MoteinoMEGA on 2.0.1 error compiling
Hello.
I cannot compile a standard GW sketch on 2.0.1b for MoteinoMEGA. It does compile for Moteino though.
This is the error message:Arduino: 1.6.9 (Windows 10), Board: "MoteinoMEGA" In file included from C:\Users\Alex\AppData\Local\Temp\build7dc6f2b63c7f50e674134238335fb178.tmp\sketch\GatewaySerial-2.0.1b.ino.cpp:1:0: C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyLeds.cpp: In function 'void ledsProcess()': C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:154: error: '__digitalPinToPortReg' was not declared in this scope #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:30: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:117: note: in expansion of macro 'bitWrite' #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:61:40: note: in expansion of macro 'digitalWriteFast' #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyLeds.cpp:66:5: note: in expansion of macro 'hwDigitalWrite' hwDigitalWrite(MY_DEFAULT_RX_LED_PIN, state); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:180: error: '__digitalPinToBit' was not declared in this scope #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:49: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:117: note: in expansion of macro 'bitWrite' #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:61:40: note: in expansion of macro 'digitalWriteFast' #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyLeds.cpp:66:5: note: in expansion of macro 'hwDigitalWrite' hwDigitalWrite(MY_DEFAULT_RX_LED_PIN, state); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp: In member function 'bool RFM69::initialize(uint8_t, uint8_t, uint8_t)': C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:154: error: '__digitalPinToPortReg' was not declared in this scope #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:30: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:117: note: in expansion of macro 'bitWrite' #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:61:40: note: in expansion of macro 'digitalWriteFast' #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:90:3: note: in expansion of macro 'hwDigitalWrite' hwDigitalWrite(_slaveSelectPin, HIGH); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:180: error: '__digitalPinToBit' was not declared in this scope #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:49: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:117: note: in expansion of macro 'bitWrite' #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:61:40: note: in expansion of macro 'digitalWriteFast' #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:90:3: note: in expansion of macro 'hwDigitalWrite' hwDigitalWrite(_slaveSelectPin, HIGH); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:172: error: '__digitalPinToDDRReg' was not declared in this scope #define pinModeFast(__pin, __mode) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__mode) && (__mode!=INPUT_PULLUP)) { bitWrite(*__digitalPinToDDRReg(__pin), __digitalPinToBit(__pin), (__mode)); } else { pinMode((__pin), (__mode)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:30: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:136: note: in expansion of macro 'bitWrite' #define pinModeFast(__pin, __mode) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__mode) && (__mode!=INPUT_PULLUP)) { bitWrite(*__digitalPinToDDRReg(__pin), __digitalPinToBit(__pin), (__mode)); } else { pinMode((__pin), (__mode)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:63:35: note: in expansion of macro 'pinModeFast' #define hwPinMode(__pin, __value) pinModeFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:91:3: note: in expansion of macro 'hwPinMode' hwPinMode(_slaveSelectPin, OUTPUT); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:198: error: '__digitalPinToBit' was not declared in this scope #define pinModeFast(__pin, __mode) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__mode) && (__mode!=INPUT_PULLUP)) { bitWrite(*__digitalPinToDDRReg(__pin), __digitalPinToBit(__pin), (__mode)); } else { pinMode((__pin), (__mode)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:49: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:136: note: in expansion of macro 'bitWrite' #define pinModeFast(__pin, __mode) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__mode) && (__mode!=INPUT_PULLUP)) { bitWrite(*__digitalPinToDDRReg(__pin), __digitalPinToBit(__pin), (__mode)); } else { pinMode((__pin), (__mode)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:63:35: note: in expansion of macro 'pinModeFast' #define hwPinMode(__pin, __value) pinModeFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:91:3: note: in expansion of macro 'hwPinMode' hwPinMode(_slaveSelectPin, OUTPUT); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp: In member function 'virtual void RFM69::sendFrame(uint8_t, const void*, uint8_t, bool, bool)': C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:94:114: error: '__digitalPinToPINReg' was not declared in this scope #define digitalReadFast(__pin) ( (bool) (__builtin_constant_p(__pin) ) ? (( bitRead(*__digitalPinToPINReg(__pin), __digitalPinToBit(__pin))) ) : digitalRead((__pin)) ) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:111:32: note: in definition of macro 'bitRead' #define bitRead(value, bit) (((value) >> (bit)) & 0x01) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:62:30: note: in expansion of macro 'digitalReadFast' #define hwDigitalRead(__pin) digitalReadFast(__pin) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:338:10: note: in expansion of macro 'hwDigitalRead' while (hwDigitalRead(_interruptPin) == 0 && millis() - txStart < RF69_TX_LIMIT_MS) {} // wait for DIO0 to turn HIGH signalling transmission finish ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:94:140: error: '__digitalPinToBit' was not declared in this scope #define digitalReadFast(__pin) ( (bool) (__builtin_constant_p(__pin) ) ? (( bitRead(*__digitalPinToPINReg(__pin), __digitalPinToBit(__pin))) ) : digitalRead((__pin)) ) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:111:43: note: in definition of macro 'bitRead' #define bitRead(value, bit) (((value) >> (bit)) & 0x01) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:62:30: note: in expansion of macro 'digitalReadFast' #define hwDigitalRead(__pin) digitalReadFast(__pin) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:338:10: note: in expansion of macro 'hwDigitalRead' while (hwDigitalRead(_interruptPin) == 0 && millis() - txStart < RF69_TX_LIMIT_MS) {} // wait for DIO0 to turn HIGH signalling transmission finish ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp: In member function 'virtual void RFM69::select()': C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:154: error: '__digitalPinToPortReg' was not declared in this scope #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:30: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:117: note: in expansion of macro 'bitWrite' #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:61:40: note: in expansion of macro 'digitalWriteFast' #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:488:3: note: in expansion of macro 'hwDigitalWrite' hwDigitalWrite(_slaveSelectPin, LOW); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:180: error: '__digitalPinToBit' was not declared in this scope #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:49: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:117: note: in expansion of macro 'bitWrite' #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:61:40: note: in expansion of macro 'digitalWriteFast' #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:488:3: note: in expansion of macro 'hwDigitalWrite' hwDigitalWrite(_slaveSelectPin, LOW); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp: In member function 'virtual void RFM69::unselect()': C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:154: error: '__digitalPinToPortReg' was not declared in this scope #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:30: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:117: note: in expansion of macro 'bitWrite' #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:61:40: note: in expansion of macro 'digitalWriteFast' #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:493:3: note: in expansion of macro 'hwDigitalWrite' hwDigitalWrite(_slaveSelectPin, HIGH); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:180: error: '__digitalPinToBit' was not declared in this scope #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:49: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:117: note: in expansion of macro 'bitWrite' #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:61:40: note: in expansion of macro 'digitalWriteFast' #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:493:3: note: in expansion of macro 'hwDigitalWrite' hwDigitalWrite(_slaveSelectPin, HIGH); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp: In member function 'void RFM69::setCS(uint8_t)': C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:154: error: '__digitalPinToPortReg' was not declared in this scope #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:30: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:117: note: in expansion of macro 'bitWrite' #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:61:40: note: in expansion of macro 'digitalWriteFast' #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:530:3: note: in expansion of macro 'hwDigitalWrite' hwDigitalWrite(_slaveSelectPin, HIGH); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:180: error: '__digitalPinToBit' was not declared in this scope #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:49: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:117: note: in expansion of macro 'bitWrite' #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(*__digitalPinToPortReg(__pin), __digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:61:40: note: in expansion of macro 'digitalWriteFast' #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:530:3: note: in expansion of macro 'hwDigitalWrite' hwDigitalWrite(_slaveSelectPin, HIGH); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:172: error: '__digitalPinToDDRReg' was not declared in this scope #define pinModeFast(__pin, __mode) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__mode) && (__mode!=INPUT_PULLUP)) { bitWrite(*__digitalPinToDDRReg(__pin), __digitalPinToBit(__pin), (__mode)); } else { pinMode((__pin), (__mode)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:30: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:136: note: in expansion of macro 'bitWrite' #define pinModeFast(__pin, __mode) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__mode) && (__mode!=INPUT_PULLUP)) { bitWrite(*__digitalPinToDDRReg(__pin), __digitalPinToBit(__pin), (__mode)); } else { pinMode((__pin), (__mode)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:63:35: note: in expansion of macro 'pinModeFast' #define hwPinMode(__pin, __value) pinModeFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:531:3: note: in expansion of macro 'hwPinMode' hwPinMode(_slaveSelectPin, OUTPUT); ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:198: error: '__digitalPinToBit' was not declared in this scope #define pinModeFast(__pin, __mode) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__mode) && (__mode!=INPUT_PULLUP)) { bitWrite(*__digitalPinToDDRReg(__pin), __digitalPinToBit(__pin), (__mode)); } else { pinMode((__pin), (__mode)); } } while (0) ^ C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\cores\arduino/Arduino.h:112:49: note: in definition of macro 'bitSet' #define bitSet(value, bit) ((value) |= (1UL << (bit))) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:136: note: in expansion of macro 'bitWrite' #define pinModeFast(__pin, __mode) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__mode) && (__mode!=INPUT_PULLUP)) { bitWrite(*__digitalPinToDDRReg(__pin), __digitalPinToBit(__pin), (__mode)); } else { pinMode((__pin), (__mode)); } } while (0) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/core/MyHwATMega328.h:63:35: note: in expansion of macro 'pinModeFast' #define hwPinMode(__pin, __value) pinModeFast(__pin, __value) ^ C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/RFM69/RFM69.cpp:531:3: note: in expansion of macro 'hwPinMode' hwPinMode(_slaveSelectPin, OUTPUT); ^ -
Looks like 1284p defines are missing in digitalWriteFast.h
that should be fixed soon..bug reported ;) or i will look asap pin mapping of 1284.. -
I'm using beta from Yesterday (23Nov2016), still an issue...
Made these changes in: digitalWriteFast.h to get started as the 644 and 1284 have the same pinout.
#elif defined(__AVR_ATmega644__) || defined(__AVR_ATmega644P__) || defined(__AVR_ATmega1284__) || defined(__AVR_ATmega1284P__) #define __digitalPinToPortReg(__pin) (((__pin) <= 7) ? &PORTB : (((__pin) >= 8 && (__pin) <= 15) ? &PORTD : (((__pin) >= 16 && (__pin) <= 23) ? &PORTC : &PORTA))) #define __digitalPinToDDRReg(__pin) (((__pin) <= 7) ? &DDRB : (((__pin) >= 8 && (__pin) <= 15) ? &DDRD : (((__pin) >= 8 && (__pin) <= 15) ? &DDRC : &DDRA))) #define __digitalPinToPINReg(__pin) (((__pin) <= 7) ? &PINB : (((__pin) >= 8 && (__pin) <= 15) ? &PIND : (((__pin) >= 8 && (__pin) <= 15) ? &PINC : &PINA))) #define __digitalPinToBit(__pin) (((__pin) <= 7) ? (__pin) : (((__pin) >= 8 && (__pin) <= 15) ? (__pin) - 8 : (((__pin) >= 16 && (__pin) <= 23) ? (__pin) - 16 : (__pin) - 24)))But now I get:
"digitalPinToInterrupt" not defined
This function seem to be defined for a RPI, but I'm using a MoteinoMEGA, so something is still wrong. I just deleted the function call for now. Not needed on Arduino.
I think i still get the same "digitalPinToInterrupt" compile error as @lafleur (has 2.1.1 fixed this for you?) with MoteinoMega but im now on Mysensors 2.1.1
Im trying a RFM95MQTTGateway.In the sketch i have defined:
#define MY_RFM95_SPI_CS 4 #define MY_RFM95_IRQ_PIN 2In file included from C:\Program Files (x86)\Arduino\libraries\MySensors/MySensors.h:304:0, from C:\Users\somewhere..........Node101Motion_rfm95v1test.ino:54: C:\Program Files (x86)\Arduino\libraries\MySensors/drivers/RFM95/RFM95.cpp: In function 'bool RFM95_initialise(float)': C:\Program Files (x86)\Arduino\libraries\MySensors/drivers/RFM95/RFM95.cpp:165:60: error: 'digitalPinToInterrupt' was not declared in this scope _SPI.usingInterrupt(digitalPinToInterrupt(MY_RFM95_IRQ_PIN));``` -
@Tris yes, there is still an issue with RFM95 and ATmega1284(P) - hopefully will be dealt with in the next release
