 by Enfeet
                                #define DHT_ADAFRUIT // uncomment out this line to enable DHT with 'Adafruit Unified Sensor by Adafruit' + 'DHT sensor library'
                                //#define DHTTYPE           DHT11     // DHT 11
                                #define DHTTYPE           DHT22     // DHT 22 (AM2302)
                                //#define DHTTYPE           DHT21     // DHT 21 (AM2301)
                                // /20170621 by Enfeet
                                //#define LUX_ON // uncomment out this line to enable BH1750 sensor
                                //#define USE_DAILY // Uncomment to display individual daily rainfall totals in the variables sent to your controller. If it's commented it will add each day to the next for a cumulative total.
                                #define TIP_SENSOR_PIN 3
                                //d=112 mm
                                //11689.863832 mm2 =  116,89863832 cm2
                                //42,77209787776081 mm
                                //88 89 91 91 90 = 89,8
                                //0,4763039852757329
                                #define CALIBRATE_FACTOR 48 // amount of rain per rain bucket tip e.g. 5 is .05mm
                                #define DHT_LUX_DELAY 300000  //Delay in milliseconds that the DHT and LUX sensors will wait before sending data
                                #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
                                #define CHILD_ID_TRIPPED_INDICATOR 4  // Indicates Tripped when rain detected
                                #define EEPROM_BUFFER_LOCATION 0  // location of the EEPROM circular buffer
                                #define E_BUFFER_LENGTH 240
                                #define RAIN_BUCKET_SIZE 120
                                  #ifdef  DEBUG_ON
                                    #define M_DEBUG_PRINT(x)   Serial.print(x)
                                    #define M_DEBUG_PRINTLN(x) Serial.println(x)
                                    #define SERIAL_START(x)  Serial.begin(x)
                                    #else
                                MyMessage msgRainRate(CHILD_ID_RAIN_LOG, V_RAINRATE);
                                MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
                                MyMessage msgRainVAR1(CHILD_ID_RAIN_LOG, V_VAR1);
                                MyMessage msgRainVAR2(CHILD_ID_RAIN_LOG, V_VAR2);
                                MyMessage msgRainVAR3(CHILD_ID_RAIN_LOG, V_VAR3);
                                MyMessage msgRainVAR4(CHILD_ID_RAIN_LOG, V_VAR4);
                                MyMessage msgRainVAR5(CHILD_ID_RAIN_LOG, V_VAR5);
                                MyMessage msgTripped(CHILD_ID_TRIPPED_INDICATOR, V_TRIPPED);
                                MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
                                MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
                                #ifdef DHT_ON
                                  #ifdef DHT_ADAFRUIT
                                  #include <Adafruit_Sensor.h>
                                  #include <DHT_U.h>
                                  #include <DHT.h>
                                  #define CHILD_ID_HUM 0
                                  #define CHILD_ID_TEMP 1
                                  #define HUMIDITY_SENSOR_DIGITAL_PIN 8
                                  #ifndef DHT_ADAFRUIT // 20170621 by Enfeet
                                    DHT dht;
                                  #else
                                    DHT_Unified dht(HUMIDITY_SENSOR_DIGITAL_PIN, DHTTYPE);
                                    sensors_event_t event;
                                  #endif // /20170621 by Enfeet
                                  float lastTemp;
                                  float lastHum;
                                  bool metric = true;
                                #ifdef LUX_ON
                                  //BH1750 is connected to SCL (analog input A5) and SDA (analog input A4)
                                  #include <BH1750.h>
                                  #include <Wire.h>
                                  #define CHILD_ID_LIGHT 2
                                  BH1750 lightSensor;
                                  unsigned int lastlux;
                                  uint8_t heartbeat = 10; //Used to send the light lux to gateway as soon as the device is restarted and after the DHT_LUX_DELAY has happened 10 times
                                unsigned long sensorPreviousMillis;
                                int eepromIndex;
                                int tipSensorPin = 3; // Pin the tipping bucket is connected to. Must be interrupt capable pin
                                int ledPin = 5; // Pin the LED is connected to.  PWM capable pin required
                                #ifdef DEBUG_ON
                                unsigned long dataMillis;
                                unsigned long serialInterval = 600000UL;
                                const unsigned long oneHour = 3600000UL;
                                unsigned long lastTipTime;
                                unsigned long lastRainTime; //Used for rainRate calculation
                                unsigned int rainBucket [RAIN_BUCKET_SIZE] ; /* 24 hours x 5 Days = 120 hours */
                                unsigned int rainRate = 0;
                                uint8_t rainWindow = 72;         //default rain window in hours.  Will be overwritten with msgTrippedVar1.
                                volatile int wasTippedBuffer = 0;
                                int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
                                uint8_t state = 0;
                                uint8_t oldState = 2; //Setting the default to something other than 1 or 0
                                unsigned int lastRainRate = 0;
                                int lastMeasure = 0;
                                bool gotTime = false;
                                uint8_t lastHour;
                                uint8_t currentHour;
                                void presentation()  {
                                  wait(DWELL_TIME);
                                  present(CHILD_ID_RAIN_LOG, S_RAIN);
                                  wait(DWELL_TIME);
                                  present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
                                  wait(DWELL_TIME);
                                #ifdef DHT_ON
                                  present(CHILD_ID_HUM, S_HUM);
                                  wait(DWELL_TIME);
                                  wait(DWELL_TIME);
                                #ifdef LUX_ON
                                  M_DEBUG_PRINTLN(F("Sensor Presentation Complete"));
                                  #ifndef MY_DEBUG
                                  SERIAL_START(115200);  //Start serial if MySensors debugging isn't enabled
                                  // Set up the IO
                                  attachInterrupt (digitalPinToInterrupt(TIP_SENSOR_PIN), sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
                                  pinMode(ledPin, OUTPUT);
                                  digitalWrite(ledPin, HIGH);
                                  //Sync time with the server
                                  unsigned long functionTimeout = millis();
                                  while (timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL)
                                    requestTime();
                                    M_DEBUG_PRINTLN(F("Getting Time"));
                                    wait(1000); // call once per second
                                    M_DEBUG_PRINTLN(F("."));
                                  currentHour = hour();
                                  lastHour = hour();
                                  //retrieve from EEPROM stored values on a power cycle.
                                  bool isDataOnEeprom = false;
                                  for (int i = 0; i < E_BUFFER_LENGTH; i++)
                                    uint8_t locator = loadState(EEPROM_BUFFER_LOCATION + i);
                                    if (locator == 0xFE)  // found the EEPROM circular buffer index
                                      eepromIndex = EEPROM_BUFFER_LOCATION + i;
                                      M_DEBUG_PRINT(F("EEPROM Index "));
                                      M_DEBUG_PRINTLN(eepromIndex);
                                      //Now that we have the buffer index let's populate the rainBucket[] with data from eeprom
                                      loadRainArray(eepromIndex);
                                      isDataOnEeprom = true;
                                      break;
                                  if (!isDataOnEeprom) // Added for the first time it is run on a new Arduino
                                    M_DEBUG_PRINTLN(F("I didn't find valid EEPROM Index, so I'm writing one to location 0"));
                                    eepromIndex = EEPROM_BUFFER_LOCATION;
                                    saveState(eepromIndex, 0xFE);
                                    saveState(eepromIndex + 1, 0xFE);
                                    //then I will clear out any bad data
                                    for (int i = 2; i <= E_BUFFER_LENGTH; i++)
                                      saveState(i, 0x00);
                                  #ifdef DEBUG_ON
                                  dataMillis = millis();
                                  lastTipTime = millis();
                                  request(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
                                  wait(DWELL_TIME);
                                  request(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
                                  wait(DWELL_TIME);
                                #ifdef DHT_ON
                                  #else
                                    dht.begin();
                                  wait(DWELL_TIME);
                                #ifdef LUX_ON
                                  lightSensor.begin();
                                  transmitRainData(); //Setup complete send any data loaded from eeprom to gateway
                                  if (state)
                                    prettyFade();  // breathe if tripped
                                  else
                                    slowFlash();   // blink if not tripped
                                #ifdef DEBUG_ON  // Serial Debug Block
                                  if ( (millis() - dataMillis) >= serialInterval)
                                    for (int i = 24; i <= 120; i = i + 24)
                                      updateSerialData(i);
                                  // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
                                  int measure = 0; // Check to see if we need to show sensor tripped in this block
                                  for (int i = 0; i < rainWindow; i++)
                                    measure += rainBucket [i];
                                    if (measure != lastMeasure)
                                      //      M_DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
                                      //      M_DEBUG_PRINTLN(measure);
                                      lastMeasure = measure;
                                  state = (measure >= (rainSensorThreshold * 100));
                                  if (state != oldState)
                                    send(msgTripped.set(state));
                                    wait(DWELL_TIME);
                                    M_DEBUG_PRINT(F("New Sensor State... Sensor: "));
                                    M_DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
                                    oldState = state;
                                  unsigned long tipDelay = millis() - lastRainTime;
                                  if (wasTippedBuffer) // if was tipped, then update the 24hour total and transmit to Vera
                                    M_DEBUG_PRINTLN(F("Sensor Tipped"));
                                    M_DEBUG_PRINT(F("rainBucket [0] value: "));
                                    M_DEBUG_PRINTLN(rainBucket [0]);
                                    send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); //Calculate the total rain for the day
                                    wait(DWELL_TIME);
                                    wasTippedBuffer--;
                                    rainRate = ((oneHour) / tipDelay);
                                    if (rainRate != lastRainRate)
                                      send(msgRainRate.set(rainRate, 1));
                                      wait(DWELL_TIME);
                                      M_DEBUG_PRINT(F("RainRate= "));
                                      M_DEBUG_PRINTLN(rainRate);
                                      lastRainRate = rainRate;
                                    lastRainTime = lastTipTime;
                                  if (currentHour != lastHour)
                                    M_DEBUG_PRINTLN(F("One hour elapsed."));
                                    send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); // send today's rainfall
                                    wait(DWELL_TIME);
                                    saveState(eepromIndex, highByte(rainBucket[0]));
                                    saveState(eepromIndex + 1, lowByte(rainBucket[0]));
                                    M_DEBUG_PRINT(F("Saving rainBucket[0] to eeprom. rainBucket[0] = "));
                                    M_DEBUG_PRINTLN(rainBucket[0]);
                                    for (int i = RAIN_BUCKET_SIZE - 1; i >= 0; i--)//cascade an hour of values back into the array
                                      rainBucket [i + 1] = rainBucket [i];
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                    rainBucket[0] = 0;
                                    eepromIndex = eepromIndex + 2;
                                    if (eepromIndex > EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH)
                                    M_DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
                                    requestTime(); // sync the time every hour
                                    wait(DWELL_TIME);
                                    transmitRainData();
                                    rainRate = 0;
                                    wait(DWELL_TIME);
                                    M_DEBUG_PRINTLN(F("Sending rainRate is 0 to controller"));
                                    lastHour = hour();
                                  if (millis() - sensorPreviousMillis > DHT_LUX_DELAY)
                                    #ifdef DHT_ON  //DHT Code
                                      doDHT();
                                    #ifdef LUX_ON
                                      doLUX();
                                    sensorPreviousMillis = millis();
                                #ifdef DHT_ON
                                void doDHT(void)
                                    if (isnan(temperature))
                                  #else
                                    dht.temperature().getEvent(&event);
                                    float temperature = event.temperature;
                                    if (isnan(event.temperature))
                                      M_DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
                                    } else if (temperature != lastTemp)
                                      lastTemp = temperature;
                                        if (!metric)
                                      wait(DWELL_TIME);
                                      M_DEBUG_PRINT(F("Temperature is: "));
                                      M_DEBUG_PRINTLN(temperature);
                                    float humidity = dht.getHumidity();;
                                    if (isnan(humidity))
                                  #else
                                    dht.humidity().getEvent(&event);
                                    float humidity = event.relative_humidity;
                                    if (isnan(event.relative_humidity))
                                      M_DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
                                    } else if (humidity != lastHum)
                                      lastHum = humidity;
                                      wait(DWELL_TIME);
                                      M_DEBUG_PRINT(F("Humidity is: "));
                                      M_DEBUG_PRINTLN(humidity);
                                #ifdef LUX_ON
                                void doLUX(void)
                                  unsigned int lux = lightSensor.readLightLevel();// Get Lux value
                                  M_DEBUG_PRINT(F("Current LUX Level: "));
                                  M_DEBUG_PRINTLN(lux);
                                  heartbeat++;
                                  if (lux != lastlux || heartbeat > 10)
                                    send(msg.set(lux));
                                    lastlux = lux;
                                  if (heartbeat > 10)
                                    heartbeat = 0;
                                void sensorTipped()
                                  unsigned long thisTipTime = millis();
                                  if (thisTipTime - lastTipTime > 100UL)
                                    rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
                                    wasTippedBuffer++;
                                  lastTipTime = thisTipTime;
                                int rainTotal(int hours)
                                  int total = 0;
                                  for ( int i = 0; i <= hours; i++)
                                    total += rainBucket [i];
                                  return total;
                                #ifdef DEBUG_ON
                                void updateSerialData(int x)
                                  M_DEBUG_PRINT(F("Rain last "));
                                  M_DEBUG_PRINT(x);
                                  M_DEBUG_PRINTLN(F(" hours: "));
                                  float tipCount = 0;
                                  for (int i = 0; i < x; i++)
                                    tipCount = tipCount + rainBucket [i];
                                  tipCount = tipCount / 100;
                                  M_DEBUG_PRINTLN(tipCount);
                                void loadRainArray(int eValue) // retrieve stored rain array from EEPROM on powerup
                                  for (int i = 1; i < RAIN_BUCKET_SIZE; i++)
                                    eValue = eValue - 2;
                                    if (eValue < EEPROM_BUFFER_LOCATION)
                                      eValue = EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH;
                                    M_DEBUG_PRINT(F("EEPROM location: "));
                                    M_DEBUG_PRINTLN(eValue);
                                    uint8_t rainValueHigh = loadState(eValue);
                                    uint8_t rainValueLow = loadState(eValue + 1);
                                    unsigned int rainValue = rainValueHigh << 8;
                                    rainValue |= rainValueLow;
                                    rainBucket[i] = rainValue;
                                    M_DEBUG_PRINT(F("rainBucket[ value: "));
                                    M_DEBUG_PRINT(i);
                                    M_DEBUG_PRINT(F("] value: "));
                                    M_DEBUG_PRINTLN(rainBucket[i]);
                                void transmitRainData(void)
                                  M_DEBUG_PRINT(F("In transmitRainData. currentHour = "));
                                  M_DEBUG_PRINTLN(currentHour);
                                  int rainUpdateTotal = 0;
                                  for (int i = currentHour; i >= 0; i--)
                                    rainUpdateTotal += rainBucket[i];
                                    M_DEBUG_PRINT(F("Adding rainBucket["));
                                    M_DEBUG_PRINT(i);
                                    M_DEBUG_PRINTLN(F("] to rainUpdateTotal."));
                                  M_DEBUG_PRINT(F("TX Day 1: rainUpdateTotal = "));
                                  M_DEBUG_PRINTLN((float)rainUpdateTotal / 100.0);
                                  send(msgRainVAR1.set((float)rainUpdateTotal / 100.0, 1)); //Send current day rain totals (resets at midnight)
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                  for (int i = currentHour + 24; i > currentHour; i--)
                                    M_DEBUG_PRINT(i);
                                  M_DEBUG_PRINT(F("TX Day 2: rainUpdateTotal = "));
                                  send(msgRainVAR2.set((float)rainUpdateTotal / 100.0, 1));
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                  for (int i = currentHour + 48; i > currentHour + 24; i--)
                                    M_DEBUG_PRINT(i);
                                  M_DEBUG_PRINT(F("TX Day 3: rainUpdateTotal = "));
                                  send(msgRainVAR3.set((float)rainUpdateTotal / 100.0, 1));
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                  for (int i = currentHour + 72; i > currentHour + 48; i--)
                                    M_DEBUG_PRINT(i);
                                  M_DEBUG_PRINT(F("TX Day 4: rainUpdateTotal = "));
                                  send(msgRainVAR4.set((float)rainUpdateTotal / 100.0, 1));
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                  for (int i = currentHour + 96; i > currentHour + 72; i--)
                                    M_DEBUG_PRINT(i);
                                  M_DEBUG_PRINT(F("TX Day 5: rainUpdateTotal = "));
                                  send(msgRainVAR5.set((float)rainUpdateTotal / 100.0, 1));
                                  wait(DWELL_TIME);
                                  if (message.sensor == CHILD_ID_RAIN_LOG)
                                    // nothing to do here
                                  else if (message.sensor == CHILD_ID_TRIPPED_INDICATOR)
                                    if (message.type == V_VAR1)
                                      rainWindow = atoi(message.data);
                                      if (rainWindow > 120)
                                        rainWindow = 120;
                                      else if (rainWindow < 1)
                                        rainWindow = 1;
                                      if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
                                        send(msgTrippedVar1.set(rainWindow));
                                    else if (message.type == V_VAR2)
                                      rainSensorThreshold = atoi(message.data);
                                      if (rainSensorThreshold > 10000)
                                        rainSensorThreshold = 10000;
                                      else if (rainSensorThreshold < 1)
                                        rainSensorThreshold = 1;
                                      if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
                                        send(msgTrippedVar2.set(rainSensorThreshold));
                                void prettyFade(void)
                                  float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
                                  analogWrite(ledPin, val);
                                void slowFlash(void)
                                  static bool ledState = true;
                                  static unsigned long pulseStart = millis();
                                  if (millis() - pulseStart < 100UL)
                                    digitalWrite(ledPin, !ledState);
                                void receiveTime(unsigned long newTime)
                                  M_DEBUG_PRINTLN(F("Time received..."));
                                  setTime(newTime);
                                  char theTime[6];
                                  sprintf(theTime, "%d:%2d", hour(), minute());
                                  M_DEBUG_PRINTLN(theTime);
                                i take an original .stl files from the link provided: https://drive.google.com/drive/folders/0B3KGTJHUgpw1fkwtM3RreEF2QWg4eUdsUHdSQjl6UWx2Q3dPS19WSGdqd0pZQ3hhQk1TMkE
                                but in order to save a support material recreate and split it a little ;-)
                                The result are visible on photos
                                here is an .scad code of my modifications on top of original files, also i print them up side down ;-)
                                $fn=300;
                                difference(){
                                translate([35,0,0])
                                import("Can.stl");
                                cube([210,150,150],center=true);
                                translate([62,0,0])
                                rotate([0,90,0])
                                difference(){
                                cylinder(d=10,h=3,center=true);
                                cylinder(d=4,h=6,center=true);
                                difference(){
                                translate([-88,0,0])
                                sphere(d=300);
                                translate([-90,0,0])
                                sphere(d=300);
                                translate([61,0,0])
                                rotate([0,90,0])
                                cylinder(d=4,h=4,center=true);
                                rotate([0,90,0])
                                difference(){
                                cylinder(d=310,h=208,center=true);
                                cylinder(d=122.5+4,h=310,center=true);
                                translate([54,0,0])
                                rotate([0,90,0])
                                difference(){
                                cylinder(d=122.5+4,h=108,center=true);
                                cylinder(d=122.5,h=310,center=true);
                                $fn=300;
                                difference(){
                                translate([35,0,0])
                                import("Can.stl");
                                translate([62,0,0])
                                rotate([0,90,0])
                                difference(){
                                difference(){
                                sphere(d=300);
                                sphere(d=300);
                                translate([61,0,0])
                                rotate([0,90,0])
                                rotate([0,90,0])
                                difference(){
                                translate([54,0,0])
                                rotate([0,90,0])
                                difference(){
                                cylinder(d=122.5+4,h=40
                                   ,center=true);
                                translate([32,0,0])
                                rotate([0,90,0])
                                difference(){
                                cylinder(d=122.5+4+4,h=8
                                   ,center=true);
                                cylinder(d=122.5+4,h=9,center=true);
                                SY
                                Enfeet
                                D 2 Replies Last reply
                                • EnfeetE Enfeet
                                  Hi friends,
                                  photos:
                                   April 26, 2015
                                   Version 2.0
                                  //#define MY_DEBUG
                                  #include <math.h>
                                  //d=112 mm
                                    #ifdef  DEBUG_ON
                                      #else
                                  #ifdef DHT_ON
                                    #ifdef DHT_ADAFRUIT
                                    #include <DHT_U.h>
                                    #include <DHT.h>
                                      DHT dht;
                                    #else
                                    float lastTemp;
                                    float lastHum;
                                    bool metric = true;
                                  #ifdef LUX_ON
                                    #include <BH1750.h>
                                    #include <Wire.h>
                                    BH1750 lightSensor;
                                  int eepromIndex;
                                  #ifdef DEBUG_ON
                                  uint8_t state = 0;
                                  uint8_t lastHour;
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                  #ifdef DHT_ON
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                  #ifdef LUX_ON
                                    #ifndef MY_DEBUG
                                    // Set up the IO
                                      requestTime();
                                    lastHour = hour();
                                        break;
                                        saveState(i, 0x00);
                                    #ifdef DEBUG_ON
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                  #ifdef DHT_ON
                                    #else
                                      dht.begin();
                                    wait(DWELL_TIME);
                                  #ifdef LUX_ON
                                    if (state)
                                    else
                                      wait(DWELL_TIME);
                                      oldState = state;
                                      wait(DWELL_TIME);
                                      wasTippedBuffer--;
                                        wait(DWELL_TIME);
                                      wait(DWELL_TIME);
                                      wait(DWELL_TIME);
                                      wait(DWELL_TIME);
                                      rainBucket[0] = 0;
                                      wait(DWELL_TIME);
                                      transmitRainData();
                                      rainRate = 0;
                                      wait(DWELL_TIME);
                                      lastHour = hour();
                                        doDHT();
                                      #ifdef LUX_ON
                                        doLUX();
                                  #ifdef DHT_ON
                                  void doDHT(void)
                                    #else
                                          if (!metric)
                                        wait(DWELL_TIME);
                                    #else
                                        lastHum = humidity;
                                        wait(DWELL_TIME);
                                  #ifdef LUX_ON
                                  void doLUX(void)
                                    heartbeat++;
                                      send(msg.set(lux));
                                      lastlux = lux;
                                    if (heartbeat > 10)
                                      heartbeat = 0;
                                  void sensorTipped()
                                      wasTippedBuffer++;
                                    int total = 0;
                                    return total;
                                  #ifdef DEBUG_ON
                                    M_DEBUG_PRINT(x);
                                    float tipCount = 0;
                                      M_DEBUG_PRINT(i);
                                      M_DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      M_DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      M_DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      M_DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      M_DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                          rainWindow = 120;
                                          rainWindow = 1;
                                    setTime(newTime);
                                    char theTime[6];
                                  $fn=300;
                                  difference(){
                                  translate([35,0,0])
                                  import("Can.stl");
                                  translate([62,0,0])
                                  rotate([0,90,0])
                                  difference(){
                                  difference(){
                                  sphere(d=300);
                                  sphere(d=300);
                                  translate([61,0,0])
                                  rotate([0,90,0])
                                  rotate([0,90,0])
                                  difference(){
                                  translate([54,0,0])
                                  rotate([0,90,0])
                                  difference(){
                                  $fn=300;
                                  difference(){
                                  translate([35,0,0])
                                  import("Can.stl");
                                  translate([62,0,0])
                                  rotate([0,90,0])
                                  difference(){
                                  difference(){
                                  sphere(d=300);
                                  sphere(d=300);
                                  translate([61,0,0])
                                  rotate([0,90,0])
                                  rotate([0,90,0])
                                  difference(){
                                  translate([54,0,0])
                                  rotate([0,90,0])
                                  difference(){
                                     ,center=true);
                                  translate([32,0,0])
                                  rotate([0,90,0])
                                  difference(){
                                     ,center=true);
                                  SY
                                  Enfeet
                                  @Enfeet What type of sensor did you use for the tipping bucket? Reed switch? Hall effect sensor?
                                  EnfeetE 1 Reply Last reply
                                  • D dbemowsk
                                    EnfeetE Offline
                                    EnfeetE Offline
                                    Enfeet
                                    @dbemowsk
                                    20mm magnetic contact like this:
                                    SY
                                    Enfeet
                                    D 1 Reply Last reply
                                    • EnfeetE Enfeet
                                      @dbemowsk
                                      SY
                                      Enfeet
                                      @Enfeet Thanks, it was hard to tell from your pics. It almost looked like a hall sensor. I too am using a reed switch. I have some reed switch boards that I salvaged from some old laptops. They were the sensors for closing the LCD.
                                      • EnfeetE Enfeet
                                        Hi friends,
                                        photos:
                                         April 26, 2015
                                         Version 2.0
                                        //#define MY_DEBUG
                                        #include <math.h>
                                        //d=112 mm
                                          #ifdef  DEBUG_ON
                                            #else
                                        #ifdef DHT_ON
                                          #ifdef DHT_ADAFRUIT
                                          #include <DHT_U.h>
                                          #include <DHT.h>
                                            DHT dht;
                                          #else
                                          float lastTemp;
                                          float lastHum;
                                          bool metric = true;
                                        #ifdef LUX_ON
                                          #include <BH1750.h>
                                          #include <Wire.h>
                                          BH1750 lightSensor;
                                        int eepromIndex;
                                        #ifdef DEBUG_ON
                                        uint8_t state = 0;
                                        uint8_t lastHour;
                                          wait(DWELL_TIME);
                                          wait(DWELL_TIME);
                                          wait(DWELL_TIME);
                                        #ifdef DHT_ON
                                          wait(DWELL_TIME);
                                          wait(DWELL_TIME);
                                        #ifdef LUX_ON
                                          #ifndef MY_DEBUG
                                          // Set up the IO
                                            requestTime();
                                          lastHour = hour();
                                              break;
                                              saveState(i, 0x00);
                                          #ifdef DEBUG_ON
                                          wait(DWELL_TIME);
                                          wait(DWELL_TIME);
                                        #ifdef DHT_ON
                                          #else
                                            dht.begin();
                                          wait(DWELL_TIME);
                                        #ifdef LUX_ON
                                          if (state)
                                          else
                                            wait(DWELL_TIME);
                                            oldState = state;
                                            wait(DWELL_TIME);
                                            wasTippedBuffer--;
                                              wait(DWELL_TIME);
                                            wait(DWELL_TIME);
                                            wait(DWELL_TIME);
                                            wait(DWELL_TIME);
                                            rainBucket[0] = 0;
                                            wait(DWELL_TIME);
                                            transmitRainData();
                                            rainRate = 0;
                                            wait(DWELL_TIME);
                                            lastHour = hour();
                                              doDHT();
                                            #ifdef LUX_ON
                                              doLUX();
                                        #ifdef DHT_ON
                                        void doDHT(void)
                                          #else
                                                if (!metric)
                                              wait(DWELL_TIME);
                                          #else
                                              lastHum = humidity;
                                              wait(DWELL_TIME);
                                        #ifdef LUX_ON
                                        void doLUX(void)
                                          heartbeat++;
                                            send(msg.set(lux));
                                            lastlux = lux;
                                          if (heartbeat > 10)
                                            heartbeat = 0;
                                        void sensorTipped()
                                            wasTippedBuffer++;
                                          int total = 0;
                                          return total;
                                        #ifdef DEBUG_ON
                                          M_DEBUG_PRINT(x);
                                          float tipCount = 0;
                                            M_DEBUG_PRINT(i);
                                            M_DEBUG_PRINT(i);
                                          wait(DWELL_TIME);
                                        #ifdef USE_DAILY
                                            M_DEBUG_PRINT(i);
                                          wait(DWELL_TIME);
                                        #ifdef USE_DAILY
                                            M_DEBUG_PRINT(i);
                                          wait(DWELL_TIME);
                                        #ifdef USE_DAILY
                                            M_DEBUG_PRINT(i);
                                          wait(DWELL_TIME);
                                        #ifdef USE_DAILY
                                            M_DEBUG_PRINT(i);
                                          wait(DWELL_TIME);
                                                rainWindow = 120;
                                                rainWindow = 1;
                                          setTime(newTime);
                                          char theTime[6];
                                        $fn=300;
                                        difference(){
                                        translate([35,0,0])
                                        import("Can.stl");
                                        translate([62,0,0])
                                        rotate([0,90,0])
                                        difference(){
                                        difference(){
                                        sphere(d=300);
                                        sphere(d=300);
                                        translate([61,0,0])
                                        rotate([0,90,0])
                                        rotate([0,90,0])
                                        difference(){
                                        translate([54,0,0])
                                        rotate([0,90,0])
                                        difference(){
                                        $fn=300;
                                        difference(){
                                        translate([35,0,0])
                                        import("Can.stl");
                                        translate([62,0,0])
                                        rotate([0,90,0])
                                        difference(){
                                        difference(){
                                        sphere(d=300);
                                        sphere(d=300);
                                        translate([61,0,0])
                                        rotate([0,90,0])
                                        rotate([0,90,0])
                                        difference(){
                                        translate([54,0,0])
                                        rotate([0,90,0])
                                        difference(){
                                           ,center=true);
                                        translate([32,0,0])
                                        rotate([0,90,0])
                                        difference(){
                                           ,center=true);
                                        SY
                                        Enfeet
                                        @Enfeet I was checking out your sketch and was confused on some of the numbers you had commented into your sketch. I am gathering that they are numbers you used to figure out your CALIBRATE_FACTOR number, but I am trying to understand them. These are the numbers I am referring to:
                                        //d=112 mm
                                        I am assuming that 112 mm is the diameter of your catchment funnel. I cannot however figure out your next number 11689.863832 mm2. What formula did you use to come up with that number? Knowing that may help me understand the rest of the numbers.
                                        • D dbemowsk
                                          //d=112 mm
                                          EnfeetE Offline
                                          EnfeetE Offline
                                          Enfeet
                                          @dbemowsk i use first found online calculator http://onlinemschool.com/math/assistance/figures_area/circle/
                                          and... strange.... it gives other result ;-) So my calculations are incorrect ;-(
                                          A = 1 4 π d2 = 1 4 π 1122 = 3136 π ≈ 9852.032512
                                          SY
                                          Sergey
                                          EnfeetE D 2 Replies Last reply
