  3. Vera
  4. Veralite Gateway Issues
3 Posts 2 Posters 1.5k Views 2 Watching
  • ramoncarranzaR
    ramoncarranzaR
    ramoncarranza
    Hi, I have the same issue. I installed the plugin and serial Gateway with no apparent issues, but can't add any sensors. I have triple-checked the wiring on the sensors and gateway with no success. One thing I have notice some of the Arduino LUUP Files on Vera display the following message when you open/view them.
    This page contains the following errors:
    error on line 1 at column 1: Document is empty
    Below is a rendering of the page up to the first error.
    BartEB 1 Reply Last reply
    • ramoncarranzaR ramoncarranza
      BartEB
      BartEB
      BartE
      @ramoncarranza you might need to upload all empty files again they should not be empty
      And can you be a bit more specific about "the same issue" ? What issue are you referring to?
      ramoncarranzaR 1 Reply Last reply
      • BartEB BartE
        ramoncarranzaR
        ramoncarranzaR
        ramoncarranza
        @BartE
        Sorry Bart somehow I posted this as a topic instead of a reply but here is the thread
        https://forum.mysensors.org/topic/4387/ui5-mysensors-library-2-0-gateway-issues/7
