  3. How do i sent "virtual switches" from node to Controller?
25 Posts 5 Posters 8.5k Views 6 Watching
  • SuperKrisS
    SuperKrisS
    SuperKris
    Ok, next problem. I saw this one coming, but i cant figure it out by myself...
    I added the DHT code for the temperature and humidity. I took the sketch that under the build section as example. It does compile and work, but the sleep in the sketch is a issue. I was surprised to find the sketch was still responding to messages from the gateway. Maybe i'm understanding sleep wrong, so that is my first question.
    1. Does sleep stop all code from running, or just the function that its in? In other words; My keypad code is in the loop function. The mysensor code for receiving messages is in another funtion outside the loop function (void receive). Does a sleep in the loop function also blocks void receive, or does it only block the loop part?
    So both my keypad code and the DHT code are in the loop part of the sketch. This makes the keypad unresponsive. If i understand right this is caused because the code is sleeping most of the time. If i keep pressing the button until it wakes up for a a fraction of a second the key is registered.
    So the easy way would be to disable sleep right.... I do not need to save any batteries, and i want the whole node to be as responsive as possible. Disabling the sleep function (with just a // ) seems to work, but its flooding (debug still enabled off course) the serial monitor "with Failed reading temperature from DHT! Failed reading humidity from DHT"
    1. So i guess this is just because of the way the DHT works, but i fear this may be slowing down the whole sketch and making the node less responsive. Is it a bad idea to just skip the sleep and keep the rest the same?
    From what i learned from earlier experiments where i needed to time things but still needed it to be responsive to other input, i think the only solution is the millis function. I think such a function could be applied to only run the DHT code every 5 seconds. Unfortunately i'm way to much of a noob, and the DHT code is way to advanced to replace the sleep function with a millis function.
    1. Can anyone help me on my wat to replace the sleep funtion with the millies code?
    My current code (its getting pretty big now) can be found below:
    // ##### SET PROJECT NAME AND VERSION #####
    #define ProjectName "Shed Controller" // Name that is vissible in controller
    #define ProjectVersion "0,3"          // Version that is vissible in controller
    //#define MY_NODE_ID 10               // Manual Node ID.
    // ##### SET MYSENSOR SETTINGS BEFORE INCLUDIGN LIBRARY #####
    #define MY_DEBUG            // Enable debug prints to serial monitor
    // #define MY_DISABLED_SERIAL  // Disable serial monitor so pins 0 and 1 can be used for the keypad. Disable this line with comment to use serial monitor so debug code works
    #define MY_RADIO_NRF24      // Enable and select radio type attached
    #define MY_REPEATER_FEATURE // Enabled repeater feature for this node
    // ##### INCLUDE LIBRARYS #####
    #include <Keypad.h>
    #include <DHT.h>
    // ##### DEFINE I/O PINS #####
    //#define IoPin1 4  // Arduino Digital I/O pin number for I/O 1
    #define IoPin2 3  // Arduino Digital I/O pin number for I/O 2
    #define IoPin3 6  // Arduino Digital I/O pin number for I/O 3
    #define IoPin4 5  // Arduino Digital I/O pin number for I/O 4
    #define IoPin5 8  // Arduino Digital I/O pin number for I/O 5
    #define IoPin6 7  // Arduino Digital I/O pin number for I/O 6
    #define IoPin7 19 // Arduino Digital I/O pin number for I/O 7
    // ##### DEFINE CHILD ID'S #####
    #define CHILD_ID1 1     // ID for child 1 (I/O)
    #define CHILD_ID2 2     // ID for child 2 (I/O) used for relay
    //#define CHILD_ID4 4   // ID for child 4 (I/O)
    #define CHILD_ID5 5     // ID for child 5 (I/O) used for relay
    #define CHILD_ID6 6     // ID for child 6 (I/O) used for relay
    #define CHILD_ID7 7     // ID for child 7 (I/O) used for relay
    #define CHILD_ID_V1 10    // ID for child virtual switch 1. Used for Outside lighting button
    #define CHILD_ID_V2 11    // ID for child virtual switch 2. Used for Heater button
    #define CHILD_ID_V3 12    // ID for child virtual switch 3. Used for Anti Frost button
    #define CHILD_ID_V4 13    // ID for child virtual switch 4. Used for Party Lights button
    #define CHILD_ID_V5 14    // ID for child virtual switch 5. Used for Wifi AP button
    #define CHILD_ID_V6 15    // ID for child virtual switch 6. Used for Aux 1 button
    #define CHILD_ID_V7 16    // ID for child virtual switch 7. Used for Aux 2 button
    #define CHILD_ID_V8 17    // ID for child virtual switch 8. Used for 5 min button
    #define CHILD_ID_TEMP1 30 // ID for child 8 (I/O) used for humidity
    #define CHILD_ID_HUM1 31  // ID for child 3 (I/O) used for temperature
    // ##### TEMPERATURE SENSOR SETTINGS #####
    #define SENSOR_TEMP_OFFSET 0 // Offset for temperatur sensor can be set here
    static const uint64_t UPDATE_INTERVAL = 10000;
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    // ##### RELAY SETTING #####
    #define RELAY_ON 0          // Invert for some relay modules (currently inverted)
    #define RELAY_OFF 1         // Invert for some relay modules (currently inverted)
    // ##### OTHER VARIABLES #####
    bool state; // Not realy sure what this exatly does. I guess temporary storage of received messages and loading from EEPROM
    // ##### BOOLEANS FOR VIRTUAL SWITCHES #####
    bool VirtalSwitch1;  // Boolean (status) for virtual switch 1 (controlled by keypad)
    bool VirtalSwitch2;  // Boolean (status) for virtual switch 2 (controlled by keypad)
    bool VirtalSwitch3;  // Boolean (status) for virtual switch 3 (controlled by keypad)
    bool VirtalSwitch4;  // Boolean (status) for virtual switch 4 (controlled by keypad)
    bool VirtalSwitch5;  // Boolean (status) for virtual switch 5 (controlled by keypad)
    bool VirtalSwitch6;  // Boolean (status) for virtual switch 6 (controlled by keypad)
    bool VirtalSwitch7;  // Boolean (status) for virtual switch 7 (controlled by keypad)
    // ##### DEFINE MYSENSORS MESSAGE CONTAINERS TO COMMUNICATE WITH GATEWAY #####
    MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP); // msgTemp sends child ID CHILD_ID_TEMP1 as V_TEMP
    MyMessage msgHum(CHILD_ID_HUM1, V_HUM);    // msgHum sends child ID CHILD_ID_HUM1 as V_HUM
    MyMessage msgV1(CHILD_ID_V1,S_LIGHT);      // msgV1 sends child ID CHILD_ID_V1 as S_LIGHT
    MyMessage msgV2(CHILD_ID_V2,S_LIGHT);      // msgV2 sends child ID CHILD_ID_V2 as S_LIGHT
    MyMessage msgV3(CHILD_ID_V3,S_LIGHT);      // msgV3 sends child ID CHILD_ID_V3 as S_LIGHT
    MyMessage msgV4(CHILD_ID_V4,S_LIGHT);      // msgV4 sends child ID CHILD_ID_V4 as S_LIGHT
    MyMessage msgV5(CHILD_ID_V5,S_LIGHT);      // msgV5 sends child ID CHILD_ID_V5 as S_LIGHT
    MyMessage msgV6(CHILD_ID_V6,S_LIGHT);      // msgV6 sends child ID CHILD_ID_V6 as S_LIGHT
    MyMessage msgV7(CHILD_ID_V7,S_LIGHT);      // msgV7 sends child ID CHILD_ID_V7 as S_LIGHT
    MyMessage msgV8(CHILD_ID_V8,S_LIGHT);      // msgV8 sends child ID CHILD_ID_V8 as S_LIGHT
    // ##### KEYPAD SETUP #####
    const byte ROWS = 4; // Just settings for keypad library. Enter number of rows here
    const byte COLS = 3; // Just settings for keypad library. Enter number of columns here
    // Nameing of very key on the keypad. The output of keypad code will be the charaters used here.
    char keys[ROWS][COLS] = {
      {'1', '2', '3'},
      {'4', '5', '6'},
      {'7', '8', '9'},
      {'A', 'B', 'C'}
    byte rowPins[ROWS] = { A0, A1, A2, A3 }; // The pins the row wires are connected to (from left to right)
    byte colPins[COLS] = { A4, 1, 0 };       // The pins the column wires are connected to (from top to bottom)
    Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS ); // This creates the actual keypad based on specs above.
      // ##### I/O SETUP FOR PHYSICAL I/O ON ARDUINO #####
      // Setup I/O 2
      pinMode(IoPin2, OUTPUT);                        // use I/O 2 as output for relay module
      digitalWrite(IoPin2, RELAY_OFF);                // and set switch relay output off
      state = loadState(CHILD_ID2);                   // Load last known state (using eeprom storage)
      digitalWrite(IoPin2, state?RELAY_ON:RELAY_OFF); // write last know state
      // Setup I/O 3
      dht.setup(IoPin3); // set data pin of DHT sensor
      // Setup I/O 4                                     Not in use
      // pinMode(IoPin4, OUTPUT);                        // use I/O 4 as output for relay module
      // digitalWrite(IoPin4, RELAY_OFF);                // and set switch relay output off
      // state = loadState(CHILD_ID4);                   // Load last known state (using eeprom storage)
      // digitalWrite(IoPin4, state?RELAY_ON:RELAY_OFF); // write last know state
      // Setup I/O 5
      pinMode(IoPin5, OUTPUT);                        // use I/O 5 as output for relay module
      digitalWrite(IoPin5, RELAY_OFF);                // and set switch relay output off
      state = loadState(CHILD_ID5);                   // Load last known state (using eeprom storage)
      digitalWrite(IoPin5, state?RELAY_ON:RELAY_OFF); // write last know state
      // Setup I/O 6
      pinMode(IoPin6, OUTPUT);                        // use I/O 6 as output for relay module
      digitalWrite(IoPin6, RELAY_OFF);                // and set switch relay output off
      state = loadState(CHILD_ID6);                   // Load last known state (using eeprom storage)
      digitalWrite(IoPin6, state?RELAY_ON:RELAY_OFF); // write last know state
      // Setup I/O 7
      pinMode(IoPin7, OUTPUT);                        // use I/O 7 as output for relay module
      digitalWrite(IoPin7, RELAY_OFF);                // and set switch relay output off
      state = loadState(CHILD_ID7);                   // Load last known state (using eeprom storage)
      digitalWrite(IoPin7, state?RELAY_ON:RELAY_OFF); // write last know state
     // ----- PIN SETUP (FOR TESTING ONLY -----
     // pinMode(IoPin4, OUTPUT);   //use I/O 4 as output for relay module
     // digitalWrite(IoPin4, HIGH);//   and set is HIGH so relay stays off
    // ###### PRESENT ALL ATTACHED SENSORS TO CONTROLLER ######
    void presentation(){
      // ----- Sent sketch info -----
      sendSketchInfo(ProjectName, ProjectVersion); // Send the sketch version information to the gateway and Controller
      // ----- Physical I/O child IDs -----
      //present(CHILD_ID1, XXXXXXX); //Register child ID 1 as NONE
      present(CHILD_ID2, S_LIGHT, "Outside lighting relay"); //Register CHILD_ID2 as S_LIGHT, and sent name to controller.
      //present(CHILD_ID4, XXXXXXX); //Register child ID 4 as NONE
      present(CHILD_ID5, S_LIGHT, "Switched outlet heater"); //Register CHILD_ID5 as S_LIGHT, and sent name to controller.
      present(CHILD_ID6, S_LIGHT, "Sw outlet party lights"); //Register CHILD_ID6 as S_LIGHT, and sent name to controller.
      present(CHILD_ID7, S_LIGHT, "Gate light relay");       //Register CHILD_ID7 as S_LIGHT, and sent name to controller.
      // ----- virtual switch child ID (keypad)
      present(CHILD_ID_V1, S_LIGHT, "Outside light switch"); //Register CHILD_ID_V1 as S_LIGHT, and sent name to controller
      present(CHILD_ID_V2, S_LIGHT, "Shed heater");          //Register CHILD_ID_V2 as S_LIGHT, and sent name to controller
      present(CHILD_ID_V3, S_LIGHT, "Anti frost mode");      //Register CHILD_ID_V3 as S_LIGHT, and sent name to controller
      present(CHILD_ID_V4, S_LIGHT, "Party lights");         //Register CHILD_ID_V4 as S_LIGHT, and sent name to controller
      present(CHILD_ID_V5, S_LIGHT, "Wifi AP");              //Register CHILD_ID_V5 as S_LIGHT, and sent name to controller
      present(CHILD_ID_V6, S_LIGHT, "Aux 1");                //Register CHILD_ID_V6 as S_LIGHT, and sent name to controller
      present(CHILD_ID_V7, S_LIGHT, "Aux 2");                //Register CHILD_ID_V7 as S_LIGHT, and sent name to controller
      present(CHILD_ID_V8, S_LIGHT, "5 min. button");        //Register CHILD_ID_V8 as S_LIGHT, and sent name to controller
      // ----- Sensor child ID's -----
      present(CHILD_ID_TEMP1, S_TEMP, "Temp shed Inside");   //Register CHILD_ID_TEMP1 as S_TEMP, and sent name to controller
      present(CHILD_ID_HUM1, S_HUM, "Hum. shed Indide");     //Register CHILD_ID_HUM1 as S_HUM, and sent name to controller
      // ----- Aditional presentation setting -----
      metric = getConfig().isMetric;  //Not sure what this does, Its needed for DHT sensor
    { // ##### KEYPAD CODE TO SET A ACTION FOR A PRESSED KEY #####
      char key = kpd.getKey();       // Get key from keypad (if pressed)
      if (key)  {                    // compare key (defined in keypad setup)
        switch (key) {               // with multiple multiple options below
                                // On button for outside light
          case '1':                  // If the pressed key compares with "1"
            VirtalSwitch1 = true;    // Change te state of boolean VirtalSwitch1 to true (on)
            send(msgV1.set(1));      // Sent "on" command to gateway for CHILD_ID_V1
            Serial.println("KEY 1"); // Debug code. Print "KEY 1" to show that button 1 was pressed
            break;                   // End of code for button 1
                                // Off button for outside light
          case '2':                  // If the pressed key compares with "2"
            VirtalSwitch1 = false;   // Change te state of boolean VirtalSwitch1 to false (off)
            send(msgV1.set(0));      // Sent "off" command to gateway for CHILD_ID_V1
            Serial.println("KEY 2"); // Debug code. Print "KEY 2" to show that button 2 was pressed
            break;                   // End of code for button 2
                                // 5 minute button
          case '3':                  // If the pressed key compares with "3"
            send(msgV8.set(1));      // Sent "on" command to gateway for CHILD_ID_V8
            Serial.println("KEY 4"); // Debug code. Print "KEY 4" to show that button 4 was pressed
            break;                   // End of code for button 4
                                // On button for heating
          case '4':                  // If the pressed key compares with "4"
            VirtalSwitch2 = true;    // Change te state of boolean VirtalSwitch2 to true (on). This is the heater
            VirtalSwitch3 = false;   // Change te state of boolean VirtalSwitch3 to false (off). This is the anti frost funtion
            send(msgV2.set(1));      // Sent "on" command to gateway for CHILD_ID_V2. This is the heater
            send(msgV3.set(0));      // Sent "off" command to gateway for CHILD_ID_V3. This is the anti frost funtion
                                // Off button for heating
          case '5':                  // If the pressed key compares with "5"
            VirtalSwitch2 = false;   // Change te state of boolean VirtalSwitch2 to false (off). This is the heater
            send(msgV2.set(0));      // Sent "off" command to gateway for CHILD_ID_V2. This is the heater
            Serial.println("KEY 5"); // Debug code. Print "KEY 5" to show that button 5 was pressed
            break;                   // End of code for button 5
                                // On button for anti frost
          case '6':                  // If the pressed key compares with "6"
            VirtalSwitch3 = true;    // Change te state of boolean VirtalSwitch3 to true (on). This is the anti frost funtion
            send(msgV3.set(1));      // Sent "on" command to gateway for CHILD_ID_V3. This is the anti frost funtion
            Serial.println("KEY 6"); // Debug code. Print "KEY 6" to show that button 6 was pressed
            break;                   // End of code for button 6
                                // On button for party lights
          case '7':                  // If the pressed key compares with "7"
            VirtalSwitch4 = true;    // Change te state of boolean VirtalSwitch1 to true (on)
            send(msgV4.set(1));      // Sent "on" command to gateway for CHILD_ID_V4
            Serial.println("KEY 7"); // Debug code. Print "KEY 7" to show that button 7 was pressed
            break;                   // End of code for button 7
                                // Off button for party lights
          case '8':                  // If the pressed key compares with "8"
            VirtalSwitch4 = false;   // Change te state of boolean VirtalSwitch1 to false (off)
            send(msgV4.set(0));      // Sent "off" command to gateway for CHILD_ID_V4
            Serial.println("KEY 8"); // Debug code. Print "KEY 8" to show that button 8 was pressed
            break;                   // End of code for button 8
                                    // Aux ON/OFF buton 1
          case '9':{                     // If the pressed key compares with "9"
            if (VirtalSwitch6 == false){ // check if the virtual switch (VirtalSwitch6) is OFF. If so, do the following
              VirtalSwitch6 = true;      // set the new status of the virtual swich to ON
              send(msgV6.set(1));        // Sent "on" command to gateway for CHILD_ID_V6
            else {                       // If the virtual switch was not OFF, it must have been ON, so do the following
              VirtalSwitch6 = false;     // set the new status of the virtual swich to OFF
              send(msgV6.set(0));        // Sent "off" command to gateway for CHILD_ID_V6
            Serial.println("KEY 9");    // Debug code. Print "KEY 9" to show that button 9 was pressed
            break;                      // End of code for button 9
                                 // On button for Wifi AP
          case 'A':                  // If the pressed key compares with "A"
            VirtalSwitch5 = true;    // Change te state of boolean VirtalSwitch5 to true (on)
            send(msgV5.set(1));      // Sent "on" command to gateway for CHILD_ID_V5
            Serial.println("KEY A"); // Debug code. Print "KEY A" to show that button A was pressed
            break;                   // End of code for button A
                                 // Off button for Wifi AP
          case 'B':                  // If the pressed key compares with "B"
            VirtalSwitch5 = false;   // Change te state of boolean VirtalSwitch5 to false (off)
            send(msgV5.set(0));      // Sent "off" command to gateway for CHILD_ID_V5
            Serial.println("KEY B"); // Debug code. Print "KEY B" to show that button B was pressed
            break;                   // End of code for button B
                                  // Aux ON/OFF buton 2
          case 'C':{                     // If the pressed key compares with "C"
            if (VirtalSwitch7 == false){ // check if the virtual switch (VirtalSwitch7) is OFF. If so, do the following
              VirtalSwitch7 = true;      // set the new status of the virtual swich to ON
              send(msgV7.set(1));        // Sent "on" command to gateway for CHILD_ID_V7
              VirtalSwitch7 = false;     // set the new status of the virtual swich to OFF
              send(msgV7.set(0));        // Sent "off" command to gateway for CHILD_ID_V7
            Serial.println("KEY C");    // Debug code. Print "KEY C" to show that button C was pressed
            break;                      // End of code for button C
          default:                  // If the pressed key does not match the cases above
            Serial.print(key);      // Print the key that was pressed
            Serial.println(" was pressed but not recognized by the keypadcode. Something is wrong!"); // print warning
            break;                  // End of function
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      //sleep(UPDATE_INTERVAL);
    // ##### CODE FOR RECEIVING MYSENSORS MESSAGES FROM CONTROLLER #####
    void receive(const MyMessage &message) {                         //start mysensor receiving code
      if (message.isAck()) {                                         //Check for gateway acknowledgment
         Serial.println("This is an ack from gateway");              //Print debug code (serial print) to confirm received ack
      // ----- Relay actors -----
      // ----- Action taken for child ID 1: Currently set as V_LIGHT to switch relay on IoPin1 -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID2) {  //if message is V_LIGHT and the child ID is 2
         state = message.getBool();                                  //guess this write the incomming boolean to state?
         digitalWrite(IoPin2, state?RELAY_ON:RELAY_OFF);             //change the the arduino pin from "on" to "off" or other way around
         saveState(CHILD_ID2, state);                                //guess this saves the state if child ID 2 to EEPPROM
         Serial.print("Incoming change for sensor:");                //debug info text
         Serial.print(message.sensor);                               //write received child ID
         Serial.print(", New status: ");                             //debug info text
         Serial.println(message.getBool());                          //write received boolean
      // ----- Action taken for child ID 5: Currently set as V_LIGHT to switch relay on IoPin5 -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID5) {  //no further comments. See actions for child 2. Its the same
         state = message.getBool();                                  //also no debug code (serial print) written to save space
         saveState(CHILD_ID5, state);
      // ----- Action taken for child ID 6: Currently set as V_LIGHT to switch relay on IoPin6 -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID6) {  //no further comments. See actions for child 2. Its the same
         saveState(CHILD_ID6, state);
      // ----- Action taken for child ID 7: Currently set as V_LIGHT to switch relay on IoPin7 -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID7) {  //no further comments. See actions for child 2. Its the same
         saveState(CHILD_ID7, state);
      // ----- Virtual switches -----
      // ----- Action taken for CHILD_ID_V1: Currently set as V_LIGHT. Changes the boolean of virtual switch (VirtalSwitch1) -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID_V1) {  //if message is V_LIGHT, the child ID is CHILD_ID_V1 do the following
         VirtalSwitch1 = state;                                        //copy the received boolean to VirtalSwitch1
         saveState(CHILD_ID_V1, state);                                //guess this saves the state if CHILD_ID_V1 to EEPPROM
      // ----- Action taken for CHILD_ID_V2: Currently set as V_LIGHT.  -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID_V2 && state == 1) {  //if message is V_LIGHT, the CHILD_ID_V2 and the message is 1 (on)
         VirtalSwitch2 = true;                                         //set VirtalSwitch2 (heating) to 1 (on)
         VirtalSwitch3 = false;                                        //set VirtalSwitch3 (anti frost) to 0. This prevents the anti frost and heating funtion being on at the same time.
         send(msgV3.set(0));                                           //sent "off" command to gateway for CHILD_ID_V3. This is the anti frost funtion.
         saveState(CHILD_ID_V2, state);                                //guess this saves the state if CHILD_ID_V1 to EEPPROM
      if (message.type == V_LIGHT && message.sensor == CHILD_ID_V2 && state == 0) {  //if message is V_LIGHT, the CHILD_ID_V2 and the message is 0 (off)
         VirtalSwitch2 = false;                                        //set VirtalSwitch2 (heating) to 0 (off)
         VirtalSwitch3 = false;                                        //set VirtalSwitch3 (anti frost) to 0 ((off)
      // ----- Action taken for CHILD_ID_V3: Currently set as V_LIGHT.  -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID_V3 && state == 1) {  //if message is V_LIGHT, the CHILD_ID_V3 and the message is 1 (on)
         VirtalSwitch3 = true;                                         //set VirtalSwitch3 (anti frost) to 1 (on)
         VirtalSwitch2 = false;                                        //set VirtalSwitch2 (heating) to 0. This prevents the heating and anti frost funtion being on at the same time.
         send(msgV2.set(0));                                           //sent "off" command to gateway for CHILD_ID_V2. This is the heating funtion.
         saveState(CHILD_ID_V3, state);                                //guess this saves the state if CHILD_ID_V1 to EEPPROM
      if (message.type == V_LIGHT && message.sensor == CHILD_ID_V3 && state == 0) {  //if message is V_LIGHT, the CHILD_ID_V3 and the message is 0 (off)
         send(msgV2.set(0));                                           //sent "off" command to gateway for CHILD_ID_V3. This is the anti frost funtion.
      // ----- Action taken for CHILD_ID_V4: Currently set as V_LIGHT. Changes the boolean of virtual switch (VirtalSwitch4) -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID_V4) {  //if message is V_LIGHT, the child ID is CHILD_ID_V4 do the following
         VirtalSwitch4 = state;                                        //copy the received boolean to VirtalSwitch4
         saveState(CHILD_ID_V4, state);                                //guess this saves the state if CHILD_ID_V4 to EEPPROM
      // ----- Action taken for CHILD_ID_V5: Currently set as V_LIGHT. Changes the boolean of virtual switch (VirtalSwitch5) -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID_V5) {  //if message is V_LIGHT, the child ID is CHILD_ID_V5 do the following
         VirtalSwitch5 = state;                                        //copy the received boolean to VirtalSwitch5
         saveState(CHILD_ID_V5, state);                                //guess this saves the state if CHILD_ID_V5 to EEPPROM
      // ----- Action taken for CHILD_ID_V6: Currently set as V_LIGHT. Changes the boolean of virtual switch (VirtalSwitch6) -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID_V6) {  //if message is V_LIGHT, the child ID is CHILD_ID_V6 do the following
         VirtalSwitch6 = state;                                        //copy the received boolean to VirtalSwitch6
         saveState(CHILD_ID_V6, state);                                //guess this saves the state if CHILD_ID_V6 to EEPPROM
      // ----- Action taken for CHILD_ID_V7: Currently set as V_LIGHT. Changes the boolean of virtual switch (VirtalSwitch7) -----
      if (message.type == V_LIGHT && message.sensor == CHILD_ID_V7) {  //if message is V_LIGHT, the child ID is CHILD_ID_V7 do the following
         VirtalSwitch7 = state;                                        //copy the received boolean to VirtalSwitch7
         saveState(CHILD_ID_V7, state);                                //guess this saves the state if CHILD_ID_V6 to EEPPROM
    Boots33B T 2 Replies Last reply
    • SuperKrisS SuperKris
      #include <Keypad.h>
      #include <DHT.h>
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
        {'1', '2', '3'},
        {'4', '5', '6'},
        {'7', '8', '9'},
        {'A', 'B', 'C'}
        // Setup I/O 2
        // Setup I/O 3
        // Setup I/O 5
        // Setup I/O 6
        // Setup I/O 7
                                  // 5 minute button
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      Boots33B
      Boots33B
      Boots33
      @SuperKris Yes sleep will power down your node so should not be used for nodes that are expecting to receive messages or are set up as a repeater. Have a look at this thread for the basic non blocking delay code.
      SuperKrisS 1 Reply Last reply
        #include <Keypad.h>
        #include <DHT.h>
        float lastTemp;
        float lastHum;
        bool metric = true;
        DHT dht;
          {'1', '2', '3'},
          {'4', '5', '6'},
          {'7', '8', '9'},
          {'A', 'B', 'C'}
          // Setup I/O 2
          // Setup I/O 3
          // Setup I/O 5
          // Setup I/O 6
          // Setup I/O 7
                                    // 5 minute button
            if (!metric) {
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
          } else {
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
          } else {
            nNoUpdatesHum++;
        tboha
        @SuperKris
        • sleep() stops all code. You should not use it in this environment.
        • the receive() is declared outside loop() but runs inside loop(). This is done automatically by MySensors framework.
        • you are right to disable sleep(), but .... the DHT Sensor is not as fast as your Arduino.
        An excerpt of the DHT samplesketch:
        static const uint64_t MEASURING_INTERVAL = 30000;
        // i.e. the sensor would force sending an update every MEASURING_INTERVAL*FORCE_UPDATE_N_READS [ms]
        Thus your code must result in more than 1 reading per 2 seconds, so the DHT Sensor is not ready and fails.
        So as you expected, it boils down to enclose the DHT code into an millis() controlled if-Statement.
        Basically it looks like this
        // before setup() aka global variables
        unsigned long last_time = 0, actual_time = 0;
        // within loop()
          if ( (millis() - last_time) >= MEASURING_INTERVAL) {
            last_time = millis();
        // rest of your DHT Code here
        }   // don´t forget closing parenthesis (after Humidity is done)
        you will recognize the fragments, they originate form the DHT Example Sketch.
        • Boots33B Boots33
          SuperKrisS
          SuperKrisS
          SuperKris
          Thanks. That is just what i was looking for, but i want not able to find it trough the search funtion!
          There is just 1 thing i still dont understand about the sleep function. In the latest version of my sketch i use a sleep time of 5 seconds. If the arduino fully stops processing code while in sleep, i would not think it would be able to receive messages from the controller.
          But i have no problem receiving messages from the controller. If i press a lightswitch in Domoticz the relay on the arduino switches without any noticeable delay. This should not be possible right? How is this possible?
          Thanks! I guess i still dont fully understand the whole structure of a arduino sketch. I see why sleep() would stop the keypad from working properly, but i dont really understand why receive() seems to be not affected by this.
          I think i understand why i'm getting the errors from the DHT code. I'm just wondering if it would slow down other functions of the arduino, or the controller.
          // within loop()
          Thank, i'll try to work this within my sketch. It just seems a little hard because the DHT code is relatively complex compared to the other code i used in this sketch. I'm to much of a noob to understand if i can just copy the whole loop part into the if function with the millis.
          I'll try adding the millis code tonight!
          T 1 Reply Last reply
            // within loop()
            tboha
            @SuperKris
            you already solved the problem with Pin0 and 1 (did you?). Here is possibly another solution (from 2.0 API):
            MY_DISABLED_SERIAL 	Disabled 	Enable this in sketch if you want to use TX(1), RX(0) as normal I/O pin
            so
            should free Pin 0 and Pin 1.
