  3. [SOLVED] GatewayESP8266MQTTClient node reboots permanently as soon as MyController activates it as gateway
3 Posts 2 Posters 1.7k Views 1 Watching
  • DerTommD
    DerTommD
    DerTomm
    Hi everyone,
    up to now I used MySensors release 2.0.1-beta together with Arduino µCs and nRF24L01+ modules which works fine. Thanks to all developers and supporters for this great project.
    Today I tried to include an ESP8266 node (ESP-01 module with a Dallas temperature sensor attached) into my network. I chose the GatewayESP8266MQTTClient sketch from the examples folder and adapted it to my Wifi network. The communication with the MQTT broker works flawlessly so far. After powering the node it transmits its meta/vital data and the temperature value:
    ;MCO:BGN:INIT GW,CP=R-NGE--,VER=2.0.1-beta
    scandone
    f 0, scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    connected with Kumanet, channel 6
    ip:192.168.64.99,mask:255.255.255.0,gw:192.168.64.253
    chg_B1:-40
    .IP: 192.168.64.99
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
    IP: 192.168.64.99
    chg_B1:-80
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/255/0/0/17
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/255/3/0/11
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/255/3/0/12
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/0/0/0/6
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/0/1/0/0
    chg_B1:-120
    pm open,type:2 0
    The problems starts as soon as I register the node in MyController as MQTT gateway:
    As soon as I enable the newly added gateway the ESP8266 sensor node reboots and goes into a boot loop:
    chg_B1:-40
    .IP: 192.168.64.99
    IP: 192.168.64.99
    chg_B1:-80
    chg_B1:-120
    pm open,type:2 0
    IP: 192.168.64.99
    IP: 192.168.64.99
    IP: 192.168.64.99
    IP: 192.168.64.99
    Unfortunately there are no further debug outputs. Neither on MySensors side nor on MyController side. As far as I see MyController does not send any MQTT messages at any time.
    Is it possible that the sensor node reboots because it does not get any responses? But why aren't there any reboots if the node is not an enabled gateway in MyController? There must be any non-visible communication which causes the reboots...
    Did anybody include a GatewayESP8266MQTTClient successfully into MyController yet?
    The MQTT broker is Mosquitto by the way, hostet on the same server as MyController.
    This is my sketch:
    #include <Arduino.h>
    #include <EEPROM.h>
    #define MY_BAUD_RATE 115200
    #define MY_NODE_ID 4
    #define MY_PARENT_NODE_ID 0
    #define MY_GATEWAY_ESP8266
    // Set MQTT client id
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "Kumanet"
    #define MY_ESP8266_PASSWORD "<<REMOVED>>"
    #define MY_IP_ADDRESS 192,168,64,99
    #define MY_IP_GATEWAY_ADDRESS 192,168,64,253
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 64, 253
    #define MY_PORT 1883
    #include <ESP8266WiFi.h>
    #include <OneWire.h>
    #define ONE_WIRE_BUS 0
    OneWire oneWire(ONE_WIRE_BUS);
    #define CHILD_ID_TEMPERATURE        0
    MyMessage msgTemperature(CHILD_ID_TEMPERATURE, V_TEMP);
    unsigned long lastSent = 0;
      sensors.begin();
    void presentation() {
      sendSketchInfo("ESP8266TempSensor", "0.9");
      present(CHILD_ID_TEMPERATURE, S_TEMP);
      sensors.requestTemperatures(); // Send the command to get temperatures
      delay(50);
      send(msgTemperature.set(sensors.getTempCByIndex(0), 1));
      delay(10000);
    • E
      E
      ericvdb
      wrote on last edited by ericvdb
      try changing to something like
      #define MY_MQTT_CLIENT_ID "mywifinode-1"
      You are using the same client ID on both controller and node
      • DerTommD
        DerTommD
        DerTomm
        Thanks - that solved the problem!
