  3. arduino mega nrf wiring
8 Posts 5 Posters 6.5k Views 5 Watching
  • Michel LallemandM
    Michel LallemandM
    Michel Lallemand
    I want to connect my nRF24L01 on my Arduino Mega created for a gateway Mysensors
    I do not know how to do ?
    thank you for your help cordially
    • Michel LallemandM Michel Lallemand
      @Michel-Lallemand the Mega has different pins for SPI. I don't have a Mega myself, but this thread should cover what you need to do.
      Please post the result here. If the instructions work, I will add them to the radio page.
      • ayoA
        ayoA
        ayo
        Just connect it like this
        That should Work.
        In your arduino code add the following before the #include <SPI.h>
        // Pin Confuguration for Arduino Mega
        #define MY_RF24_CE_PIN 40
        #define MY_RF24_CS_PIN 53
        and you are good. :)
        Edoardo MacrìE 1 Reply Last reply
        • Michel LallemandM
          Michel LallemandM
          Michel Lallemand
          thanks a lot @ayo this wiring run perfectly thanks
          • ayoA ayo
            That should Work.
            Edoardo MacrìE
            Edoardo MacrìE
            Edoardo Macrì
            wrote on last edited by Edoardo Macrì
            @ayo for me didn't worked.. maybe because i have an updated mysensor library?
            • Edoardo MacrìE Edoardo Macrì
              @Edoardo-Macrì hour you describe "not working" in more detail?
              The MySensors library has not been updated since July and even if it had been updated it should work.
              • ayoA
                ayoA
                ayo
                @Edoardo-Macrì It should work irrespective of the library version. Cross check your connection again, don't forget about capacitors too and lastly make sure you add that #define part into your code.
                • E
                  E
                  emaddoost
                  @ayo I have this problem too, I can't get the radio modules work, the modules are nRF24L01 and I have tested with two arduino nano and two Arduino mega2560, but there is no result. The transmitter and receiver can not contact each other.
