  3. OpenHAB
  4. Change color of RGB led strip over MQTT?
coloropenhabled stripopenhab mqtt
2 Posts 2 Posters 2.9k Views 2 Watching
  • augusthalversonA
    augusthalversonA
    augusthalverson
    I was wondering how you change the color of RGB LED strips over MQTT with a raspberry pi gateway. Thanks in advance :)
    • augusthalversonA augusthalverson
      Hi and welcome to the MySensors community @augusthalverson !
      In general, you just set the color in your controller. It works the same way regardless of which type of gateway you are using, so there is nothing specific about mqtt.
      You might be able to get some inspiration from https://forum.mysensors.org/topic/4934/wall-mounted-mood-light-v2
