  3. How do i sent "virtual switches" from node to Controller?
25 Posts 5 Posters 8.5k Views 6 Watching
  • SuperKrisS SuperKris
    @tboha said:
    @SuperKris
    From the first look: it could be a simple typo:
    saveState(CHILD_ID_V1), state);
    should be
    saveState(CHILD_ID_V1, state);
    it may be simply one parenthesis too much.
    Wow.. I cant believe i missed that... damn.
    Ok, so everything seems to work now. I can just copy paste code and add some "virtual" buttons. Thats great! Thank you so much.
    Next i will need to add the PIR setup, but i think i have enough understanding to do this now. After that the DHT22 code. Should be a bit more trick, but i will get there.
    Just one more question about the code you written:
      present(CHILD_ID_V1, S_LIGHT, "Partylichtjes");
    What does "partytlichtjes" do? I guess its supposed to send the name of the switch to the controller, but it wont compile if i add it in my sketch.
    tboha
    Yes, it is supposed to give a human readable name to your Sensor, which could be displayed by your controller.
    strange - within my "testenvironment" it compiled (5 minutes ago) without complaints.
    Would you please give the CompilerMessage?
    It is not a vital point but it´s anoying.
    some additional remarks:
    Switching to Arduino-MEGA would solve your lack of IO-Pins dramatically (and provides you with huge amounts of Memory and RAM (=Variables)).
    Another Option would be to split different functions to different Arduinos. E.g. one Arduino to serve the switches, one Arduino to control an Array of Relays.
    Delegate dumb tasks to even dumber Hardware
    • IOPort-Expander to control relais http://www.ebay.com/itm/PCF8574T-PCF8574-I2C-8-Bit-IO-GPIO-expander-module-for-Arduino-Raspberry-Pi-/311730563568?var=&hash=item8e2bb3695d
    • multifunctional PCB´s for input and display[ http://stores.ebay.de/TxHang-Electronic/_i.html?_nkw=tm1638&submit=Finden&LH_TitleDesc=1&_sid=1103958046
    • capacitive switches with i2c http://www.ebay.de/itm/CAP1188-8-Key-Capacitive-Touch-Sensor-Module-SPI-I2C-Captouch-LED-For-Arduino-/401148874426?hash=item5d66560eba]
    Frequently read your included headerfiles (especially Mysensors.h) and read the APIs (https://www.mysensors.org/download/sensor_api_20), you will discover a bunch of additional functions.
    One function you will discover is direct "internode" communication without gateway and so without controller.
    This partially answers your question where to store your virtual items (or makes it more complicated with respect to maintenance). Deploying vital components to your peripherial Units gives great flexibility in choosing your controller. It also makes the integration "Third-Party" components easier. You mentioned your 433Mhz WallSwitch.
    SuperKrisS 1 Reply Last reply
    • T tboha
      SuperKrisS
      SuperKrisS
      SuperKris
      I tried ir multiple times earlier tonight, but was unable to compile. (i dont know the error anymore). For some reason it works fine now. Very strange!
      Switching to a mega is no option at this point. I got all the hardware already soldered together on a PCB, and thats a lot of inputs and outputs to do. I also do not like the size of the mega. The ram i dont need. I'm currently at around 50% and besides the DTH sensor, i'm almost done.
      Also i like the challenge of creating what i want with minimal components. I'm pretty sure its going to work in the end!
      Same goes for multiple arduino's. I think i have a couple of I/O expander PCBs laying around, but rather not use them either as its complicates the sketch even further.
      I have read a lot about the API but i'm still very much struggling to understand anything of it. I will definitely continue to read!
      Below my current code. The keypad part is done. Next is the receiving part for the virtual switches.
      Thank you very much for your great help! I fear i will have new questions very soon!
      // ##### SET PROJECT NAME AND VERSION #####
      #define ProjectName "Schuur controller"
      #define ProjectVersion "0,2"
      // ##### SET MYSENSOR SETTINGS BEFORE INCLUDIGN LIBRARY #####
      #define MY_DEBUG // Enable debug prints to serial monitor
      #define MY_RADIO_NRF24 // Enable and select radio type attached
      #define MY_REPEATER_FEATURE // Enabled repeater feature for this node
      // ##### INCLUDE LIBRARYS #####
      #include <Keypad.h>
      // ##### DEFINE I/O PINS #####
      //#define IoPin1 4  // Arduino Digital I/O pin number for I/O 1
      #define IoPin2 3  // Arduino Digital I/O pin number for I/O 2
      //#define IoPin3 6  // Arduino Digital I/O pin number for I/O 3
      #define IoPin4 5  // Arduino Digital I/O pin number for I/O 4
      #define IoPin5 8  // Arduino Digital I/O pin number for I/O 5
      #define IoPin6 7  // Arduino Digital I/O pin number for I/O 6
      #define IoPin7 19 // Arduino Digital I/O pin number for I/O 7
      // ##### DEFINE CHILD ID'S #####
      #define CHILD_ID1 1    // ID for child 1 (I/O)
      #define CHILD_ID2 2    // ID for child 2 (I/O) used for relay
      //#define CHILD_ID3 3  // ID for child 3 (I/O)
      //#define CHILD_ID4 4  // ID for child 4 (I/O)
      #define CHILD_ID5 5    // ID for child 5 (I/O) used for relay
      #define CHILD_ID6 6    // ID for child 6 (I/O) used for relay
      #define CHILD_ID7 7    // ID for child 7 (I/O) used for relay
      #define CHILD_ID_V1 10  // ID for child virtual switch 1. Used for Outside lighting button
      #define CHILD_ID_V2 11  // ID for child virtual switch 2. Used for Heater button
      #define CHILD_ID_V3 12  // ID for child virtual switch 3. Used for Anit Frost button
      #define CHILD_ID_V4 13  // ID for child virtual switch 4. Used for Party Lights button
      #define CHILD_ID_V5 14  // ID for child virtual switch 5. Used for Wifi AP button
      #define CHILD_ID_V6 15  // ID for child virtual switch 6. Used for Aux 1 button
      #define CHILD_ID_V7 16  // ID for child virtual switch 7. Used for Aux 2 button
      #define CHILD_ID_V8 17  // ID for child virtual switch 8. Used for 5 min button
      // ##### RELAY SETTING #####
      #define RELAY_ON 0          // Invert for some relay modules (currently inverted)
      #define RELAY_OFF 1         // Invert for some relay modules (currently inverted)
      // ##### OTHER VARIABLES #####
      bool state; // not sure what this does
      // ##### BOOLEANS FOR VIRTUAL SWITCHES #####
      bool VirtalSwitch1;  // Boolean (status) for virtual switch 1 (controlled by keypad)
      bool VirtalSwitch2;  // Boolean (status) for virtual switch 2 (controlled by keypad)
      bool VirtalSwitch3;  // Boolean (status) for virtual switch 3 (controlled by keypad)
      bool VirtalSwitch4;  // Boolean (status) for virtual switch 4 (controlled by keypad)
      bool VirtalSwitch5;  // Boolean (status) for virtual switch 5 (controlled by keypad)
      bool VirtalSwitch6;  // Boolean (status) for virtual switch 1 (controlled by keypad)
      bool VirtalSwitch7;  // Boolean (status) for virtual switch 1 (controlled by keypad)
      // ##### DEFINE MYSENSORS MESSAGE CONTAINERS TO COMMUNICATE WITH GATEWAY #####
      MyMessage msgV1(CHILD_ID_V1,S_LIGHT); // msgV1 sends child ID CHILD_ID_V1 as S_LIGHT
      MyMessage msgV2(CHILD_ID_V2,S_LIGHT); // msgV2 sends child ID CHILD_ID_V2 as S_LIGHT
      MyMessage msgV3(CHILD_ID_V3,S_LIGHT); // msgV3 sends child ID CHILD_ID_V3 as S_LIGHT
      MyMessage msgV4(CHILD_ID_V4,S_LIGHT); // msgV4 sends child ID CHILD_ID_V4 as S_LIGHT
      MyMessage msgV5(CHILD_ID_V5,S_LIGHT); // msgV5 sends child ID CHILD_ID_V5 as S_LIGHT
      MyMessage msgV6(CHILD_ID_V6,S_LIGHT); // msgV6 sends child ID CHILD_ID_V6 as S_LIGHT
      MyMessage msgV7(CHILD_ID_V7,S_LIGHT); // msgV7 sends child ID CHILD_ID_V7 as S_LIGHT
      MyMessage msgV8(CHILD_ID_V8,S_LIGHT); // msgV8 sends child ID CHILD_ID_V8 as S_LIGHT
      // ##### KEYPAD SETUP #####
      const byte ROWS = 4; // Four rows
      const byte COLS = 3; // Three columns
      // Define the Keymap
      char keys[ROWS][COLS] = {
        {'1', '2', '3'},
        {'4', '5', '6'},
        {'7', '8', '9'},
        {'A', 'B', 'C'}
      // Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
      byte rowPins[ROWS] = { A0, A1, A2, A3 };
      // Connect keypad COL0, COL1 and COL2 to these Arduino pins.
      byte colPins[COLS] = { A4, 1, 0 };                                        //if you got any spare pins - change 0 and 1 accordingly  e.g. { A4, 8, 9 }
        // or see below
      // Create the Keypad
      Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
        // ##### I/O SETUP FOR PHYSICAL I/O ON ARDUINO #####
        // Setup I/O 2
        pinMode(IoPin2, OUTPUT);                        // use I/O 2 as output for relay module
        digitalWrite(IoPin2, RELAY_OFF);                // and set switch relay output off
        state = loadState(CHILD_ID2);                   // Load last known state (using eeprom storage)
        digitalWrite(IoPin2, state?RELAY_ON:RELAY_OFF); // write last know state
        // Setup I/O 4                                     Not in use
        // pinMode(IoPin4, OUTPUT);                        // use I/O 4 as output for relay module
        // digitalWrite(IoPin4, RELAY_OFF);                // and set switch relay output off
        // state = loadState(CHILD_ID4);                   // Load last known state (using eeprom storage)
        // digitalWrite(IoPin4, state?RELAY_ON:RELAY_OFF); // write last know state
        // Setup I/O 5
        pinMode(IoPin5, OUTPUT);                        // use I/O 5 as output for relay module
        digitalWrite(IoPin5, RELAY_OFF);                // and set switch relay output off
        state = loadState(CHILD_ID5);                   // Load last known state (using eeprom storage)
        digitalWrite(IoPin5, state?RELAY_ON:RELAY_OFF); // write last know state
        // Setup I/O 6
        pinMode(IoPin6, OUTPUT);                        // use I/O 6 as output for relay module
        digitalWrite(IoPin6, RELAY_OFF);                // and set switch relay output off
        state = loadState(CHILD_ID6);                   // Load last known state (using eeprom storage)
        digitalWrite(IoPin6, state?RELAY_ON:RELAY_OFF); // write last know state
        // Setup I/O 7
        pinMode(IoPin7, OUTPUT);                        // use I/O 7 as output for relay module
        digitalWrite(IoPin7, RELAY_OFF);                // and set switch relay output off
        state = loadState(CHILD_ID7);                   // Load last known state (using eeprom storage)
        digitalWrite(IoPin7, state?RELAY_ON:RELAY_OFF); // write last know state
       // ----- PIN SETUP (FOR TESTING ONLY -----
        pinMode(IoPin4, OUTPUT);   //use I/O 4 as output for relay module
        digitalWrite(IoPin4, HIGH);//   and set is HIGH so relay stays off
      // ###### PRESENT ALL ATTACHED SENSORS TO CONTROLLER ######
      void presentation(){
        sendSketchInfo(ProjectName, ProjectVersion); // Send the sketch version information to the gateway and Controller
        // ----- Actual I/O child IDs -----
        //present(CHILD_ID1, XXXXXXX); //Register child ID 1 as NONE
        present(CHILD_ID2, S_LIGHT);   //Register child ID 2 as S_LIGHT
        //present(CHILD_ID3, XXXXXXX); //Register child ID 3 as NONE
        //present(CHILD_ID4, XXXXXXX); //Register child ID 4 as NONE
        present(CHILD_ID5, S_LIGHT);   //Register child ID 5 as S_LIGHT
        present(CHILD_ID6, S_LIGHT);   //Register child ID 6 as S_LIGHT
        present(CHILD_ID7, S_LIGHT);   //Register child ID 7 as S_LIGHT
        // ----- virtual switch child ID (keypad)
        present(CHILD_ID_V1, S_LIGHT, "Outside light switch");    //Register child ID 10 as S_LIGHT
        present(CHILD_ID_V2, S_LIGHT);  //Register child ID 11 as S_LIGHT
        present(CHILD_ID_V3, S_LIGHT);  //Register child ID 12 as S_LIGHT
        present(CHILD_ID_V4, S_LIGHT);  //Register child ID 13 as S_LIGHT
        present(CHILD_ID_V5, S_LIGHT);  //Register child ID 14 as S_LIGHT
        present(CHILD_ID_V6, S_LIGHT);  //Register child ID 15 as S_LIGHT
        present(CHILD_ID_V7, S_LIGHT);  //Register child ID 16 as S_LIGHT
        present(CHILD_ID_V8, S_LIGHT);  //Register child ID 17 as S_LIGHT
      { // ##### KEYPAD CODE TO SET A ACTION FOR A PRESSED KEY #####
        char key = kpd.getKey();       // Get key from keypad (if pressed)
        if (key)  {                    // compare key (defined in keypad setup)
          switch (key) {               // with multiple multiple options below
                                  // On button for outside light
            case '1':                  // If the pressed key compares with "1"
              VirtalSwitch1 = true;    // Change te state of boolean VirtalSwitch1 to true (on)
              send(msgV1.set(1));      // Sent "on" command to gateway for CHILD_ID_V1
              Serial.println("KEY 1"); // Debug code. Print "KEY 1" to show that button 1 was pressed
              break;                   // End of code for button 1
                                  // Off button for outside light
            case '2':                  // If the pressed key compares with "2"
              VirtalSwitch1 = false;   // Change te state of boolean VirtalSwitch1 to false (off)
              send(msgV1.set(0));      // Sent "off" command to gateway for CHILD_ID_V1
              Serial.println("KEY 2"); // Debug code. Print "KEY 2" to show that button 2 was pressed
              break;                   // End of code for button 2
                                  // 5 minute button
            case '3':                  // If the pressed key compares with "3"
              send(msgV8.set(1));      // Sent "on" command to gateway for CHILD_ID_V8
              Serial.println("KEY 4"); // Debug code. Print "KEY 4" to show that button 4 was pressed
              break;                   // End of code for button 4
                                  // On button for heating
            case '4':                  // If the pressed key compares with "4"
              VirtalSwitch2 = true;    // Change te state of boolean VirtalSwitch2 to true (on). This is the heater
              VirtalSwitch3 = false;   // Change te state of boolean VirtalSwitch3 to false (off). This is the anti frost funtion
              send(msgV2.set(1));      // Sent "on" command to gateway for CHILD_ID_V2. This is the heater
              send(msgV3.set(0));      // Sent "off" command to gateway for CHILD_ID_V3. This is the anti frost funtion
                                  // Off button for heating
            case '5':                  // If the pressed key compares with "5"
              VirtalSwitch2 = false;   // Change te state of boolean VirtalSwitch2 to false (off). This is the heater
              send(msgV2.set(0));      // Sent "off" command to gateway for CHILD_ID_V2. This is the heater
              Serial.println("KEY 5"); // Debug code. Print "KEY 5" to show that button 5 was pressed
              break;                   // End of code for button 5
                                  // On button for anti frost
            case '6':                  // If the pressed key compares with "6"
              VirtalSwitch3 = true;    // Change te state of boolean VirtalSwitch3 to true (on). This is the anti frost funtion
              send(msgV3.set(1));      // Sent "on" command to gateway for CHILD_ID_V3. This is the anti frost funtion
              Serial.println("KEY 6"); // Debug code. Print "KEY 6" to show that button 6 was pressed
              break;                   // End of code for button 6
                                  // On button for party lights
            case '7':                  // If the pressed key compares with "7"
              VirtalSwitch4 = true;    // Change te state of boolean VirtalSwitch1 to true (on)
              send(msgV4.set(1));      // Sent "on" command to gateway for CHILD_ID_V4
              Serial.println("KEY 7"); // Debug code. Print "KEY 7" to show that button 7 was pressed
              break;                   // End of code for button 7
                                  // Off button for party lights
            case '8':                  // If the pressed key compares with "8"
              VirtalSwitch4 = false;   // Change te state of boolean VirtalSwitch1 to false (off)
              send(msgV4.set(0));      // Sent "off" command to gateway for CHILD_ID_V4
              Serial.println("KEY 8"); // Debug code. Print "KEY 8" to show that button 8 was pressed
              break;                   // End of code for button 8
                                      // Aux ON/OFF buton 1
            case '9':{                     // If the pressed key compares with "9"
              if (VirtalSwitch6 == false){ // check if the virtual switch (VirtalSwitch6) is OFF. If so, do the following
                VirtalSwitch6 = true;      // set the new status of the virtual swich to ON
                send(msgV6.set(1));        // Sent "on" command to gateway for CHILD_ID_V6
              else {                       // If the virtual switch was not OFF, it must have been ON, so do the following
                VirtalSwitch6 = false;     // set the new status of the virtual swich to OFF
                send(msgV6.set(0));        // Sent "off" command to gateway for CHILD_ID_V6
              Serial.println("KEY 9");    // Debug code. Print "KEY 9" to show that button 9 was pressed
              break;                      // End of code for button 9
                                   // On button for Wifi AP
            case 'A':                  // If the pressed key compares with "A"
              VirtalSwitch5 = true;    // Change te state of boolean VirtalSwitch5 to true (on)
              send(msgV5.set(1));      // Sent "on" command to gateway for CHILD_ID_V5
              Serial.println("KEY A"); // Debug code. Print "KEY A" to show that button A was pressed
              break;                   // End of code for button A
                                   // Off button for Wifi AP
            case 'B':                  // If the pressed key compares with "B"
              VirtalSwitch5 = false;   // Change te state of boolean VirtalSwitch5 to false (off)
              send(msgV5.set(0));      // Sent "off" command to gateway for CHILD_ID_V5
              Serial.println("KEY B"); // Debug code. Print "KEY B" to show that button B was pressed
              break;                   // End of code for button B
                                    // Aux ON/OFF buton 2
            case 'C':{                     // If the pressed key compares with "C"
              if (VirtalSwitch7 == false){ // check if the virtual switch (VirtalSwitch7) is OFF. If so, do the following
                VirtalSwitch7 = true;      // set the new status of the virtual swich to ON
                send(msgV7.set(1));        // Sent "on" command to gateway for CHILD_ID_V7
                VirtalSwitch7 = false;     // set the new status of the virtual swich to OFF
                send(msgV7.set(0));        // Sent "off" command to gateway for CHILD_ID_V7
              Serial.println("KEY C");    // Debug code. Print "KEY C" to show that button C was pressed
              break;                      // End of code for button C
            default:                  // If the pressed key does not match the cases above
              Serial.print(key);      // Print the key that was pressed
              Serial.println(" was pressed but not recognized by the keypadcode. Something is wrong!"); // print warning
              break;                  // End of function
        // ----- WRITE BOOLEAN TO PIN (FOR TESTING PURPOSES ONLY) -----
        //digitalWrite(IoPin4, VirtalSwitch6);
      // ##### CODE FOR RECEIVING MYSENSORS MESSAGES FROM CONTROLLER #####
      void receive(const MyMessage &message) {                         //start mysensor receiving code
        if (message.isAck()) {                                         //Check for gateway acknowledgment
           Serial.println("This is an ack from gateway");              //Print debug code (serial print) to confirm received ack
        // ----- Action taken for child ID 1: Currently set as V_LIGHT to switch relay on IoPin1 -----
        if (message.type == V_LIGHT && message.sensor == CHILD_ID2) {  //if message is V_LIGHT and the child ID is 2
           state = message.getBool();                                  //guess this write the incomming boolean to state?
           digitalWrite(IoPin2, state?RELAY_ON:RELAY_OFF);             //change the the arduino pin from "on" to "off" or other way around
           saveState(CHILD_ID2, state);                                //guess this saves the state if child ID 2 to EEPPROM
           Serial.print("Incoming change for sensor:");                //debug info text
           Serial.print(message.sensor);                               //write received child ID
           Serial.print(", New status: ");                             //debug info text
           Serial.println(message.getBool());                          //write received boolean
        // ----- Action taken for child ID 5: Currently set as V_LIGHT to switch relay on IoPin5 -----
        if (message.type == V_LIGHT && message.sensor == CHILD_ID5) {  //no further comments. See actions for child 2. Its the same
           state = message.getBool();                                  //also no debug code (serial print) written to save space
           saveState(CHILD_ID5, state);
        // ----- Action taken for child ID 6: Currently set as V_LIGHT to switch relay on IoPin6 -----
        if (message.type == V_LIGHT && message.sensor == CHILD_ID6) {  //no further comments. See actions for child 2. Its the same
           saveState(CHILD_ID6, state);
        // ----- Action taken for child ID 7: Currently set as V_LIGHT to switch relay on IoPin7 -----
        if (message.type == V_LIGHT && message.sensor == CHILD_ID7) {  //no further comments. See actions for child 2. Its the same
           saveState(CHILD_ID7, state);
         // ----- Action taken for CHILD_ID_V1: Currently set as V_LIGHT. Changes the boolean of virtual switch (VirtalSwitch1) -----
        if (message.type == V_LIGHT && message.sensor == CHILD_ID_V1) {  //if message is V_LIGHT and the CHILD_ID_V1
           VirtalSwitch1 = state;                                        //copy the received boolean to VirtalSwitch1
           saveState(CHILD_ID_V1, state);                               //guess this saves the state if CHILD_ID_V1 to EEPPROM
        #include <Keypad.h>
          {'1', '2', '3'},
          {'4', '5', '6'},
          {'7', '8', '9'},
          {'A', 'B', 'C'}
        // or see below
          // Setup I/O 2
          // Setup I/O 5
          // Setup I/O 6
          // Setup I/O 7
                                    // 5 minute button
        tboha
        @SuperKris : You are welcome!
        • SuperKrisS
          SuperKrisS
          SuperKris
          So right now i think i have all the code for the keypad en de relays complete. It does exactly what i want. I just have one problem...
          The damn thing keeps giving serial prints. In the sketch below not from the mysensors library, but from the keypad code. The problem with this is that i really need all the digital ports, including 1 and 0. At this point there is no real way around that.
          In the keypad code i posted in my 2nd post, this issue only happened when there was a serial print active. Its currently not in the sketch at all, or is working from the library?
          Does anyone has any clue how i can give the digital pin 0 and 1 back to the keypad again?
          My current code
          #define ProjectName "Shed controller"
          #define ProjectVersion "0,3"
          //#define MY_DEBUG // Enable debug prints to serial monitor
          #include <Keypad.h>
          #define CHILD_ID_V3 12  // ID for child virtual switch 3. Used for Anti Frost button
          bool state; // Not realy sure what this exatly does. I guess temporary storage of received messages and loading from EEPROM
          bool VirtalSwitch6;  // Boolean (status) for virtual switch 6 (controlled by keypad)
          bool VirtalSwitch7;  // Boolean (status) for virtual switch 7 (controlled by keypad)
          const byte ROWS = 4; // Just settings for keypad library. Enter number of rows here
          const byte COLS = 3; // Just settings for keypad library. Enter number of columns here
          // Nameing of very key on the keypad. The output of keypad code will be the charaters used here.
            {'1', '2', '3'},
            {'4', '5', '6'},
            {'7', '8', '9'},
            {'A', 'B', 'C'}
          byte rowPins[ROWS] = { A0, A1, A2, A3 }; // The pins the row wires are connected to (from left to right)
          byte colPins[COLS] = { A4, 1, 0 };       // The pins the column wires are connected to (from top to bottom)
          Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS ); // This creates the actual keypad based on specs above.
            // Setup I/O 2
            // Setup I/O 5
            // Setup I/O 6
            // Setup I/O 7
           // pinMode(IoPin4, OUTPUT);   //use I/O 4 as output for relay module
           // digitalWrite(IoPin4, HIGH);//   and set is HIGH so relay stays off
            // ----- Physical I/O child IDs -----
            present(CHILD_ID2, S_LIGHT, "Outside lighting relay"); //Register child ID 2 as S_LIGHT, and sent name to controller.
            present(CHILD_ID5, S_LIGHT, "Switched outlet heater"); //Register child ID 5 as S_LIGHT, and sent name to controller.
            present(CHILD_ID6, S_LIGHT, "Sw outlet party lights"); //Register child ID 6 as S_LIGHT, and sent name to controller.
            present(CHILD_ID7, S_LIGHT, "Gate light relay");       //Register child ID 7 as S_LIGHT, and sent name to controller.
            present(CHILD_ID_V1, S_LIGHT, "Outside light switch"); //Register CHILD_ID_V1 as S_LIGHT, and sent name to controller
            present(CHILD_ID_V2, S_LIGHT, "Shed heater");          //Register CHILD_ID_V2 as S_LIGHT, and sent name to controller
            present(CHILD_ID_V3, S_LIGHT, "Anti frost mode");      //Register CHILD_ID_V3 as S_LIGHT, and sent name to controller
            present(CHILD_ID_V4, S_LIGHT, "Party lights");         //Register CHILD_ID_V4 as S_LIGHT, and sent name to controller
            present(CHILD_ID_V5, S_LIGHT, "Wifi AP");              //Register CHILD_ID_V5 as S_LIGHT, and sent name to controller
            present(CHILD_ID_V6, S_LIGHT, "Aux 1");                //Register CHILD_ID_V6 as S_LIGHT, and sent name to controller
            present(CHILD_ID_V7, S_LIGHT, "Aux 2");                //Register CHILD_ID_V7 as S_LIGHT, and sent name to controller
            present(CHILD_ID_V8, S_LIGHT, "5 min. button");        //Register CHILD_ID_V8 as S_LIGHT, and sent name to controller
                                      // 5 minute button
            // ----- Relay actors -----
            // ----- Virtual switches -----
            if (message.type == V_LIGHT && message.sensor == CHILD_ID_V1) {  //if message is V_LIGHT, the child ID is CHILD_ID_V1 do the following
            // ----- Action taken for CHILD_ID_V2: Currently set as V_LIGHT.  -----
            if (message.type == V_LIGHT && message.sensor == CHILD_ID_V2 && state == 1) {  //if message is V_LIGHT, the CHILD_ID_V2 and the message is 1 (on)
               VirtalSwitch2 = true;                                         //set VirtalSwitch2 (heating) to 1 (on)
               VirtalSwitch3 = false;                                        //set VirtalSwitch3 (anti frost) to 0. This prevents the anti frost and heating funtion being on at the same time.
               send(msgV3.set(0));                                           //sent "off" command to gateway for CHILD_ID_V3. This is the anti frost funtion.
               saveState(CHILD_ID_V2, state);                                //guess this saves the state if CHILD_ID_V1 to EEPPROM
            if (message.type == V_LIGHT && message.sensor == CHILD_ID_V2 && state == 0) {  //if message is V_LIGHT, the CHILD_ID_V2 and the message is 0 (off)
               VirtalSwitch2 = false;                                        //set VirtalSwitch2 (heating) to 0 (off)
               VirtalSwitch3 = false;                                        //set VirtalSwitch3 (anti frost) to 0 ((off)
            // ----- Action taken for CHILD_ID_V3: Currently set as V_LIGHT.  -----
            if (message.type == V_LIGHT && message.sensor == CHILD_ID_V3 && state == 1) {  //if message is V_LIGHT, the CHILD_ID_V3 and the message is 1 (on)
               VirtalSwitch3 = true;                                         //set VirtalSwitch3 (anti frost) to 1 (on)
               VirtalSwitch2 = false;                                        //set VirtalSwitch2 (heating) to 0. This prevents the heating and anti frost funtion being on at the same time.
               send(msgV2.set(0));                                           //sent "off" command to gateway for CHILD_ID_V2. This is the heating funtion.
               saveState(CHILD_ID_V3, state);                                //guess this saves the state if CHILD_ID_V1 to EEPPROM
            if (message.type == V_LIGHT && message.sensor == CHILD_ID_V3 && state == 0) {  //if message is V_LIGHT, the CHILD_ID_V3 and the message is 0 (off)
               send(msgV2.set(0));                                           //sent "off" command to gateway for CHILD_ID_V3. This is the anti frost funtion.
            // ----- Action taken for CHILD_ID_V4: Currently set as V_LIGHT. Changes the boolean of virtual switch (VirtalSwitch4) -----
            if (message.type == V_LIGHT && message.sensor == CHILD_ID_V4) {  //if message is V_LIGHT, the child ID is CHILD_ID_V4 do the following
               VirtalSwitch4 = state;                                        //copy the received boolean to VirtalSwitch4
               saveState(CHILD_ID_V4, state);                                //guess this saves the state if CHILD_ID_V4 to EEPPROM
            // ----- Action taken for CHILD_ID_V5: Currently set as V_LIGHT. Changes the boolean of virtual switch (VirtalSwitch5) -----
            if (message.type == V_LIGHT && message.sensor == CHILD_ID_V5) {  //if message is V_LIGHT, the child ID is CHILD_ID_V5 do the following
               VirtalSwitch5 = state;                                        //copy the received boolean to VirtalSwitch5
               saveState(CHILD_ID_V5, state);                                //guess this saves the state if CHILD_ID_V5 to EEPPROM
            // ----- Action taken for CHILD_ID_V6: Currently set as V_LIGHT. Changes the boolean of virtual switch (VirtalSwitch6) -----
            if (message.type == V_LIGHT && message.sensor == CHILD_ID_V6) {  //if message is V_LIGHT, the child ID is CHILD_ID_V6 do the following
               VirtalSwitch6 = state;                                        //copy the received boolean to VirtalSwitch6
               saveState(CHILD_ID_V6, state);                                //guess this saves the state if CHILD_ID_V6 to EEPPROM
            // ----- Action taken for CHILD_ID_V7: Currently set as V_LIGHT. Changes the boolean of virtual switch (VirtalSwitch7) -----
            if (message.type == V_LIGHT && message.sensor == CHILD_ID_V7) {  //if message is V_LIGHT, the child ID is CHILD_ID_V7 do the following
               VirtalSwitch7 = state;                                        //copy the received boolean to VirtalSwitch7
               saveState(CHILD_ID_V7, state);                                //guess this saves the state if CHILD_ID_V6 to EEPPROM
          • SuperKrisS
            SuperKrisS
            SuperKris
            Found it!!! I figured there must be a serial begin somewhere in the library. It was not in MySensors.h, but MySensors.h had MySensorsCore.h included which included serval other library's. One of them was MyConfig.h I looked in al library's for a serial begin by searching "serial". In MyConfig.h i found this.
            *  Serial and debug options
            // I_DEBUG requests are:
            // V: CPU voltage
            // F: CPU frequency
            // M: free memory
            //#define MY_SPECIAL_DEBUG
            //#define MY_DISABLED_SERIAL
            //#define MY_CORE_ONLY
            Adding "#define MY_DISABLED_SERIAL" to my sketch did the trick, and i can now use the full keypad.
            #include <Keypad.h>
            etc.....
            • SuperKrisS
              SuperKrisS
              SuperKris
              Ok, next problem. I saw this one coming, but i cant figure it out by myself...
              I added the DHT code for the temperature and humidity. I took the sketch that under the build section as example. It does compile and work, but the sleep in the sketch is a issue. I was surprised to find the sketch was still responding to messages from the gateway. Maybe i'm understanding sleep wrong, so that is my first question.
              1. Does sleep stop all code from running, or just the function that its in? In other words; My keypad code is in the loop function. The mysensor code for receiving messages is in another funtion outside the loop function (void receive). Does a sleep in the loop function also blocks void receive, or does it only block the loop part?
              So both my keypad code and the DHT code are in the loop part of the sketch. This makes the keypad unresponsive. If i understand right this is caused because the code is sleeping most of the time. If i keep pressing the button until it wakes up for a a fraction of a second the key is registered.
              So the easy way would be to disable sleep right.... I do not need to save any batteries, and i want the whole node to be as responsive as possible. Disabling the sleep function (with just a // ) seems to work, but its flooding (debug still enabled off course) the serial monitor "with Failed reading temperature from DHT! Failed reading humidity from DHT"
              1. So i guess this is just because of the way the DHT works, but i fear this may be slowing down the whole sketch and making the node less responsive. Is it a bad idea to just skip the sleep and keep the rest the same?
              From what i learned from earlier experiments where i needed to time things but still needed it to be responsive to other input, i think the only solution is the millis function. I think such a function could be applied to only run the DHT code every 5 seconds. Unfortunately i'm way to much of a noob, and the DHT code is way to advanced to replace the sleep function with a millis function.
              1. Can anyone help me on my wat to replace the sleep funtion with the millies code?
              My current code (its getting pretty big now) can be found below:
              #define ProjectName "Shed Controller" // Name that is vissible in controller
              #define ProjectVersion "0,3"          // Version that is vissible in controller
              //#define MY_NODE_ID 10               // Manual Node ID.
              // #define MY_DISABLED_SERIAL  // Disable serial monitor so pins 0 and 1 can be used for the keypad. Disable this line with comment to use serial monitor so debug code works
              #include <Keypad.h>
              #define CHILD_ID_TEMP1 30 // ID for child 8 (I/O) used for humidity
              #define CHILD_ID_HUM1 31  // ID for child 3 (I/O) used for temperature
              // ##### TEMPERATURE SENSOR SETTINGS #####
              #define SENSOR_TEMP_OFFSET 0 // Offset for temperatur sensor can be set here
              static const uint64_t UPDATE_INTERVAL = 10000;
              float lastTemp;
              float lastHum;
              uint8_t nNoUpdatesTemp;
              uint8_t nNoUpdatesHum;
              bool metric = true;
              DHT dht;
              MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP); // msgTemp sends child ID CHILD_ID_TEMP1 as V_TEMP
              MyMessage msgHum(CHILD_ID_HUM1, V_HUM);    // msgHum sends child ID CHILD_ID_HUM1 as V_HUM
                {'1', '2', '3'},
                {'4', '5', '6'},
                {'7', '8', '9'},
                {'A', 'B', 'C'}
                // Setup I/O 2
                // Setup I/O 3
                dht.setup(IoPin3); // set data pin of DHT sensor
                // Setup I/O 5
                // Setup I/O 6
                // Setup I/O 7
                // ----- Sent sketch info -----
                present(CHILD_ID2, S_LIGHT, "Outside lighting relay"); //Register CHILD_ID2 as S_LIGHT, and sent name to controller.
                present(CHILD_ID5, S_LIGHT, "Switched outlet heater"); //Register CHILD_ID5 as S_LIGHT, and sent name to controller.
                present(CHILD_ID6, S_LIGHT, "Sw outlet party lights"); //Register CHILD_ID6 as S_LIGHT, and sent name to controller.
                present(CHILD_ID7, S_LIGHT, "Gate light relay");       //Register CHILD_ID7 as S_LIGHT, and sent name to controller.
                // ----- Sensor child ID's -----
                present(CHILD_ID_TEMP1, S_TEMP, "Temp shed Inside");   //Register CHILD_ID_TEMP1 as S_TEMP, and sent name to controller
                present(CHILD_ID_HUM1, S_HUM, "Hum. shed Indide");     //Register CHILD_ID_HUM1 as S_HUM, and sent name to controller
                // ----- Aditional presentation setting -----
                metric = getConfig().isMetric;  //Not sure what this does, Its needed for DHT sensor
                                          // 5 minute button
                dht.readSensor(true);
                if (isnan(temperature)) {
                  lastTemp = temperature;
                  if (!metric) {
                  // Reset no updates counter
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                  Serial.print("T: ");
                  nNoUpdatesTemp++;
                if (isnan(humidity)) {
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                  Serial.print("H: ");
                  Serial.println(humidity);
                  nNoUpdatesHum++;
                //sleep(UPDATE_INTERVAL);
              Boots33B T 2 Replies Last reply
                #include <Keypad.h>
                float lastTemp;
                float lastHum;
                bool metric = true;
                DHT dht;
                  {'1', '2', '3'},
                  {'4', '5', '6'},
                  {'7', '8', '9'},
                  {'A', 'B', 'C'}
                  // Setup I/O 2
                  // Setup I/O 3
                  // Setup I/O 5
                  // Setup I/O 6
                  // Setup I/O 7
                                            // 5 minute button
                    if (!metric) {
                    nNoUpdatesTemp = 0;
                    #ifdef MY_DEBUG
                    nNoUpdatesTemp++;
                    lastHum = humidity;
                    nNoUpdatesHum = 0;
                    #ifdef MY_DEBUG
                    nNoUpdatesHum++;
                Boots33B
                Boots33B
                Boots33
                @SuperKris Yes sleep will power down your node so should not be used for nodes that are expecting to receive messages or are set up as a repeater. Have a look at this thread for the basic non blocking delay code.
                  #include <Keypad.h>
                  float lastTemp;
                  float lastHum;
                  bool metric = true;
                  DHT dht;
                    {'1', '2', '3'},
                    {'4', '5', '6'},
                    {'7', '8', '9'},
                    {'A', 'B', 'C'}
                    // Setup I/O 2
                    // Setup I/O 3
                    // Setup I/O 5
                    // Setup I/O 6
                    // Setup I/O 7
                                              // 5 minute button
                      if (!metric) {
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesTemp++;
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesHum++;
                  tboha
                  @SuperKris
                  • sleep() stops all code. You should not use it in this environment.
                  • the receive() is declared outside loop() but runs inside loop(). This is done automatically by MySensors framework.
                  • you are right to disable sleep(), but .... the DHT Sensor is not as fast as your Arduino.
                  An excerpt of the DHT samplesketch:
                  static const uint64_t UPDATE_INTERVAL = 60000;
                  static const uint64_t MEASURING_INTERVAL = 30000;
                  // i.e. the sensor would force sending an update every MEASURING_INTERVAL*FORCE_UPDATE_N_READS [ms]
                  Thus your code must result in more than 1 reading per 2 seconds, so the DHT Sensor is not ready and fails.
                  So as you expected, it boils down to enclose the DHT code into an millis() controlled if-Statement.
                  Basically it looks like this
                  // before setup() aka global variables
                  unsigned long last_time = 0, actual_time = 0;
                  // within loop()
                    if ( (millis() - last_time) >= MEASURING_INTERVAL) {
                      last_time = millis();
                  // rest of your DHT Code here
                  }   // don´t forget closing parenthesis (after Humidity is done)
                  you will recognize the fragments, they originate form the DHT Example Sketch.
                  • Boots33B Boots33
                    SuperKrisS
                    SuperKrisS
                    SuperKris
                    Thanks. That is just what i was looking for, but i want not able to find it trough the search funtion!
                    There is just 1 thing i still dont understand about the sleep function. In the latest version of my sketch i use a sleep time of 5 seconds. If the arduino fully stops processing code while in sleep, i would not think it would be able to receive messages from the controller.
                    But i have no problem receiving messages from the controller. If i press a lightswitch in Domoticz the relay on the arduino switches without any noticeable delay. This should not be possible right? How is this possible?
                    Thanks! I guess i still dont fully understand the whole structure of a arduino sketch. I see why sleep() would stop the keypad from working properly, but i dont really understand why receive() seems to be not affected by this.
                    I think i understand why i'm getting the errors from the DHT code. I'm just wondering if it would slow down other functions of the arduino, or the controller.
                    // within loop()
                    Thank, i'll try to work this within my sketch. It just seems a little hard because the DHT code is relatively complex compared to the other code i used in this sketch. I'm to much of a noob to understand if i can just copy the whole loop part into the if function with the millis.
                    I'll try adding the millis code tonight!
                      // within loop()
                      tboha
                      @SuperKris
                      you already solved the problem with Pin0 and 1 (did you?). Here is possibly another solution (from 2.0 API):
                      MY_DISABLED_SERIAL 	Disabled 	Enable this in sketch if you want to use TX(1), RX(0) as normal I/O pin
                      so
                      should free Pin 0 and Pin 1.
