  3. My Sesnor DHT - can't upload to Uno
9 Posts 3 Posters 5.4k Views 2 Watching
  • robertmtR
    robertmtR
    robertmt
    Hello.
    I'm trying to upload a example sketch from mysensors.org and I have this error... Reinstalled Arduino, downloaded DHT libraries and still nothing....
    This is error:
    DHTSensor:41: error: no matching function for call to 'DHT::DHT()'
    DHT dht;
    D:\Arduino\DHTSensor\DHTSensor.ino:41:5: note: candidates are:
    In file included from D:\Arduino\DHTSensor\DHTSensor.ino:12:0:
    C:\Users\Robert\Documents\Arduino\libraries\DHT_sensor_library/DHT.h:40:4: note: DHT::DHT(uint8_t, uint8_t, uint8_t)
    DHT(uint8_t pin, uint8_t type, uint8_t count=6);
    C:\Users\Robert\Documents\Arduino\libraries\DHT_sensor_library/DHT.h:40:4: note: candidate expects 3 arguments, 0 provided
    C:\Users\Robert\Documents\Arduino\libraries\DHT_sensor_library/DHT.h:38:7: note: constexpr DHT::DHT(const DHT&)
    class DHT {
    C:\Users\Robert\Documents\Arduino\libraries\DHT_sensor_library/DHT.h:38:7: note: candidate expects 1 argument, 0 provided
    C:\Users\Robert\Documents\Arduino\libraries\DHT_sensor_library/DHT.h:38:7: note: constexpr DHT::DHT(DHT&&)
    D:\Arduino\DHTSensor\DHTSensor.ino: In function 'void setup()':
    DHTSensor:59: error: 'class DHT' has no member named 'setup'
    DHTSensor:60: error: 'class DHT' has no member named 'getMinimumSamplingPeriod'
    DHTSensor:65: error: 'class DHT' has no member named 'getMinimumSamplingPeriod'
    D:\Arduino\DHTSensor\DHTSensor.ino: In function 'void loop()':
    DHTSensor:72: error: 'class DHT' has no member named 'readSensor'
    dht.readSensor(true);
    DHTSensor:75: error: 'class DHT' has no member named 'getTemperature'
    DHTSensor:82: error: 'class DHT' has no member named 'toFahrenheit'
    DHTSensor:99: error: 'class DHT' has no member named 'getHumidity'
    exit status 1
    Please help!!!
    • sundberg84S
      It really looks like it cant find the DHT library... or you have the wrong lib installed.
      Open the dht.cpp file in notepad and see if you find the functions like getTemperature() and so on.
      • robertmtR
        robertmtR
        robertmt
        Can't see getTemperature in dht.cpp. There is "readTemperature", "readHumidity" etc... but nothing like "get"
        • robertmtR robertmt
          @robertmt - then you are using the wrong DHTlib.
          Download it from Mysensors github and use the example sketch and it will work:
          https://github.com/mysensors/MySensorsArduinoExamples
          there is a getTemperature() in this lib.
          • robertmtR
            robertmtR
            robertmt
            Thanks... it helped a bit. No more DHT error... but now:
            avr-g++: error: CreateProcess: No such file or directory
            exit status 1
            Error compiling for board Arduino/Genuino Uno.
            Invalid version found: 1.04
            • robertmtR
              robertmtR
              robertmt
              I'm lost....
              I've installed Arduino ver 1.6.6 than I had an error :+1:
              avr-g++: error: missing filename after '-o'
              removed everything and installed ver. 1.6.12 ... libraries from github:
              everything inside:
              C:\Users\Robert\Documents\Arduino\libraries\MySensors
              now error:
              C:\Users\Robert\Documents\Arduino\libraries\MySensors\examples\DhtTemperatureAndHumiditySensor\DhtTemperatureAndHumiditySensor.ino:44:17: fatal error: DHT.h: No such file or directory
              #include <DHT.h>
              compilation terminated.
              exit status 1
              • robertmtR
                robertmtR
                robertmt
                hello again:
                my latest trial gave me something like this:
                exit status 1
                anyone???
                • robertmtR
                  robertmtR
                  robertmt
                  Ok... Looks like issue was with windows and some SH...T in AppData and Temp...
                  Removed everything related with arduino and maneged to upload a sketch.
                  (Maybe somebody else will have a same issue)
                  Only one thing left, this:
                  Any idea what can it be? My Arduino IDE is 1.6.12 on Windows 7.
                  Thanks in advance
                  clio75C 1 Reply Last reply
                    Thanks in advance
                    clio75C
                    clio75C
                    clio75
                    @robertmt Yes I have similar problems :/
                    But have not had the time to look into this yet.
                    Hopefully later today (or maybe closer to the weekend)
