  3. Multi-Sensor Button+dallas problem
5 Posts 3 Posters 2.6k Views 4 Watching
  • Thib.T
    Thib.T
    Thib.
    I made a multisensor node with latest library :
    2x Relay + 2x Dallas+ Sonar Distance + 2x Button
    The node is working but :
    • If i include sleep() or wait() in dallas sketch the node become slow and button is very slow to transfer data (more than 15sec)
    • If i remove sleep() or wait() its better but dallas send to many informations
    Is it possible to send dallas information every minute without a wait ?
    For the moment my solution is to convert FLOAT temperature to INT.
    #define MY_REPEATER_FEATURE
    #include <Bounce2.h>
    #include <OneWire.h>
    #include <NewPing.h>
    //-------------------RELAY-----------------------------//
    #define RELAY_1  A1  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_2  A2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    //-------------------DALLAS----------------------------//
    #define MAX_ATTACHED_DS18B20 2
    //unsigned long WAIT_TIME = 5000; // Sleep time between reads (in milliseconds)
    int lastTemperature[MAX_ATTACHED_DS18B20];
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    //-------------------SONAR----------------------------//
    #define CHILD_ID 5
    #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 1000 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage msg1(CHILD_ID, V_DISTANCE);
    int lastDist;
    //-------------------BUTTON----------------------------//
    #define CHILD_ID_6 6
    #define CHILD_ID_7 7
    #define BUTTON_PIN_6  4  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON_PIN_7  8  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValue1=-1;
    int oldValue2=-1;
    MyMessage msg6(CHILD_ID_6,V_TRIPPED);
    MyMessage msg7(CHILD_ID_7,V_TRIPPED);
    //=======================BEFORE==========================================//
    void before() {
        //Startup up the OneWire library
        sensors.begin();
        pinMode(pin, OUTPUT);
        // Set relay to OFF
        digitalWrite(pin, RELAY_OFF);
    //=======================SETUP============================================//
        //requestTemperatures() will not block current thread
        metric = getConfig().isMetric;
        // Setup the button
        pinMode(BUTTON_PIN_6,INPUT);
        pinMode(BUTTON_PIN_7,INPUT);
        // Activate internal pull-up
        digitalWrite(BUTTON_PIN_6,HIGH);
        digitalWrite(BUTTON_PIN_7,HIGH);
        debouncer1.attach(BUTTON_PIN_6);
        debouncer1.interval(5);
        debouncer2.attach(BUTTON_PIN_7);
        debouncer2.interval(5);
    //=======================PRESENTATION======================================//
      sendSketchInfo("Poele", "1.0");
      present(1, S_BINARY);
      present(2, S_BINARY);
      //Present all sensors to controller
      present(i+3, S_TEMP);
      present(CHILD_ID, S_DISTANCE);
      present(CHILD_ID_6, S_DOOR);
      present(CHILD_ID_7, S_DOOR);
    //=======================LOOP==============================================//
          debouncer1.update();
          // Get the update value
          int value1 = debouncer1.read();
          if (value1 != oldValue1) {
          // Send in the new value
          send(msg6.set(value1==HIGH ? 1 : 0));
          oldValue1 = value1;
          debouncer2.update();
          int value2 = debouncer2.read();
          if (value2 != oldValue2) {
          send(msg7.set(value2==HIGH ? 1 : 0));
          oldValue2 = value2;
          int dist = metric?sonar.ping_cm():sonar.ping_in();
          Serial.print("Ping: ");
          Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
          Serial.println(metric?" cm":" in");
          if (dist != lastDist && dist != lastDist+1 && dist != lastDist-1) {
            send(msg1.set(dist));
            lastDist = dist;
         wait(conversionTime);
         int temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        if (lastTemperature[i+3] != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msg.setSensor(i+3).set(temperature,1));
          lastTemperature[i+3]=temperature;
    //=======================RECEIVE==============================================//
      if (message.type==V_STATUS) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    mfalkviddM Boots33B 2 Replies Last reply
    • Thib.T Thib.
      int numSensors=0;
      bool metric = true;
      #define CHILD_ID 5
      int lastDist;
      int oldValue1=-1;
      int oldValue2=-1;
      void before() {
          sensors.begin();
          // Set relay to OFF
          // Setup the button
            oldValue1 = value1;
            oldValue2 = value2;
              lastDist = dist;
          #else
      @Thib. you should be able to use something like the lastSend variable used in the UV meter example
      • Thib.T Thib.
        int numSensors=0;
        bool metric = true;
        #define CHILD_ID 5
        int lastDist;
        int oldValue1=-1;
        int oldValue2=-1;
        void before() {
            sensors.begin();
            // Set relay to OFF
            // Setup the button
              oldValue1 = value1;
              oldValue2 = value2;
                lastDist = dist;
            #else
        Boots33B
        Boots33B
        Boots33
        @Thib. When you are using devices like the ultrasonic distance sensor it is best to use non blocking delays . do a google search for "Arduino non blocking delay" to get more info.
        The basic code will look something like below
        unsigned long previousMillis = 0;        // will store last time temperature was updated
        const long interval = 60000;           // interval at which to update the temperature (milliseconds)
          unsigned long currentMillis = millis();   // get the current time
          if (currentMillis - previousMillis >= interval) {
          /*---------------------Put your code to send temp here----------------------------  */
            previousMillis = currentMillis;         // save the last time you sent the temperature
        Thib.T 1 Reply Last reply
        • Thib.T
          Thib.T
          Thib.
          Thanks for your answers, i will try it
          • Boots33B Boots33
            Thib.T
            Thib.T
            Thib.
            @Boots33 , Thanks i have compiled your example and its working good !
