  3. Issues dallas sensor and sketch
4 Posts 3 Posters 1.6k Views 3 Watching
  • pkriekP
    pkriekP
    pkriek
    Hi
    I have made multiple senors using the sketechs and fantastic site. I only have issues with the Dallas tempertatue sensors to get them working.
    I attached 2 dallas sensors to an arduino pro mini 3.3 v. I used the sketch that is provided on the site.
    prblem that it works sometimes for 1 sensors, some times 2. So I replaced both sesnors, and now I cant get an reading at al.
    Thru the serial monitor I see most of the times 1 sensors, it alsoshows up in domoticz, but is not reporting. So it seems very intermittenmd working.
    Can it be the pullup resistor? I use the 3.3 v from the arduino itself.
    thanks for helping
    • A
      A
      Affe
      Have you restore the EERPOM memory ?
       * This sketch clears radioId, relayId and other routing information in EEPROM back to factory default
      // load core modules only
      #define MY_CORE_ONLY
      #include <EEPROM.h>
        Serial.begin(MY_BAUD_RATE);
        Serial.println("Started clearing. Please wait...");
        for (int i=0;i<EEPROM_LOCAL_CONFIG_ADDRESS;i++) {
          hwWriteConfig(i,0xFF);
        Serial.println("Clearing done. You're ready to go!");
        // Nothing to do here...
      #include <EEPROM.h>
      • pkriekP
        pkriekP
        pkriek
        Hi
        With a new one,not soldered, but attached to teh clamps, it is working. This gives two posible exolanations:
        • the dalls sensor breaks easilly when soldered, can not have high temps.
        • I had a very bad packages . 3 from 10 pieces working.
        Patrikc
        • A
          A
          Alexander Voronin
          Have similar issue while connect 1-wire sensors to pins 4 (power) and 5 (data) for low energy sensor.
          Looks like at least pin 5 used internally (as LED ?) by MySensors and broke 1-wire i/o.
          After moving 1-wire "data" pin to "A1" and hardwire "power" pin to "VCC" I have no issues with DS18B20. But about 3.5uA per sensor more in sleep (11-12uA instead of 4.7).
          BTW: still have issue with node registration and/or other connection issues - after approx. 2 days node whan't to send data to gateway... Will debug later.
          PS: MySensors v2.0 from Arduino Lib manager, Arduino Pro Mini 3.3V@8MHz@4.1VLiPo
