  3. Measuring battery
Measuring battery
5 Posts 4 Posters 3.3k Views 5 Watching
  • mrc-coreM
    mrc-coreM
    mrc-core
    Hi. I'm having some troubles when i try to read the voltage off my arduino batterys,
    The problem it's not the code, my problem is the wire connection... Do i connect the battery (+) to A0 pin only or do i have the connect the battery (+) to the A0 pin and the VCC pin on the arduino pro mini ???
    If i connect the arduino over USB to see the serial monitor i can see the voltage on 4.8V to 5V.
    But when i try to connect to my battery the i get dead antenna.
    • carlekiC
      carlekiC
      carleki
      Hello @mrc-core
      You can use the Vcc.h library, and mesure the voltage without any wire ;)
      https://github.com/Yveaux/Arduino_Vcc
      meanmrgreenM 1 Reply Last reply
      • carlekiC carleki
        Hello @mrc-core
        meanmrgreenM
        meanmrgreenM
        meanmrgreen
        @carmelo42
        How does this work when using a booster?
        • meanmrgreenM meanmrgreen
          @carmelo42
          @meanmrgreen - No, since the booster will output a steady voltage and thats what read in that library. If you have a booster I always use resistors and connect it to A0 (https://www.mysensors.org/build/battery). Another way is to lower BOD by burning new fuses and bootloader but this is more advanced.
          • sundberg84S sundberg84
            meanmrgreenM
            meanmrgreenM
            meanmrgreen
            @sundberg84
            Will look into that, i have a UNO lying around aswell so prehaps ill experiment with the bootloader burning eventually.
