  3. Nodemcu 0.9 + MQTT gateway + TEMP + Motion Sensor
6 Posts 6 Posters 3.9k Views 6 Watching
  • Sam LakeS
    Sam LakeS
    Sam Lake
    wrote on last edited by Sam Lake
    I'm having my first bash at mysensors and a total newbie to all of this so please excuse any simple oversights. I feel a bit sheepish just posting this as there are a few examples of what I am trying to do but after a day of head scratching i feel i need to ask for help.
    The story so far:
    I have a bunch of nodemcu's lying around so thought I would make some multi purpose wifi/ mqtt sensors.
    First up I mashed the mqtt gateway and DHT sketches together.
     * Version 1.0 - Henrik Ekblad
     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_ESP8266
    // Set MQTT client id
    //#define MY_MQTT_USER "XXXXXXXXXXXXXXXX"
    //#define MY_MQTT_PASSWORD "XXXXXXXXXXXXXXXX"
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "XXXXXXXXXXXXXXX"
    #define MY_ESP8266_PASSWORD "XXXXXXXXXXX"
    // #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
    #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 10, 10, 0, 10
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <ESP8266WiFi.h>
    #include <DHT.h>
    #define DHT_DATA_PIN 2
    #define SENSOR_TEMP_OFFSET 0
    //const unsigned long SLEEP_TIME = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      metric = getConfig().isMetric;
      wait(dht.getMinimumSamplingPeriod());
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      wait(UPDATE_INTERVAL);
    This is working great. So I have a working temp / humidity sensor.
    Ploughing on I mashed my working mqtt dht example with the motion example and realisied i might have bitten off more than I can chew...
    Stepping back I thought ok just try MQTT + Motion Here's the sketch.
     * LED purposes:
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway2-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway2-in"
    #define MY_MQTT_CLIENT_ID "mysensors-2"
    #define MY_ESP8266_SSID "XXXXXXXXXXXXXXXX"
    #define MY_ESP8266_PASSWORD "XXXXXXXXXXXXXXXXX"
    #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    // Initialize motion message
        sendSketchInfo("Motion Sensor", "1.0");
        present(CHILD_ID, S_MOTION);
        // Read digital motion value
        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        Serial.println(tripped);
        send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
        sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    The node comes up and mqtt gateway registers with mybroker.
    See the serial log here:
    oÈHìè‰CGH,xI$ø0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGE--,VER=2.1.0
    scandone
    f 0, scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 8
    cnt
    connected with LakeNET, channel 1
    dhcp client start...
    .ip:10.10.0.235,mask:255.255.255.0,gw:10.10.0.1
    .IP: 10.10.0.235
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
    IP: 10.10.0.235
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: mygateway2-out/0/255/0/0/17
    0;255;3;0;9;Sending message on topic: mygateway2-out/0/255/3/0/11
    0;255;3;0;9;Sending message on topic: mygateway2-out/0/255/3/0/12
    0;255;3;0;9;Sending message on topic: mygateway2-out/0/1/0/0/1
    0;255;3;0;9;Sending message on topic: mygateway2-out/0/1/1/0/16
    0;255;3;0;9;MCO:SLP:MS=120000,SMS=0,I1=2,M1=3,I2=255,M2=255
    0;255;3;0;9;MCO:SLP:WUP=-2
    pm open,type:2 0
    But the sketch that looks like it should sleep for 2 mins if there is no motion (i have the sensor face down) but the sketch just keeps runnning away.
    I am not sure if its the code or something to do with the hardware / how I am wired. Just not sure about this whole interrupt thing.
    Any pointers will be gratefully received.
    • EfflonE
      EfflonE
      Efflon
      Just browsing through your code since I have a similar setup with a mqtt gateway with a few sensors and had the same problem. The thing is that a gateway shouldn't sleep thus I believe the sleep() function is not working (without looking at the source code). I replaced sleep() with wait() and have it running on usb power.
      tekkaT 1 Reply Last reply
      • EfflonE Efflon
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        @Efflon @Sam-Lake The sleeping function for ESP8266 HW is currently not implemented, hence following debug output:
        WUP=-2 indicates that sleeping is not possible.
        • Tim AbelsT
          Tim AbelsT
          Tim Abels
          With esp8266 and MQTT you are not in the right corner at MySensors. You might want to check out ESPEasy:
          http://letscontrolit.com/wiki/index.php/ESPEasy
          • proddyP
            proddyP
            proddy
            I have a similar setup: MySensor nodes running on NodeMcu/ESP8266 and each using an MQTT client gateway to send sensor status directly to my MQTT broker running on a Raspberry pi alongside Home Assistant. And I also had to replace sleep() with counters in the loop() code. Those error codes are described here.
            I spent many hours learning and configuring HA so sticking to that for now. Their community, like MySensors are very helpful.
            • Aswinth RajA
              Aswinth RajA
              Aswinth Raj
              Hey I am also interfacing Temperature and PIR sensor with NodeMCU and having the same problem as you are. Did you solve it?
              I followed this ESP8266 MQTT Tutorial and got everything working without any trouble. But then problem starts when I connect my Temperature and PIR Sesnor.
              So, are the sleep functions not implemented yet? If this does not work my only option is to go back to Arduino and push the data serially to ESP-01. Kindly suggest me a way out. I can provide circuit and code if required
