  3. Powering a transiver without external antenna?
6 Posts 3 Posters 1.6k Views 2 Watching
  • P
    P
    popunonkok
    Hi quick question. Is it dangerous to power a transiver like the one in the picture with external antenna when the antenna is removed?
    I have solderd the transiver to the arduino and need to program the arduino but I dont have the antenne here.
    I belive that in some cases you can fry the transiver. What do you think?
    YveauxY 1 Reply Last reply
    • P popunonkok
      YveauxY
      YveauxY
      @popunonkok just powering it will not brake it, but I wouldn't try transmitting with it. If you flash a mysensors sketch in it and start it, it will start transmitting immediately, so be careful!
      • P
        P
        popunonkok
        But dosent it start the sketch directly after I flash it?
        • P popunonkok
          YveauxY
          YveauxY
          Depends on how you flash it, I guess.
          Your original question was: "Is it dangerous to power a transiver like the one in the picture with external antenna when the antenna is removed?" so I tried to answer that.
          • P
            P
            popunonkok
            Yes I understand. I'm not criticising your answer. But I guess that means that I cant program it at the moment. Because that would mean the transiver would start transmitting directly.
            Hmmm... Unless I start with a 5-10 sec delay. =)
            It is a temperatur sensor sketch. I could probably code a 10 sec delay in the void setup() section. It would be an ugly solution but probably would work. =)
            • P popunonkok
              @popunonkok - unless you connect a normal radio to test.
