  3. Pulse Power Meter: Sleep mode and clear last pulse count
8 Posts 2 Posters 2.8k Views 3 Watching
  • miljumeM
    miljumeM
    miljume
    I have built a power meter that works just fine when I use sleep mode = false but that uses up the battery in no-time
    As soon as I switch to true it stops sending values, I waited for one hour without any transfers and then I gave up
    How is it supposed to work?
    Another thing I can't figure out is how to clear the stored pulse count in the gateway, after the tryout is done I would like to start from scratch
    Anyone that can help me with these two problems?
    Attaching my code below
    * version 2 as published by the Free Software Foundation..
    * Version 1.0
    * Power Meter for S0 pulses
    //#define MY_DEBUG
    // Define a static node address, remove if you want auto address assignment
    //#deine MY_NODE_ID 3
    #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meeter
    #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
    #define MAX_WATT 10000          // Max watt value to report. This filetrs outliers.
    #define RELEASE "1.0"
    // Child sensor ID's
    //#define CHILD_ID_TEMP  1
    #define CHILD_ID_POWER   2
    // Sensor messages
    MyMessage wattMsg(CHILD_ID_POWER, V_WATT);
    MyMessage kwhMsg(CHILD_ID_POWER, V_KWH);
    MyMessage pcMsg(CHILD_ID_POWER, V_VAR1);
    // Global settings
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR) / 1000; // Pulses per watt hour
    bool pcReceived = false;
    volatile unsigned long watt = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    boolean transmission_occured = false;
    int sendBattery = 0;
    // Storage of old measurements
    long lastBattery = -100;
    * Setup code
    	Serial.begin(9600);
    	Serial.print(F("Power Meter FW "));
    	Serial.print(RELEASE);
    	Serial.flush();
    	Serial.flush();
    	Serial.println(F(" - Online!"));
    	request(CHILD_ID_POWER, V_VAR1);
    	// Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
    	// If no pullup is used, the reported usage will be too high because of the floating pin
    	pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
    	attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
    	lastSend = millis();
    void presentation() {
    	sendSketchInfo("Power Meter", RELEASE);
    	present(CHILD_ID_POWER, S_POWER);
    *  Main loop function
    	unsigned long now = millis();
    	bool sendTime = now - lastSend > SEND_FREQUENCY;
    	if (pcReceived && (SLEEP_MODE || sendTime)) {
    		// New watt value has been calculated
    		if (!SLEEP_MODE && watt != oldWatt) {
    			// Check that we dont get unresonable large watt value.
    			// could hapen when long wraps or false interrupt triggered
    			if (watt<((unsigned long)MAX_WATT)) {
    				send(wattMsg.set(watt));  // Send watt value to gw
    			Serial.print("Watt:");
    			Serial.println(watt);
    			oldWatt = watt;
    		// Pulse count has changed
    		if (pulseCount != oldPulseCount) {
    			send(pcMsg.set(pulseCount));  // Send pulse count value to gw
    			//sendBattLevel();
    			double kwh = ((double)pulseCount / ((double)PULSE_FACTOR));
    			oldPulseCount = pulseCount;
    			if (kwh != oldKwh) {
    				send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
    				oldKwh = kwh;
    		lastSend = now;
    	else if (sendTime && !pcReceived) {
    		// No count received. Try requesting it again
    		lastSend = now;
    	if (SLEEP_MODE) {
    		sleep(SEND_FREQUENCY);
    void onPulse()
    	if (!SLEEP_MODE) {
    		unsigned long interval = newBlink - lastBlink;
    		if (interval<10000L) { // Sometimes we get interrupt on RISING
    			return;
    		watt = (3600000000.0 / interval) / ppwh;
    		lastBlink = newBlink;
    	pulseCount++;
    	if (message.type == V_VAR1) {
    		Serial.println(pulseCount);
    		pcReceived = true;
    void sendBattLevel()
    	long vcc = readVcc();
    	Serial.print("VCC: ");Serial.println(vcc);
    	if (vcc != lastBattery) {
    		lastBattery = vcc;
    		// Calculate percentage
    		vcc = vcc - 1900; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
    		long percent = vcc / 14.0;
    		sendBatteryLevel(percent);
    		transmission_occured = true;
    * Internal battery ADC measuring
    long readVcc() {
    #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
    	ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
    #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
    	ADMUX = _BV(MUX5) | _BV(MUX0);
    #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
    	ADcdMUX = _BV(MUX3) | _BV(MUX2);
    #else
    	while (bit_is_set(ADCSRA, ADSC)); // measuring
    	uint8_t low = ADCL; // must read ADCL first - it then locks ADCH
    	long result = (high << 8) | low;
    miljumeM 1 Reply Last reply
    • miljumeM miljume
      * Version 1.0
      //#define MY_DEBUG
      // Sensor messages
      // Global settings
      double oldKwh;
      * Setup code
      	Serial.begin(9600);
      	Serial.flush();
      	Serial.flush();
      			oldWatt = watt;
      			//sendBattLevel();
      				oldKwh = kwh;
      		lastSend = now;
      		lastSend = now;
      	if (SLEEP_MODE) {
      void onPulse()
      	if (!SLEEP_MODE) {
      			return;
      	pulseCount++;
      		pcReceived = true;
      		lastBattery = vcc;
      long readVcc() {
      #else
      miljumeM
      miljumeM
      miljume
      wrote on last edited by miljume
      @miljume said:
      I have worked with this sensor for over a week now but still can't get it to work in sleep mode
      So far I have noticed some strange things, please correct me if my assumptions are wrong
      • It seems like request(CHILD_ID_POWER, V_VAR1); in setup() is not being run when in sleep mode
      • When that function is not executed, the boolean pcReceived is not set to true
      • When pcReceived is false the code never enters if (pcReceived && (SLEEP_MODE || sendTime)) where all the "magic" happens
      • Pulse counter gets updated (i.e. interrupt occurs) but as the code never enters the if statement where everything is calculated and sent to the GW things dont work
      And I still havent figured out how to clear the V_VAR1 in the gateway ...
        Hmm.. When running in sleepmode, you should probably put a wait(500) or something after each request.
        Please report back after testing.
        • miljumeM
          miljumeM
          miljume
          @hek Thank you for the suggestion but I tried that with no luck
          But I realized that you need to detach the interrupt when entering loop() and then attach it again in the end of the loop(). Then it seems like at least the receive() function is entered. However I still have troubles with the SLEEP mode and getting it to report kwh to the GW
          Meanwhile I have been looking at This Example and it seems like its working better even if I have some conversion problems but I guess that it is due to an incorrect formula on how to calculate watts
          One big problem though that you might know the solution to. How do I clear the gateway value that the sensor reads at startup (V_VAR1)?
          I've been looking at This Link but I am not sure if that's the way to go?
            Clearing the V_VAR1 value on the controller side (I suspect this is what you mean) depends on which controller you're running.
            Clearing EEPROM won't help as it will be requested at each startup.
            • miljumeM
              miljumeM
              miljume
              Yes, I am using Domoticz and have cleared the nodes & childs (Settings/Hardware/MySensorsGateway) from the tables but still it the deleted value is being reported back to the sensor at startup
                I think I read somewhere hat you have to go into the database and clear the value. I don't run Domoticz myself.. so I'm not sure.
                  miljumeM
                  miljumeM
                  miljume
                  @hek Thank you, you are absolutely correct!
                  I found a description on how to edit the SQLite table to remove old values
                  Now I think I am up and running :relaxed:
