  3. Laser Christmas Light Control - 433MHZ
14 Posts 3 Posters 6.6k Views 4 Watching
  • T
    tbully
    Hello All -
    I recently purchased a pretty neat laser/projector from: http://www.laserchristmaslights.com/
    I control my annual display by a few Z-Wave Outlets/Modules and Vera Scenes. The problem with this laser (I knew this when purchasing) is that it doesn't "remember" the mode it was in prior to shutdown. While I purchased the "moving lasers" product, I knew that I initially intended to use it in its static mode to keep things less busy. The problem is it comes up in "moving mode" regardless of initial settings.
    No problem, I figured. I originally thought it was going to be an IR remote and was going to use a blaster to remind it to not move. Short of that, I also considered manually hacking the remote (bought an extra one!) and just momentarily close the button (relay, etc) to set the correct state.
    After receiving the product, I realized that it was a 433MHZ remote. I remember reading a thread by @petewill to control his RF blinds: https://forum.mysensors.org/topic/7/controlling-blinds-com-rf-dooya-motors-with-arduino-and-vera
    While I haven't completely finished sniffing the remote's traffic, I have successfully been able to "hear" it with a receiver as outlined by Pete.
    I want to mimic 7 different buttons:
    • Power (just in case I need to cycle)
    • R, G, B (turns each laser on/off to control color scenes if needed)
    • Flash (flashes all lasers - ugly but may be interesting to have control over)
    • ' - / + (controls the speed of movement from zero to "full")
    My Main Issue/Question at the Moment
    I'm not entirely clear how to present the sensor to the gateway/controller. Again, I'm using Vera and everything I'm reading at https://www.mysensors.org/download/serial_api_20#sensor-type doesn't show a clear match for what I'm trying to achieve.
    Any thoughts?
    I'm including @petewill 's thread for appropriate credit as I'm generally modeling his methods: https://forum.mysensors.org/topic/7/controlling-blinds-com-rf-dooya-motors-with-arduino-and-vera
    petewillP 1 Reply Last reply
    • T tbully
      Hello All -
      Any thoughts?
      petewillP
      petewillP
      petewill
      @tbully Cool!
      Are the RBG buttons on/off for each color or just on (which turns the others off)? If they are on/off you may want to do each color and the flash as a separate light switch. The speed and power could be a dimming light device.
        IR sensor perhaps?
        https://github.com/mysensors/Vera/tree/development/IrRecordPlayback
        • T
          tbully
          @petewill Ah! I didn't think of exposing multiple sensors/devices! Ugh! I will think on this. The problem is, each button is momentary (not a switch/dimmer) so I'm not sure I have the experience to handle that. (good with electronics - not so good in the coding world) Although, I seem to remember others talking about momentary actions in the forums..... I'm sure it has been tackled.
          @hek I didn't know about that device..... I'm going to check in to that as well.
          Thanks!
          • T
            tbully
            Well, I made some progress today. I was able to sniff the traffic, determine the pulse width, and put together a simple sketch to test it. I had to modify the antenna on the transmitter as well as the one on the receiver inside the light. I'm now able to control it from anywhere in the house. Prior, only a few feet would work.
            However, I'm still not clear on how I'll present this to the controller.
            Here are the codes for the record:
            Power= 010101101010010100000001
            Red= 010101101010010100000010
            Green= 010101101010010100001000
            Blue= 010101101010010100001110
            down = 010101101010010100000100
            up= 010101101010010100010110
            Pulse width was measured at 310 ms. However, using my ear, it sounds and works better if set at 298ms.
            Any more thoughts on the controller side? Would really be helpful. I'm just not a very creative coder.
            Thanks!
            • T
              tbully
              wrote on last edited by tbully
              I'm forging ahead with multiple switches (lights) until someone can help me think through the best way to present to the controller. I'm trying to work out the logic to simulate a button-press.
              When someone/something presses "on" in the controller, the sensor will determine which button/light was pressed, send the appropriate data and then toggle the device back off. I've never updated a switch status back to the controller. My use of "send" below is clearly invalid.
              //#define MY_REPEATER_FEATURE
              #define POWER_CONTROLLER 1
              #define RED_CONTROLLER 2
              #define GREEN_CONTROLLER 3
              #define BLUE_CONTROLLER 4
              void before() {}
              void setup() {}
                sendSketchInfo("Christmas Laser Control", "1.0");
                present (POWER_CONTROLLER, S_LIGHT);
                present (RED_CONTROLLER, S_LIGHT);
                present (GREEN_CONTROLLER, S_LIGHT);
                present (BLUE_CONTROLLER, S_LIGHT);
              void loop() {}
                if (message.type==V_LIGHT) {
                   Serial.print(message.sensor);
                   if (message.getBool()){
                     //send data for appropriate "button" and then toggle controller back to "off"/false
                     Serial.println ("Get ready to send radio message");
                      //send appropriate data here
                    if (message.sensor == POWER_CONTROLLER) {
                      Serial.println ("Sending POWER data");
                     //send 433 mhz RF data and turn switch back off
                    else if (message.sensor == RED_CONTROLLER) {
                      Serial.println ("Sending RED data");
                    else if (message.sensor == GREEN_CONTROLLER) {
                      Serial.println ("Sending GREEN data");
                    else if (message.sensor == BLUE_CONTROLLER) {
                      Serial.println ("Sending BLUE data");
                  //   delay (1000);
                  //   send(message.set(0));
                  // Store state in eeprom
                 // saveState(message.sensor, message.getBool());
              • T tbully
                void before() {}
                void setup() {}
                void loop() {}
                    //   delay (1000);
                petewillP
                petewillP
                petewill
                @tbully When you say controller, are you referring to the remote control or your home automation controller? If it's the remote control it will be difficult to get the commands from that. For my blinds, I don't use them. All controlling is done through my HA controller. If you do it this way your status will always be correct at your HA controller.
                T 1 Reply Last reply
                • petewillP petewill
                  tbully
                  @petewill Good question. I meant the home controller. The remote is completely out of the picture now. Using your ideas, I was able to figure out all the codes and can send them successfully via a test script. The hard part is done, ironically!
                  I'm just not a great code guy.....
                  I haven't put that logic in to my script yet. Instead, I'm trying to figure out how to "bounce" a light switch. When the home automation controller sends an "on" for a certain function, I'll send the RF data and then switch it back "off" to be ready for the next command/"button press" later. That's the part I'm having trouble with....
                  • T tbully
                    petewillP
                    petewillP
                    petewill
                    @tbully I'm not exactly sure what your lights require but why do you need to send the off command to be read for the next command? With my blinds I just send the Up command then wait for the next command to come in. When I receive the down command I send that.
                      tbully
                      @petewill Because when the V_LIGHT sensor is switched "on" in Vera, I will fall in to the proper "if" condition above. However, I need to switch it back off after I send the data so I can later toggle it again. I wish there was a "button device" so I didn't have to worry about it.
                      0_1475431621870_upload-cc34bba7-207c-436e-9228-da1beeb24bc8
                      • T
                        tbully
                        With the help of @petewill in a chat session, I was able to figure out why I couldn't send messages back.
                        I was failing to instantiate:
                        MyMessage msg(RED_CONTROLLER,S_LIGHT);
                        I'm only concentrating on the "red" case at the moment. As you can see from the log, I'm sending a "0" back to Vera but Vera is not showing off in the console. ** Am I not resetting the state correctly?**
                        0_1475434817226_upload-514b4107-7699-4c4b-8239-77ef99d97078
                        Incoming change for sensor:2, New status: 1
                        Sending RED data
                        Turn RED_CONTROLLER off in Vera
                        TSP:MSG:SEND 1-1-6-0 s=2,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=ok:0
                        bool state;
                        void before() {
                        void setup() {}
                         // if (state) {
                         //   Serial.println("State is true");
                            //send(msg.set(state?false:true), false); // Send new state and request ack back
                           // send(msg.setSensor(RED_CONTROLLER).set(0));
                         //   state = false;
                          if (message.isAck()) {
                                //send data here
                                wait (5000);
                                Serial.println ("Turn RED_CONTROLLER off in Vera");
                        • petewillP
                          petewillP
                          petewill
                          You're almost there! You need to change this line:
                          to this
                          MyMessage msg(RED_CONTROLLER,V_LIGHT);
                            to this
                            tbully
                            @petewill ARGH! Of course! That was it! OK, this should get me going for a bit. Thanks so much!
                            I will work on this more and report back! Love these forums and how helpful they are. Hopefully, I will be able to return the favor someday!
                            • T
                              tbully
                              I thought I'd report back with my code. The sensor is up and running. I don't like that I just had to present switches but I'm not skilled enough to use the "custom" field and make a control in Vera. (On/Off, Blue, Red, Green, Motion) So this will have to do for now. It's probably OK as I'm just going to use automation to actuate the switches.
                               *Power=  010101101010010100000001
                               *Red=  010101101010010100000010
                               *Green=  010101101010010100001000
                               *Blue= 010101101010010100001110
                               *down =  010101101010010100000100
                               *up= 010101101010010100010110
                              Decimal: 5678338 (24Bit) Binary: 010101101010010100000010 Tri-State: not applicable PulseLength: 310 microseconds Protocol: 1
                              Raw data: 9624,192,1032,808,416,232,988,840,384,256,964,872,360,876,340,288,936,884,336,288,936,888,336,284,936,284,940,884,340,284,936,884,340,284,936,288,936,284,940,284,936,284,940,284,936,884,336,288,936,
                              #include <RCSwitch.h>
                              #define POWER_BUTTON 1
                              #define RED_BUTTON 2
                              #define GREEN_BUTTON 3
                              #define BLUE_BUTTON 4
                              #define NoMotion_BUTTON 5
                              #define MedMotion_BUTTON 6
                              #define FastMotion_BUTTON 7
                              unsigned long delay_time = 500;
                              bool state;
                              MyMessage msg_power(POWER_BUTTON,V_LIGHT);
                              MyMessage msg_red(RED_BUTTON,V_LIGHT);
                              MyMessage msg_green(GREEN_BUTTON,V_LIGHT);
                              MyMessage msg_blue(BLUE_BUTTON,V_LIGHT);
                              MyMessage msg_NoMotion(NoMotion_BUTTON,V_LIGHT);
                              MyMessage msg_MedMotion(MedMotion_BUTTON,V_LIGHT);
                              MyMessage msg_FastMotion(FastMotion_BUTTON,V_LIGHT);
                              RCSwitch mySwitch = RCSwitch();
                              void before() {
                                mySwitch.enableTransmit(8);
                                mySwitch.setPulseLength(298);
                                mySwitch.setRepeatTransmit(2);
                                present (POWER_BUTTON, S_LIGHT);
                                present (RED_BUTTON, S_LIGHT);
                                present (GREEN_BUTTON, S_LIGHT);
                                present (BLUE_BUTTON, S_LIGHT);
                                present (NoMotion_BUTTON, S_LIGHT);
                                present (MedMotion_BUTTON, S_LIGHT);
                                present (FastMotion_BUTTON, S_LIGHT);
                               // if (state) {
                               //   state = false;
                                    if (message.sensor == POWER_BUTTON) {
                                      mySwitch.send("010101101010010100000001");
                                      Serial.println ("Turn POWER_BUTTON off in Vera");
                                      send(msg_power.setSensor(POWER_BUTTON).set(0), true);
                                    else if (message.sensor == RED_BUTTON) {
                                      mySwitch.send("010101101010010100000010");
                                      Serial.println ("Turn RED_BUTTON off in Vera");
                                      send(msg_red.setSensor(RED_BUTTON).set(0), true);
                                    else if (message.sensor == GREEN_BUTTON) {
                                      mySwitch.send("010101101010010100001000");
                                      Serial.println ("Turn GREEN_BUTTON off in Vera");
                                      send(msg_green.setSensor(GREEN_BUTTON).set(0), true);
                                    else if (message.sensor == BLUE_BUTTON) {
                                      mySwitch.send("010101101010010100001110");
                                      Serial.println ("Turn BLUE_BUTTON in Vera");
                                      send(msg_blue.setSensor(BLUE_BUTTON).set(0), true);
                                    else if (message.sensor == NoMotion_BUTTON) {
                                      Serial.println ("Sending No Motion data");
                                      mySwitch.send("010101101010010100000100");
                                      delay(delay_time);
                                      delay(delay_time);
                                      Serial.println ("Turn No Motion in Vera");
                                      send(msg_blue.setSensor(NoMotion_BUTTON).set(0), true);
                                    else if (message.sensor == MedMotion_BUTTON) {
                                      Serial.println ("Sending Medium Motion data");
                                      mySwitch.send("010101101010010100000100");//down
                                      delay(delay_time);
                                      delay(delay_time);
                                      mySwitch.send("010101101010010100010110");//up
                                      Serial.println ("Turn Medium Motion in Vera");
                                      send(msg_blue.setSensor(MedMotion_BUTTON).set(0), true);
                                    else if (message.sensor == FastMotion_BUTTON) {
                                      Serial.println ("Sending Fast Motion data");
                                      delay(delay_time);
                                      delay(delay_time);
                                      Serial.println ("Turn Fast Motion in Vera");
                                      send(msg_blue.setSensor(FastMotion_BUTTON).set(0), true);
