  3. Upgrading to 2.0 with whitelisting: !TSP:MSG
1 Posts 1 Posters 591 Views 1 Watching
  • S
    Sateetje
    wrote on last edited by Sateetje
    I've a node in my split unit air conditioner to control my airco with Domoticz. The node communicates through a repeater.
    I want to use whitelisting, so upgraded from 1.5 to 2.0. Everything seems fine, I could send messages from the gateway to the node. But... I get a !TSP:MSG message in the log file.
    Two questions:
    1. Is this normal, see logs below
    2. Is the whitelisting working/active (including signing, when I change the serial, I'll get a signing error)?
    Configuration node:
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x4D,0x8E,0x8F,0x89,0x60,0x34,0x8F,0xCC,0x43}}}
    #define MY_NODE_ID 40
    #define MY_PARENT_NODE_ID 10 //Repeater 1
    //#define MY_PARENT_NODE_ID 11 //Repeater 2
    Configuration gateway:
    Used SecurityPersonalizer to set HMAC, AES and a new Serial on gateway and airco-node (HMAC and AES are the same).
    Log repeater:
    TSP:MSG:READ 0-0-40 s=0,c=3,t=16,pt=0,l=0,sg=1:
    TSP:MSG:REL MSG
    TSP:MSG:SEND 0-10-40-40 s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=ok:
    TSP:MSG:READ 40-40-0 s=255,c=3,t=17,pt=6,l=25,sg=0:61228E563AE82E62E583A693BE93AAAD49CFA30DBBDB661754
    TSP:MSG:REL MSG
    TSP:MSG:SEND 40-10-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=ok:61228E563AE82E62E583A693BE93AAAD49CFA30DBBDB661754
    TSP:MSG:READ 0-0-40 s=0,c=1,t=2,pt=0,l=1,sg=1:1
    TSP:MSG:REL MSG
    TSP:MSG:SEND 0-10-40-40 s=0,c=1,t=2,pt=0,l=1,sg=1,ft=0,st=ok:1
    TSP:MSG:READ 40-40-0 s=0,c=1,t=2,pt=0,l=1,sg=0:1
    TSP:MSG:REL MSG
    !TSP:MSG:SEND 40-10-0-0 s=0,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=fail:1
    TSP:MSG:READ 40-40-0 s=1,c=2,t=47,pt=0,l=0,sg=0:
    TSP:MSG:REL MSG
    TSP:MSG:SEND 40-10-0-0 s=1,c=2,t=47,pt=0,l=0,sg=0,ft=1,st=ok:
    TSP:MSG:READ 0-0-40 s=1,c=3,t=16,pt=0,l=0,sg=1:
    TSP:MSG:REL MSG
    TSP:MSG:SEND 0-10-40-40 s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=ok:
    TSP:MSG:READ 40-40-0 s=255,c=3,t=17,pt=6,l=25,sg=0:23EDB656448AE71910C5299C36845AFBE97173826B337A0436
    TSP:MSG:REL MSG
    TSP:MSG:SEND 40-10-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=ok:23EDB656448AE71910C5299C36845AFBE97173826B337A0436
    TSP:MSG:READ 0-0-40 s=1,c=2,t=47,pt=0,l=8,sg=1:01202216
    TSP:MSG:REL MSG
    TSP:MSG:SEND 0-10-40-40 s=1,c=2,t=47,pt=0,l=8,sg=1,ft=0,st=ok:01202216
    TSP:MSG:READ 40-40-0 s=0,c=1,t=2,pt=2,l=2,sg=0:0
    TSP:MSG:REL MSG
    TSP:MSG:SEND 40-10-0-0 s=0,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
    Log node startup:
    Starting sensor (RNNNAS, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=40)
    TSM:FPAR
    TSP:MSG:SEND 40-40-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-40 s=255,c=3,t=8,pt=1,l=1,sg=1:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSP:MSG:READ 10-10-40 s=255,c=3,t=8,pt=1,l=1,sg=0:1
    TSP:MSG:FPAR RES (ID=10, dist=1)
    TSP:MSG:FPAR (PPAR FOUND)
    TSP:MSG:PAR OK (ID=10, dist=2)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=40)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-10-40 s=255,c=3,t=25,pt=1,l=1,sg=0:2
    TSP:MSG:PONG RECV (hops=2)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    Air Conditioner node with DS18B20 sensor
    Found # DS18B20: 1
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0103
    TSP:MSG:READ 0-10-40 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    TSP:MSG:SEND 40-40-10-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:10
    TSP:MSG:READ 0-10-40 s=255,c=3,t=16,pt=0,l=0,sg=1:
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=ok:F5D9FF228C89C831ACCC92A03A72AF1404E61FCAB5713F0262
    TSP:MSG:READ 0-10-40 s=255,c=3,t=6,pt=0,l=1,sg=1:M
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=ok:Airco
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:2.0
    TSP:MSG:SEND 40-40-10-0 s=0,c=0,t=3,pt=0,l=10,sg=0,ft=0,st=ok:Airco Send
    TSP:MSG:SEND 40-40-10-0 s=1,c=0,t=36,pt=0,l=10,sg=0,ft=0,st=ok:Airco Data
    TSP:MSG:SEND 40-40-10-0 s=2,c=0,t=6,pt=0,l=11,sg=0,ft=0,st=ok:Temperature
    NODE:!REG
    Request registration...
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=ok:2AFF78F86CF7535A3809359EE8A3F0D7E2CBB46896EB7CE624
    TSP:MSG:READ 0-10-40 s=255,c=3,t=27,pt=1,l=1,sg=1:1
    Node registration=1
    Init complete, id=40, parent=10, distance=2, registration=1
    Log node message from gateway:
    TSP:MSG:READ 0-10-40 s=0,c=3,t=16,pt=0,l=0,sg=1:
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=ok:61228E563AE82E62E583A693BE93AAAD49CFA30DBBDB661754
    TSP:MSG:READ 0-10-40 s=0,c=1,t=2,pt=0,l=1,sg=1:1
    TSP:MSG:ACK msg
    TSP:MSG:SEND 40-40-10-0 s=0,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=ok:1
    Requesting IR code from Domoticz...
    !TSP:MSG:SEND 40-40-10-0 s=1,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=fail:
    TSP:MSG:READ 0-10-40 s=1,c=3,t=16,pt=0,l=0,sg=1:
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=17,pt=6,l=25,sg=0,ft=1,st=ok:23EDB656448AE71910C5299C36845AFBE97173826B337A0436
    TSP:MSG:READ 0-10-40 s=1,c=2,t=47,pt=0,l=8,sg=1:01202216
    Message: 1, Message: 01202216
    Update:
    The node doesn't react anymore... Strange...
    TSP:MSG:SEND 40-40-10-0 s=1,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=ok:98ED811AA0F6BE824A89927D3172CF9656B281FB711BCE28C5
    TSP:MSG:READ 0-10-40 s=1,c=3,t=16,pt=0,l=0,sg=0:
    TSP:MSG:SEND 40-40-10-0 s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=ok:8C42A5C36CAC1CE1F8354F26294261A658C186EC414A74AB04
    TSP:MSG:READ 0-10-40 s=1,c=2,t=47,pt=0,l=8,sg=1:00202216
    !TSP:MSG:SIGN verify fail
