  3. 2 or more DHT22 - Sensors on one Arduino pro mini
8 Posts 2 Posters 3.9k Views 2 Watching
  • turborickT
    turborickT
    turborick
    I am a newbie with MySensors And Arduino, I'm looking for a sketch to put 2 or more DHT22 sensors on a pro mini that will run in 2.0. I have the pro mini running with one sensor and the DhtTemperatureAndHumiditySensor sketch. I have no idea where to begin. below is the Sketch
    Thank you in advance Rick
     * Version 1.0: Henrik EKblad
    // Enable debug prints
    //#define MY_RS485
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      metric = getConfig().isMetric;
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    • turborickT
      turborickT
      turborick
      I found this forum thread but it must be for a version prior to 2.0
      link text
      can this sketch be converted to 2.0?
      #include <DHT.h>
      #define NUM_SENSORS 2
      unsigned long SLEEP_TIME = 3000UL; // Sleep time between reads (in milliseconds)
      MyMessage tempMssg(0, V_TEMP);
      MyMessage humMssg(NUM_SENSORS, V_HUM);
      byte tempID[NUM_SENSORS] = {0,1};
      byte humID[NUM_SENSORS] = {2,3};
      DHT* dht[NUM_SENSORS];
      byte sensorPin[NUM_SENSORS] = {3, 4};
      float lastTemp[NUM_SENSORS] = {0.0, 0.0};
      float lastHum[NUM_SENSORS] = {0.0, 0.0};
      boolean metric = true;
        Serial.begin(9600);
        gw.begin();
        for (int i = 0; i < NUM_SENSORS; i++)
          dht[i] = new DHT;
          dht[i]->setup(sensorPin[i]);
        gw.sendSketchInfo("Humidity", "1.0");
          gw.present(tempID[i], S_TEMP);
          gw.present(humID[i], S_HUM);
        Serial.println(F("Setup Complete."));
          delay(dht[i]->getMinimumSamplingPeriod());
          float temperature = dht[i]->getTemperature();
            Serial.print(F("Failed reading temperature from DHT"));
            Serial.println(i);
          else if (temperature != lastTemp[i])
            lastTemp[i] = temperature;
            if (!metric)
              temperature = dht[i]->toFahrenheit(temperature);
            gw.send(tempMssg.setSensor(i).set(temperature, false));  // no ack
            Serial.print(F("T"));
            Serial.print(i);
            Serial.print(F("= "));
          float humidity = dht[i]->getHumidity();
            Serial.print("Failed reading humidity from DHT");
            Serial.println(i);
          else if (humidity != lastHum[i])
            lastHum[i] = humidity;
            gw.send(humMssg.setSensor(i).set(humidity, false));  // no ack
            Serial.print(F("H"));
            Serial.print(i);
        gw.sleep(SLEEP_TIME); //sleep a bit
      • korttomaK
        korttomaK
        korttoma
        Here are the instructions how to convert the sketch. Please try and if you run in to trouble please let me know and I will walk you through it.
        Converting sketch from 1.5 to to 2.0
        Add the following to activate NRF-radio support
        Remove MySensor constructor
        MySensors gw;
        Remove MySensors setup() call
        gw.setup(....);
        If node expects incoming messages, add the following function to handle data:
        void receive(const MyMessage &msg) {}
        Move present() and sendSketchInfo() from setup() to a new function called presentation().
        void presentation() {
             sendSketchInfo(...)
             present(...);
        If you’re using static ids , add:
        #define MY_NODE_ID xx
        If static parent node is used, add:
        #define MY_PARENT_NODE_ID xx
        If you want node to be a repeater, add
        #define MY_REPEATER_FEATURE
        If you need to reconfigure your CE/CS Pins (not needed if NRF is connected to default pins)
        #define MY_RF24_CE_PIN 9
        #define MY_RF24_CS_PIN 10
        Remove all “gw.” before MySensors library calls.
        If node requests time using requestTime(), remove callback argument define define the following function to handle time response:
        void receiveTime(unsigned long ts) {
        Make sure to include MySensors.h after any configuration defines.
        • Tomas
        turborickT 1 Reply Last reply
        • korttomaK korttoma
          MySensors gw;
          gw.setup(....);
               sendSketchInfo(...)
               present(...);
          turborickT
          turborickT
          turborick
          @korttoma Thanks for the instructions. Can you check and see if I have missed anything in the code ?
          #include <DHT.h>
          #define CHILD_ID_HUM1 1
          #define CHILD_ID_TEMP1 2
          #define HUMIDITY_SENSOR_1_DIGITAL_PIN 3
          #define CHILD_ID_HUM2 3
          #define CHILD_ID_TEMP2 4
          #define HUMIDITY_SENSOR_2_DIGITAL_PIN 4
          #define CHILD_ID_HUM3 5
          #define CHILD_ID_TEMP3 6
          #define HUMIDITY_SENSOR_3_DIGITAL_PIN 5
          DHT dht1;
          DHT dht2;
          DHT dht3;
          float lastTemp1;
          float lastHum1;
          float lastTemp2;
          float lastHum2;
          float lastTemp3;
          float lastHum3;
          MyMessage msgHum1(CHILD_ID_HUM1, V_HUM);
          MyMessage msgTemp1(CHILD_ID_TEMP1, V_TEMP);
          MyMessage msgHum2(CHILD_ID_HUM2, V_HUM);
          MyMessage msgTemp2(CHILD_ID_TEMP2, V_TEMP);
          MyMessage msgHum3(CHILD_ID_HUM3, V_HUM);
          MyMessage msgTemp3(CHILD_ID_TEMP3, V_TEMP);
            sendSketchInfo("MultiDHT2", "1.0");
            present(CHILD_ID_HUM1, S_HUM);
            wait( 55 );
            present(CHILD_ID_TEMP1, S_TEMP);
            wait( 55 );
            present(CHILD_ID_HUM2, S_HUM);
            wait( 55 );
            present(CHILD_ID_TEMP2, S_TEMP);
            wait( 55 );
            present(CHILD_ID_HUM3, S_HUM);
            wait( 55 );
            present(CHILD_ID_TEMP3, S_TEMP);
            wait( 55 );
            dht1.setup(HUMIDITY_SENSOR_1_DIGITAL_PIN);
            dht2.setup(HUMIDITY_SENSOR_2_DIGITAL_PIN);
            dht3.setup(HUMIDITY_SENSOR_3_DIGITAL_PIN);
            delay(dht1.getMinimumSamplingPeriod());
            float temperature1 = dht1.getTemperature();
            if (isnan(temperature1)) {
              Serial.println("Failed reading temperature from DHT1");
            } else if (temperature1 != lastTemp1) {
              lastTemp1 = temperature1;
              if (!metric) {
                temperature1 = dht1.toFahrenheit(temperature1);
              send(msgTemp1.set(temperature1, 1));
              Serial.println(temperature1);
            float humidity1 = dht1.getHumidity();
            if (isnan(humidity1)) {
              Serial.println("Failed reading humidity from DHT1");
            } else if (humidity1 != lastHum1) {
              lastHum1 = humidity1;
              send(msgHum1.set(humidity1, 1));
              Serial.println(humidity1);
            float temperature2 = dht2.getTemperature();
            if (isnan(temperature2)) {
              Serial.println("Failed reading temperature from DHT2");
            } else if (temperature2 != lastTemp2) {
              lastTemp2 = temperature2;
              if (!metric) {
                temperature2 = dht2.toFahrenheit(temperature2);
              send(msgTemp2.set(temperature2, 1));
              Serial.println(temperature2);
            float humidity2 = dht2.getHumidity();
            if (isnan(humidity2)) {
              Serial.println("Failed reading humidity from DHT2");
            } else if (humidity2 != lastHum2) {
              lastHum2 = humidity2;
              send(msgHum2.set(humidity2, 1));
              Serial.println(humidity2);
            float temperature3 = dht3.getTemperature();
            if (isnan(temperature3)) {
              Serial.println("Failed reading temperature from DHT3");
            } else if (temperature3 != lastTemp3) {
              lastTemp3 = temperature3;
              if (!metric) {
                temperature3 = dht3.toFahrenheit(temperature3);
              send(msgTemp3.set(temperature3, 1));
              Serial.println(temperature3);
            float humidity3 = dht3.getHumidity();
            if (isnan(humidity3)) {
              Serial.println("Failed reading humidity from DHT3");
            } else if (humidity3 != lastHum3) {
              lastHum3 = humidity3;
              send(msgHum3.set(humidity3, 1));
              Serial.println(humidity3);
            // sleep(SLEEP_TIME); //sleep a bit  //
            wait(SLEEP_TIME); //sleep a bit  //
          korttomaK 1 Reply Last reply
          • turborickT turborick
            #include <DHT.h>
            DHT dht1;
            DHT dht2;
            DHT dht3;
            float lastTemp1;
            float lastHum1;
            float lastTemp2;
            float lastHum2;
            float lastTemp3;
            float lastHum3;
              wait( 55 );
              wait( 55 );
              wait( 55 );
              wait( 55 );
              wait( 55 );
              wait( 55 );
                if (!metric) {
                if (!metric) {
                if (!metric) {
            korttomaK
            korttomaK
            korttoma
            @turborick looks fine to me, does it compile?
            • Tomas
              turborickT
              turborickT
              turborick
              @korttoma yes it compiles. here is the output from serial monitor
              Starting repeater (RNNRA-, 2.0.0)
              TSM:INIT
              TSM:RADIO:OK
              TSP:ASSIGNID:OK (ID=2)
              TSM:FPAR
              TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              TSP:MSG:READ 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
              TSP:MSG:PAR OK (ID=0, dist=1)
              TSM:FPAR:OK
              TSM:ID
              TSM:CHKID:OK (ID=2)
              TSM:UPL
              TSP:PING:SEND (dest=0)
              TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
              TSP:MSG:READ 0-0-2 s=255,c=3,t=25,pt=1,l=1,sg=0:1
              TSP:MSG:PONG RECV (hops=1)
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
              TSP:MSG:SEND 2-2-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
              TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
              TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=ok:MultiDHT2
              TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
              TSP:MSG:SEND 2-2-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
              TSP:MSG:SEND 2-2-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
              TSP:MSG:SEND 2-2-0-0 s=3,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
              TSP:MSG:SEND 2-2-0-0 s=4,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
              TSP:MSG:SEND 2-2-0-0 s=5,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
              TSP:MSG:SEND 2-2-0-0 s=6,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
              Request registration...
              TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
              TSP:MSG:READ 0-0-2 s=255,c=3,t=27,pt=1,l=1,sg=0:1
              Node registration=1
              Init complete, id=2, parent=0, distance=1, registration=1
              TSP:MSG:SEND 2-2-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:18.8
              T: 18.80
              TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:29.0
              H: 29.00
              TSP:MSG:SEND 2-2-0-0 s=4,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:18.7
              T: 18.70
              TSP:MSG:SEND 2-2-0-0 s=3,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:27.5
              H: 27.50
              TSP:MSG:SEND 2-2-0-0 s=6,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:18.8
              T: 18.80
              TSP:MSG:SEND 2-2-0-0 s=5,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:30.0
              H: 30.00
              TSP:MSG:SEND 2-2-0-0 s=4,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:18.6
              T: 18.60
              TSP:MSG:SEND 2-2-0-0 s=5,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:30.1
              H: 30.10
              TSP:SANCHK:OK
              TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:28.9
              H: 28.90
              TSP:MSG:SEND 2-2-0-0 s=3,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:27.4
              H: 27.40
              T: 18.70
              H: 27.50
              TSP:MSG:SEND 2-2-0-0 s=6,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:18.7
              T: 18.70
              TSP:MSG:SEND 2-2-0-0 s=5,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:30.2
              H: 30.20
              TSP:SANCHK:OK
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=2)
                TSM:UPL
                TSP:CHKUPL:OK
                TSM:UPL:OK
                TSM:READY
                Node registration=1
                T: 18.80
                H: 29.00
                T: 18.70
                H: 27.50
                T: 18.80
                H: 30.00
                T: 18.60
                H: 30.10
                TSP:SANCHK:OK
                H: 28.90
                H: 27.40
                T: 18.70
                H: 27.50
                T: 18.70
                H: 30.20
                TSP:SANCHK:OK
                korttomaK
                korttomaK
                korttoma
                @turborick seems to be working just fine, don´t you think?
                • Tomas
                  turborickT
                  turborickT
                  turborick
                  @korttoma I'll try and add to Vera tomorrow
