  3. Range extendsion
Range extendsion
4 Posts 2 Posters 1.9k Views 2 Watching
  • dennis_henkD
    dennis_henkD
    dennis_henk
    What is the best way to extend you receiving field over a large area . Example : I want to receive info from a node over 100 meter.
    What is the best option: making another GW ? ( and if this is the solution how do i make this work ?)
    or is there a beter way ?
    Thank you !
    • dennis_henkD dennis_henk
      Thank you !
      @dennis_henk it depends on your topology and other requirements.
      See https://www.mysensors.org/about/network#the-radio-communication for some information on what a repeater and a gateway is.
      What transport are you using? Nrf24?
      Some possible options:
      • wired ethernet to a remote gateway - maybe the least complex solution
      • rfm69 at 868/900MHz or 433 MHz - lower frequency generally has better range, but bounces less so it is not always better
      • repeater(s) - if you have active power available along the way
      • pa+lna radios - can get much better range but consumes more power and is more troublesome
      • better antennas
      • rs485 transport - might be an alternative to the ethernet cable
      or a combination of some of the above.
      • dennis_henkD
        dennis_henkD
        dennis_henk
        I think also the method.
        Is the best way. But how does this work ? especially with the programming side ?
          @dennis_henk the programming side is simple :) Follow the instructions here https://www.mysensors.org/build/ethernet_gateway
