  2. Announcements
  3. 💬 Security & Signing
137 Posts 20 Posters 46.5k Views 19 Watching
  • B bilbolodz
    I'm trying to start play with ATSHA204A signing. I've ATSHA204A-SSHCZ-T chip (8-lead SOIC single wire). I've connected chip pins: 4 - GND, 8 - VCC (5v), 5 - A3, I've added 100nF between 4 and 8 and 4K7 resistor between 5 and 8. I've loaded "near clear" SecurityPersonalizer sketch (only added #define MY_SIGNING_ATSHA204_PIN A3 #define MY_SIGNING_ATSHA204) but I've got:
    Personalization sketch for MySensors usage.
    Failed to wake device. Response: E7
    Halting!
    any ideas?
    AnticimexA
    AnticimexA
    Anticimex
    @bilbolodz hm, no. I have not tested on a 8-lead device. Should not be a difference but I can neither deny nor confirm. My best suggestion would be to have a look with an oscilloscope on the wire to confirm that the signal quality is good.
      melwinek
      Is SIGNING a RFM69_ENABLE_ENCRYPTION replacement? If so is it a better or worse solution? Maybe RFM69_ENABLE_ENCRYPTION is enough?
      mfalkviddM AnticimexA 2 Replies Last reply
      • M melwinek
        @melwinek encryption and signing have very different purpose.
        Signing prevents other people from sending messages to control your nodes. Without signing, anyone with the right skill or software can take control of your nodes.
        Encryption tries to hide the contents of the messages between your nodes. That does not prevent people from taking control of your nodes.
        • M melwinek
          AnticimexA
          AnticimexA
          Anticimex
          @melwinek signing and encryption are two completely different things. And they can be enabled at the same time if so desired. Signing provides authentication and encryption provides obscurity.
            melwinek
            @Anticimex, @mfalkvidd But with the use of encryption so easily no one will take control, must break the code.
            So it is best to simultaneously encrypt (eg RFID tag serial number when opening the gate) and sign (eg gate open message)?
            AnticimexA 1 Reply Last reply
            • M melwinek
              AnticimexA
              AnticimexA
              Anticimex
              @melwinek what prevents anyone from copying your encrypted message and record it. And then later send the same thing?
              Encryption provides obscurity. You need signing for authentication. Signed messages cannot be repeated because they are always unique. Encryption does not necessarily guarantee that.
              • B bilbolodz
                Halting!
                any ideas?
                t3chieT
                t3chieT
                t3chie
                @bilbolodz I am getting the same message with a Sensebender Micro. I configured it for soft-signing with LOCK_CONFIGURATION enabled. Now I wanted to switch to hardware based signing.
                Any way to unlock a locked configuration?
                • t3chieT t3chie
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @t3chie there is no configuration to lock for soft signing. Configuration locking only applies to atsha204a. And if locked it cannot be unlocked. And normally you shouldn't need to either as the default settings set are the one to use, and unless you have been very creative in hacking the personalizer that configured should work just fine.
                  t3chieT 1 Reply Last reply
                  • AnticimexA Anticimex
                    t3chieT
                    t3chieT
                    t3chie
                    @Anticimex I tested first with softsigning but shortly after this realized that with soft signing the Sensebender has not enough space for debug messages.
                    I rerun the personalizer to switch to hardware based signing and hit the "Failed to wake device. Response: E7" message.
                    Played around and found that
                    #define MY_SIGNING_ATSHA204_PIN 17
                    instead of
                    #define MY_SIGNING_ATSHA204_PIN 4
                    made the personalizer happy again. I am still fighting with getting signing to work. Setting #define MY_SIGNING_REQUEST_SIGNATURES and MY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL did not get me going.
                    • t3chieT t3chie
                      instead of
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @t3chie I assume you have personalized nodes and gw with the same hmac key?
                      • t3chieT t3chie
                        instead of
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @t3chie also that you also defined the signing enabled flag on all participants (but I think you get a preprocessor error if you don't)
                        • skywatchS
                          skywatchS
                          skywatch
                          Is it possible to use the ATSHA204A along with the Rpi directly attached NRF24L01+ gateway? I can see how to attach the ATSHA to the nodes, but how to attach it to the pi?
                          Thank you.
                          • skywatchS skywatch
                            Thank you.
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @skywatch no, not to my knowledge. The atsha driver is Arduino specific. I would happily review a pull request that ports the bit banged driver for Linux though :)
                              Thank you.
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @skywatch the use case for atsha204a backed signing on rPi is limited though. As it is used as I gw (I presume) it is considered "protected" and is less sensitive for key dumping.
                              • skywatchS
                                skywatchS
                                skywatch
                                Thank you for the quick response. Maybe i mis-understand this?
                                I have got 10 ATSHA chips that I would like to attach to arsuino nodes to use with a raspberry pi based gateway/controller combo. Do I therefore need to attach the ATSHA to the rpi, or could I still use the ATSHA hardware on the arduinos without an ATSHA attached to the rpi?
                                I had assumed that the atsha chip would be needed at both ends for signing to work. Maybe that's not how it works?
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @skywatch no, the software port is fully compatible with the atsha204a. So you can use Arduino nodes with atsha204a and they will work just fine with your rPi with software signing. Just as long as they all use the same hmac key.
                                  • S
                                    sineverba
                                    wrote on last edited by sineverba
                                    #37
                                    I'm hoping that I did done all ok.
                                    I've personalized the Arduino that acts as Gateway (connected via USB to a Raspberry PI) and I've personalized first node (a DHT22).
                                    Both with software signature.
                                    This is the cat from Raspberry / Gateway Arduino:
                                    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
                                    0;255;3;0;9;Skipping security for command 3 type 16
                                    0;255;3;0;9;SHA256: 37FA7FD8F19D55E99C952F467E45D9A7439AAAAAAAAAA        AAAA
                                    0;255;3;0;9;Skipping security for command 3 type 17
                                    0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:37FA7F        D8F19D5CE9A07E95992C45D9A7439
                                    0;255;3;0;9;Transmitted nonce
                                    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=0,c=1,t=1,pt=7,l=5,sg=1:59.3
                                    0;255;3;0;9;Signature in message: 010F55F31D04DBFCA0AFC7E139475
                                    0;255;3;0;9;Message to process: 03033336D4201
                                    0;255;3;0;9;Current nonce: 37FA7FD8F19D55E99C955992C45D9A7439AAA        AAAAAAAAAAA
                                    0;255;3;0;9;HMAC: B50F55F31D04DBFFC7E139475D91093F0A1EABB174B86E9        E9
                                    3;0;1;0;1;59.3
                                    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
                                    0;255;3;0;9;SHA256: 803B7127EB3B049768C59D328C89862FF731AAAAAAAAAA        AAAA
                                    0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:803B71        27EB3D0DED839579D328C89862FF731
                                    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=2,c=1,t=38,pt=7,l=5,sg=1:3.42
                                    0;255;3;0;9;Signature in message: 010E8B790708A39930F73D511F48DAECA
                                    0;255;3;0;9;Message to process: 03002E23BAE5A4002
                                    0;255;3;0;9;Current nonce: 803B7127EB3D0DED83957BB5C59D328C89862FF731AAA        AAAAAAAAAAA
                                    0;255;3;0;9;HMAC: D10E8B79D511F48DAECAFB4A3D89F553A2DDB26F1614
                                    3;2;1;0;38;3.42
                                    and so on...
                                    This is the Pro MIni serial console:
                                    T: 28.00
                                    1023
                                    Battery Voltage: 3.44 V
                                    Battery percent: 102 %
                                    40413 Skipping security for command 3 type 16
                                    40421 TSF:MSG:SEND,3-3-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                    40429 Nonce requested from 0. Waiting...
                                    40546 TSF:MSG:READ,0-0-3,s=255,c=3,t=17,pt=6,l=25,sg=1:9CC096EF18295BEFAC43638CA2673A1D759B0CEC6E49C3E060
                                    40558 Skipping security for command 3 type 17
                                    40562 Nonce received from 0.
                                    40564 Proceeding with signing...
                                    Message to process: 03002EF24002
                                    Current nonce: 9CC096EF18295BEFA59B0CEC3E060AAAAAAAAAAAAAA
                                    HMAC: 5D8E8A59EF1420406004E1318A650686E19E3A8
                                    Signature in message: 018E8A5BD166D106004E
                                    40740 Message signed
                                    40749 Message to send has been signed
                                    40755 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=38,pt=7,l=5,sg=1,ft=0,st=OK:3.44
                                    40763 Skipping security for command 3 type 16
                                    40769 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                    40777 Nonce requested from 0. Waiting...
                                    40900 TSF:MSG:READ,0-0-3,s=255,c=3,t=17,pt=6,l=25,sg=1:1C17F1A31D500CB0E840B7214BE961E
                                    40910 Skipping security for command 3 type 17
                                    40916 Nonce received from 0.
                                    40919 Proceeding with signing...
                                    Message to process: 03000E66
                                    Current nonce: 1C17FE25D7B26441A31D961EAAAAAAAAAAAAAA
                                    HMAC: D5992FF4CFB6238CD4062397EEE986F47E0BD65020F39C18662
                                    Signature in message: 01992FF4CFB6238C0FDA62397EEE986F47E0
                                    41095 Message signed
                                    41101 Message to send has been signed
                                    41109 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=OK:102
                                    41115 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                    41121 MCO:SLP:TPD
                                    Are they secure communicating? :)
                                    PS I did delete some chars from the HMAC, nonces, etc etc :D
                                    • S sineverba
                                      3;0;1;0;1;59.3
                                      3;2;1;0;38;3.42
                                      and so on...
                                      T: 28.00
                                      1023
                                      41121 MCO:SLP:TPD
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @sineverba the best way to determine that is to see if the messages you send arrive :) if you enable signing and require signatures, unsigned or incorrectly signed messages will be rejected.
                                      I see no errors in the log so it seems it works. The logs however don't match up. The hmac:s in one log does not match the hmac:s in the other.
                                      S 1 Reply Last reply
                                        sineverba
                                        @Anticimex
                                        I can assure you that messages, nonces, hmacs and signatures are exactly the same in console gateway and in console of arduino mini.
                                        I did delete some chars before posting for.... security (?) :D
                                        Thank you for your answer!
                                        • S sineverba
                                          @Anticimex
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @sineverba why did you delete them? There is nothing secret about them. They are sent over your radio link so they are to be considered very public, or signing wouldn't be useful, would it? ;)
