  3. The problem with spam, is necessary the help
4 Posts 2 Posters 1.6k Views 1 Watching
  • R
    R
    Roman
    I assembled the stand:
    1. A sensor - Arduino Pro Mini, the sketch DimmableLEDActuator
    2. Gateway - Arduino Pro Mini + CP2104 Serial Converter
    3. the controler - Raspberry Pi + the scripts on Python and PHP
    Library of version 1.4
    During tests from a Sensor data come to a Gateway without problems.
    But when I send a request of data from the controler for a sensor, spam starts pouring continuously, I won't reboot a sensor or a Gateway yet.
    When I change a line in MyConfig.h on:
    //#define DEBUG
    After the first sending data from a Sensor in a Gateway spam begins.
    LOG:
    0;0;3;0;9;read: 15-15-0 s=2,c=1,t=2,pt=2,l=2:0 - Sensor: send data
    15;2;1;0;2;0
    0;0;3;0;9;send: 0-0-15-15 s=2,c=1,t=3,pt=0,l=1,st=ok:0 - Gateway: send 15;2;1;0;3;0\n
    0;0;3;0;9;read: 0-1-15 s=2,c=1,t=3,pt=0,l=1:0
    0;0;3;0;9;read: 15-15-0 s=2,c=1,t=3,pt=2,l=2:17
    15;2;1;0;3;17 - Gateway: received data OK
    0;0;3;0;9;read: 15-15-0 s=2,c=1,t=2,pt=2,l=2:1 - Sensor: send data
    15;2;1;0;2;1
    0;0;3;0;9;read: 15-15-0 s=2,c=1,t=3,pt=2,l=2:17 - SPAM!!!!
    15;2;1;0;3;17
    15;2;1;0;3;17
    15;2;1;0;3;17
    15;2;1;0;3;17
    • R
      R
      Roman
      if (message.type==V_LIGHT) {
      // hek comment: Is this really nessesary?
      gw.send( lightMsg.set(oldValue) );
      if (message.type==V_DIMMER) {
      gw.send( dimmerMsg.set(17) );
        What happens if you update to the version I pushed yesterday to Github/master?
        • R
          R
          Roman
          Thanks! With new version library such problem isn't present.
          Spam isn't present :)
