  3. How to connect Sensebender with serial gateway?
10 Posts 2 Posters 3.6k Views 2 Watching
  • MadhiasM
    MadhiasM
    Madhias
    Hi all,
    A few weeks ago I got some packages in the mail, including 4 Sensebenders, and some other parts. I wanted to start on a small scale and try to connect a node with a serial gateway, since everything is new for me!
    I uploaded the (example) serial gateway sketch to an Uno clone, with a NRF24L01 attached to it, and also the (example) SensebenderMicro sketch to the Sensebender (with a Foca FTDI serial adapter), also with a NRF24L01 attached.
    Looking at the serial monitor of the gateway, this is the output:
    u�jI�0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    0;255;0;0;18;2.1.0
    0;255;3;0;9;MCO:BGN:STP
    Looking at the Sensebenders output:
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSM:FPAR
    16 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2025 !TSM:FPAR:NO REPLY
    2027 TSM:FPAR
    2029 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4038 !TSM:FPAR:NO REPLY
    Did I miss a simple setting to do in the sketches? It took a while until I am this point, to ask this question :smiley: My wife asked me again why I don't have a simple hobby like playing tennis.
      Welcome here @Madhias!
      Looks like you attached the radio correctly to your nodes (no warning). The Sensebender is searching for a parent and for some reason it can't seem to find it.
      Is that the full gateway log? Nothing else shows up when you (re)start the sensebender?
      What kind of NRF modules did you get?
      Any difference if you increase the distance between gw/node (2-3 meter at least)?
      • MadhiasM
        MadhiasM
        Madhias
        wrote on last edited by Madhias
        Thanks for your reply!
        In the gateway log nothing else shows up. I got these NRF modules.
        My next step was - which I wanted to try out later - to hook up an IBoard (version 1.1), and use it as Ethernet gateway. I uploaded the sketch found here from TimO, and put some batteries in the node, and got this output - is this the sensor talking with the gateway? This MSG:READ makes me happy somehow...
        IP: 10.20.30.4
        0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;TSF:MSG:BC
        0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
        0;255;3;0;9;TSF:PNG:SEND,TO=0
        0;255;3;0;9;TSF:CKU:OK
        0;255;3;0;9;TSF:MSG:GWL OK
        0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        I only have one FTDI adapter, so I can't see right now the serial monitor of the node. Later I will connect the ethernet gateway to the LAN.
        Another question: is it possible to see a local time in the serial monitor?
        • MadhiasM
          MadhiasM
          Madhias
          I have attached the ethernet gateway (Itead IBoard), to the LAN and PC, and the serial monitor output of the gateway looks like this when batteries are in the Sensebender node (unfortunately I have only one FTDI adapter):
          0;255;3;0;9;TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
          It looks good?
          I also tried the next possible gateway I could build: an ethernet gateway with a W5100 shield attached to the Uno. But with this combination I get this output:
          0;255;3;0;9;!TSM:INIT:TSP FAIL
          0;255;3;0;9;TSM:FAIL:CNT=1
          0;255;3;0;9;TSM:FAIL:PDT
          0;255;3;0;9;TSM:FAIL:RE-INIT
          But this is another story, and could it be that this Uno clone is the problem part - since it also did not work with the serial setup?
          • MadhiasM
            MadhiasM
            Madhias
            I have tried different setups now, next one will be with an original Genuino Uno Rev 3 board as a gateway. Also I'll have later another USB serial adapter. Store is closed today. Argh. So it will be next week then.
            I tried a long range NRF24 too.
            I have also reset the EEPROM on the Sensebender, and on the Arduino clone.
            For now I do not know what to do except to change all remaining parts.
            I already dreamed of !TSM:FPAR:NO REPLY !TSM:FPAR:NO REPLY !TSM:FPAR:NO REPLY Ahhh! :disappointed_relieved:
            • MadhiasM
              MadhiasM
              Madhias
              What is the difference between the Sensebender example sketch at Github (https://github.com/mysensors/SensebenderMicro/blob/master/Arduino/SensebenderMicro/SensebenderMicro.ino) and the preloaded sketch on the Sensebender?
              With the preloaded sketch the serial monitor output looks like this (I have deleted some lines in between to see the T / H values are also there):
              req node id
              send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
              sensor started, id 255
               - Online!
              req node id
              T: 23.10
              H: 63
              And with the sketch from Github I have the output as seen in my first post of this thread.
                The preloaded sketch is pretty old... I think it still is 1.5 (@tbowmo ?).
                It's really weird that you cannot seem to get any connection between your nodes. Almost as there's something wrong with the NRF modules you've received (unless your PCs USB power is behaving really strange...).
                • MadhiasM
                  MadhiasM
                  Madhias
                  I will try to find other NRF24L01+ modules. The long range versions I got were from the same seller. However next weekend I will make a restart with new parts :)
                  I am still wondering if it is really more or less easy to setup and thinking that I must have forgotten something. But I have to admit in the beginning it looked for me like a fast job, connecting some dupont cables, load up some sketches, and voila.
                    Yes, it should be easy to get things working... Especially with the sensebender were things usually can't go wrong (with stable battery powering).
                    So either the radios is misbehaving or the gateway have some powering problem of the radio which usually is solved by adding a capacitor near the radio.
                    • MadhiasM
                      MadhiasM
                      Madhias
                      Adding a capacitor at the radio solved my issues... Sorry for not trying that from the very beginning, today I bought some capacitors, and now it looks good!
                      Happy now!
                      33804 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.0
                      33818 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:62
                      34127 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      34134 MCO:SLP:TPD
                      34136 MCO:SLP:WUP=-1
                      Sending initial value
                      34154 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:1
                      Requesting initial value from controller
                      34164 TSF:MSG:SEND,3-3-0-0,s=1,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
                      TempDiff :1.01
                      HumDiff  :1.50
                      T: 23.00
                      H: 65
