  3. [SOLVED]TSM:CHKID:FAIL between serial gateway and node
3 Posts 2 Posters 1.5k Views 2 Watching
  • hannibalH
    hannibalH
    hannibal
    wrote on last edited by hannibal
    Hi everybody,
    I have a trouble with a temperature node.
    Is it my first step with MySensor, so I'm trying to make somethings very easy for understand how all works.
    So I have deploy a serial Gateway on a Arduino Uno With a NRF24L01+ and a node with a dallas temp sensor.(mount on this PCB https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors )
    Programs used here are just the mysensor examples.
    In the Gateway log, all seems normal
    ------- Gateway log -------
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
    0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
    0;255;3;0;9;TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    But in the node log I have an error
    ------- Node log -------
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSM:ID
    TSM:ID
    TSM:ID
    !TSM:CHKID:FAIL (ID=255)
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    I have tried to find the explanation of this problem but I didn't find it in the documentation:
    https://ci.mysensors.org/job/Verifiers/job/MySensorsArduino/branch/development/Doxygen_HTML/group__MyTransportgrp.html
    So do you knows a solution of my problem ?
    I did something stupid ?
    Thanks in advance for your help
    Ps: Sorry for my english, I'm learning it ;)
    • Alex PopovskiyA
      Alex PopovskiyA
      Alex Popovskiy
      Hi, It seems that you are using ID 255 for your temp node, but ID's 0 and 255 are reserved for gateway id and broadcast. Also, if not using any controller, you should manually assingn ID to sensor nodes in a sketch, like that:
      #define MY_NODE_ID 10
      • hannibalH
        hannibalH
        hannibal
        It's working thanks ;)
        For now I didn't have any controller that is the problem.
        With your small code, it's working.
        Thanks ;)
