  3. Domoticz
  4. S_WATER_QUALITY (Unknown)
3 Posts 2 Posters 1.7k Views 1 Watching
  • mikeSM
    mikeSM
    mikeS
    Can anyone else confirm that this actually works in domoticz? It says it's supported, but when I use the ph example sketch the node and child is seen by the gateway but where it should say S_WATER_QUALITY for the child type it just says unknown!, but according to the controller page domoticz should support this.
    • sundberg84S
      @mikeS Looks like it in the latest code.
      Do you use latest stable release? Maybe it wanst implemented...
      S_WATER_QUALITY = 39, //!< V_TEMP, V_PH, V_ORP, V_EC, V_STATUS
      Do you send any status using the V_ above?
      https://github.com/domoticz/domoticz/blob/master/hardware/MySensorsBase.cpp#L1037
      mikeSM 1 Reply Last reply
      • sundberg84S sundberg84
        mikeSM
        mikeSM
        mikeS
        @sundberg84
        Thanks I thought it should work, so I need to change my version of that .cpp file to the one in the link or install some beta version of Domoticz then??
