  3. Home Assistant
  4. My first relay. connected to GW 2.1.0
20 Posts 2 Posters 7.2k Views 3 Watching
  • xydixX
    xydixX
    xydix
    wrote on last edited by xydix
    My first relay....
    I am about to update my gateway to 2.1.0.
    While i am doing this i want to add a light sensor and a relay to it.
    I know i have a lot to learn about arduino and MySensors and now i am stuck.
     * Version 1.0 - Henrik EKblad
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
     * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,66   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    #define CHILD_ID_LIGHT 0
    #define LIGHT_SENSOR_ANALOG_PIN 4
    #define SN "Ljus Uppe"
    #define SV "1.0"
    bool initialValueSent = false;
    unsigned long WAIT_TIME = 30000; // Wait time between reads (in milliseconds)
    int lastLightLevel;
    void before()
        pinMode(pin, OUTPUT);
         if (!initialValueSent) {
        MyMessage msg2(sensor, V_STATUS);
        send(msg2.set(0));
        wait(1000);
      initialValueSent = true;
      sendSketchInfo(SN, SV);
        present(sensor, S_BINARY);
      int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
    //  Serial.println(lightLevel);
        send(msg.set(lightLevel));
        lastLightLevel = lightLevel;
      wait(WAIT_TIME);
      if (message.type==V_STATUS) {
        // Change relay state
        // Store state in eeprom
        // Write some debug info
        Serial.print(message.sensor);
    The lightsensor seems to work.
    I can't get the relay working. It is not showing in hass.
    Anyone want to check my sketch and gice me any tips.
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Hi!
      Your sketch looks ok. I recommend to always feedback state changes though, ie when receiving a message from the controller to change state of a relay also send a message with the new state back to the controller. You can remove the boolean initialValueSent, since you send the initial value in setup, which will only execute once.
      Can you capture a debug log from home assistant?
      • xydixX
        xydixX
        xydix
        In hass i get this during startup.
        mysensors.mysensors: child_id 0 already exists in children of node 0, cannot add child
        17-01-15 20:48:49 mysensors.mysensors: child_id 1 already exists in children of node 0, cannot add child
        I'm not sure child 1 is in my mysensors.json
        {"0": {"sensor_id": 0, "battery_level": 0, "type": 18, "sketch_name": "Ljus Uppe", "children": {"0": {"values": {"23": "3"}, "type": 16, "id": 0, "description": ""}, "sketch_version": "1.0", "protocol_version": "2.1.0"}
        I think this is all for node 0
        • martinhjelmareM
          martinhjelmareM
          martinhjelmare
          No, it doesn't look like child 1 is in the posted JSON. If you can capture a debug log after start of hass I think it could help to resolve this. Use this logger config and activate debug for mysensors config:
          logger:
            default: info
            logs:
              mysensors: debug
              homeassistant.components.mysensors: debug
          mysensors:
            debug: true
          • xydixX
            xydixX
            xydix
            I do not have access to my GW right now so i haven't removed
            But i guess this won't cause this problem?
            Here is my log after restartof hass
            https://hastebin.com/enutahepac.php
            I can't find anything, but i am a noob :D
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              I think the problem is that the setup and presentation functions in the gateway sketch have already run before home assistant connects to the gateway. I'll double check the logic flow of the ethernet gateway, to see if this can be the case.
              What you can do is request the value of each child from home assistant and send in the child values in the loop until you get a reply with the value after the request. You'd use the boolean initialValueSent to turn this behavior off.
              There's an example of this logic in the docs for mysensors on home-assistant.io under presentation header.
              https://home-assistant.io/components/mysensors/#presentation
              • xydixX
                xydixX
                xydix
                Thank you for your answears.
                I will try to modify the sketch when i have the time.
                Can i just add
                    request(CHILD_ID, V_STATUS);
                    wait(2000, C_SET, V_STATUS);
                In the loop?
                Isn't it possible to add a WAIT in the setup?
                My hass is at the moment running on an Raspberry Pi Zero so startup is pretty slow.
                • martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  I've checked the code of the ethernet gateway at mysensors github and presentation will be called whenever a client connects, but setup will not be called again. I don't think you should use setup to send initial values. I don't think the current implementation is designed to do that.
                  I suggest you follow the example on how to send initial values and request them, to make sure home assistant has received them, that I linked to.
                  Send an initial value.
                  Request the same initial value.
                  Wait for the corresponding reply from home assistant.
                  Do this in the loop within an if statement checking a boolean variable, that you can set to false when you have received all initial values. You check for received messages in the receive function, so that's where you should turn off the boolean. The example has all needed logic.
                  • xydixX
                    xydixX
                    xydix
                    Now i think i did as you said.
                    I did some copy, paste and got it working. I hope i did, hadn't had the time to physical add the relay yet but now it's showing i hass and i can change the state..
                     * LED purposes:
                    #define MY_SOFTSPI
                    // Enable to UDP
                    #define CHILD_ID_RELAY 1
                    #define SN "Gateway"
                    #define SV "1.0"
                    #define RELAY_PIN 3
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    bool state = false;
                    MyMessage msg2(CHILD_ID_RELAY, V_STATUS);
                    int lastLightLevel;
                      pinMode(RELAY_PIN, OUTPUT);
                      present(CHILD_ID_RELAY, S_BINARY);
                    //    Serial.println("Sending initial value");
                        send(msg2.set(state?RELAY_ON:RELAY_OFF));
                    //    Serial.println("Requesting initial value from controller");
                        request(CHILD_ID_RELAY, V_STATUS);
                        send(msg2.set(state?RELAY_ON:RELAY_OFF), true);
                      wait(WAIT_TIME);
                      if (message.isAck()) {
                    //     Serial.println("This is an ack from gateway");
                    //      Serial.println("Receiving initial value from controller");
                        state = (bool)message.getInt();
                    Is the sketch OK?
                    Anything i could remove or should add?
                    • xydixX xydix
                       * LED purposes:
                      #define MY_SOFTSPI
                      // Enable to UDP
                      #define SV "1.0"
                      #define RELAY_PIN 3
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      bool state = false;
                      int lastLightLevel;
                        wait(WAIT_TIME);
                      Is the sketch OK?
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @xydix said in My first relay. connected to GW 2.1.0:
                      You can remove this line in the loop after the call to wait.
                      This is not needed in the receive function either.
                      Otherwise the sketch looks good.
                      • xydixX
                        xydixX
                        xydix
                        Hi, again.
                        I did the changes you suggested and it seem to work ok when i flip the switch.
                        But now i have a strange thing happening.
                        I have a MySensors dimmer node (Node 2).
                        If i turn on my relay in the GW on.
                        And then, i change the state of the dimmer (turn on or off)
                        it will turn my relay in the GW off.
                        In this log i turn my relay on, turn my dimmer on or off.
                        and my relay get turned off.
                        I repeat these steps a couple of times.
                        17-01-22 23:30:51 homeassistant.components.http: Serving /api/services/homeassistant/turn_on to 192.168.1.8 (auth: True)
                        17-01-22 23:30:51 homeassistant.core: Bus:Handling <Event call_service[L]: domain=homeassistant, service_data=entity_id=light.kallarvaggen_2_0, service_call_id=3051336336-11, service=turn_on>
                        17-01-22 23:30:51 homeassistant.core: Bus:Handling <Event call_service[L]: domain=light, service_data=entity_id=['light.kallarvaggen_2_0'], service_call_id=3051336336-12, service=turn_on>
                        17-01-22 23:30:51 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-12>
                        17-01-22 23:30:51 mysensors.mysensors: Sending 2;0;1;0;2;1
                        17-01-22 23:30:51 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-11>
                        17-01-22 23:30:53 mysensors.mysensors: Received 2;0;1;0;2;1
                        0;1;1;0;2;0
                        2;0;1;0;3;100
                        17-01-22 23:30:53 homeassistant.components.mysensors: Update sensor_update: node 2
                        17-01-22 23:30:53 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=light.kallarvaggen_2_0, new_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:30:14.156158+01:00>, old_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=off, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:30:14.156158+01:00>>
                        17-01-22 23:30:53 homeassistant.components.mysensors: Update sensor_update: node 0
                        17-01-22 23:30:53 homeassistant.components.mysensors: Gateway 0 0: value_type 23, value = 0
                        17-01-22 23:30:53 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=sensor.gateway_0_0, new_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:30:53.836521+01:00>, old_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:30:49.700881+01:00>>
                        17-01-22 23:30:53 homeassistant.components.mysensors: Gateway 0 1: value_type 2, value = 0
                        17-01-22 23:30:53 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=switch.gateway_0_1, new_state=<state switch.gateway_0_1=off; friendly_name=Gateway 0 1, battery_level=0, node_id=0, V_STATUS=off, description=, device=192.168.1.66, child_id=1 @ 2017-01-22T23:30:53.919363+01:00>, old_state=<state switch.gateway_0_1=on; friendly_name=Gateway 0 1, battery_level=0, node_id=0, V_STATUS=on, description=, device=192.168.1.66, child_id=1 @ 2017-01-22T23:30:49.765215+01:00>>
                        17-01-22 23:30:54 homeassistant.components.mysensors: Update sensor_update: node 2
                        17-01-22 23:30:54 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=light.kallarvaggen_2_0, new_state=<state light.kallarvaggen_2_0=on; brightness=255, V_PERCENTAGE=100, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:30:54.040689+01:00>, old_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:30:14.156158+01:00>>
                        17-01-22 23:30:54 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, new_state=<state group.all_lights=on; friendly_name=all lights, hidden=True, order=5, entity_id=('light.toan_nere', 'light.kallarvaggen_2_0'), assumed_state=True, auto=True @ 2017-01-22T23:30:54.126221+01:00>, old_state=<state group.all_lights=off; friendly_name=all lights, hidden=True, order=5, entity_id=('light.toan_nere', 'light.kallarvaggen_2_0'), assumed_state=True, auto=True @ 2017-01-22T23:30:14.266930+01:00>>
                        17-01-22 23:30:57 homeassistant.components.http: Serving /api/services/homeassistant/turn_on to 192.168.1.8 (auth: True)
                        17-01-22 23:30:57 homeassistant.core: Bus:Handling <Event call_service[L]: domain=homeassistant, service_data=entity_id=switch.gateway_0_1, service_call_id=3051336336-13, service=turn_on>
                        17-01-22 23:30:57 homeassistant.core: Bus:Handling <Event call_service[L]: domain=switch, service_data=entity_id=['switch.gateway_0_1'], service_call_id=3051336336-14, service=turn_on>
                        17-01-22 23:30:57 mysensors.mysensors: Sending 0;1;1;0;2;1
                        17-01-22 23:30:57 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-14>
                        17-01-22 23:30:57 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-13>
                        17-01-22 23:30:57 mysensors.mysensors: Received 0;1;1;0;2;1
                        17-01-22 23:30:57 homeassistant.components.mysensors: Update sensor_update: node 0
                        17-01-22 23:30:57 homeassistant.components.mysensors: Gateway 0 0: value_type 23, value = 0
                        17-01-22 23:30:57 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=sensor.gateway_0_0, new_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:30:57.222167+01:00>, old_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:30:53.836521+01:00>>
                        17-01-22 23:30:57 homeassistant.components.mysensors: Gateway 0 1: value_type 2, value = 1
                        17-01-22 23:30:57 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=switch.gateway_0_1, new_state=<state switch.gateway_0_1=on; friendly_name=Gateway 0 1, battery_level=0, node_id=0, V_STATUS=on, description=, device=192.168.1.66, child_id=1 @ 2017-01-22T23:30:57.303626+01:00>, old_state=<state switch.gateway_0_1=off; friendly_name=Gateway 0 1, battery_level=0, node_id=0, V_STATUS=off, description=, device=192.168.1.66, child_id=1 @ 2017-01-22T23:30:53.919363+01:00>>
                        17-01-22 23:30:59 homeassistant.components.http: Serving /api/services/homeassistant/turn_off to 192.168.1.8 (auth: True)
                        17-01-22 23:30:59 homeassistant.core: Bus:Handling <Event call_service[L]: domain=homeassistant, service_data=entity_id=light.kallarvaggen_2_0, service_call_id=3051336336-15, service=turn_off>
                        17-01-22 23:30:59 homeassistant.core: Bus:Handling <Event call_service[L]: domain=light, service_data=entity_id=['light.kallarvaggen_2_0'], service_call_id=3051336336-16, service=turn_off>
                        17-01-22 23:30:59 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-16>
                        17-01-22 23:30:59 mysensors.mysensors: Sending 2;0;1;0;2;0
                        17-01-22 23:30:59 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-15>
                        17-01-22 23:31:00 homeassistant.components.device_tracker.netgear: Scanning
                        17-01-22 23:31:00 pynetgear: Get attached devices
                        17-01-22 23:31:01 mysensors.mysensors: Received 2;0;1;0;2;0
                        0;1;1;0;2;0
                        2;0;1;0;3;0
                        17-01-22 23:31:01 homeassistant.components.mysensors: Update sensor_update: node 2
                        17-01-22 23:31:01 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=light.kallarvaggen_2_0, new_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=100, V_STATUS=off, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:01.989013+01:00>, old_state=<state light.kallarvaggen_2_0=on; brightness=255, V_PERCENTAGE=100, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:30:54.040689+01:00>>
                        17-01-22 23:31:02 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, new_state=<state group.all_lights=off; friendly_name=all lights, hidden=True, order=5, entity_id=('light.toan_nere', 'light.kallarvaggen_2_0'), assumed_state=True, auto=True @ 2017-01-22T23:31:02.060892+01:00>, old_state=<state group.all_lights=on; friendly_name=all lights, hidden=True, order=5, entity_id=('light.toan_nere', 'light.kallarvaggen_2_0'), assumed_state=True, auto=True @ 2017-01-22T23:30:54.126221+01:00>>
                        17-01-22 23:31:02 homeassistant.components.mysensors: Update sensor_update: node 0
                        17-01-22 23:31:02 homeassistant.components.mysensors: Gateway 0 0: value_type 23, value = 0
                        17-01-22 23:31:02 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=sensor.gateway_0_0, new_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:02.205818+01:00>, old_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:30:57.222167+01:00>>
                        17-01-22 23:31:02 homeassistant.components.mysensors: Gateway 0 1: value_type 2, value = 0
                        17-01-22 23:31:02 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=switch.gateway_0_1, new_state=<state switch.gateway_0_1=off; friendly_name=Gateway 0 1, battery_level=0, node_id=0, V_STATUS=off, description=, device=192.168.1.66, child_id=1 @ 2017-01-22T23:31:02.299902+01:00>, old_state=<state switch.gateway_0_1=on; friendly_name=Gateway 0 1, battery_level=0, node_id=0, V_STATUS=on, description=, device=192.168.1.66, child_id=1 @ 2017-01-22T23:30:57.303626+01:00>>
                        17-01-22 23:31:02 homeassistant.components.mysensors: Update sensor_update: node 2
                        17-01-22 23:31:02 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=light.kallarvaggen_2_0, new_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=off, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:01.989013+01:00>, old_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=100, V_STATUS=off, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:01.989013+01:00>>
                        17-01-22 23:31:05 homeassistant.components.http: Serving /api/services/homeassistant/turn_on to 192.168.1.8 (auth: True)
                        17-01-22 23:31:05 homeassistant.core: Bus:Handling <Event call_service[L]: domain=homeassistant, service_data=entity_id=switch.gateway_0_1, service_call_id=3051336336-17, service=turn_on>
                        17-01-22 23:31:05 homeassistant.core: Bus:Handling <Event call_service[L]: domain=switch, service_data=entity_id=['switch.gateway_0_1'], service_call_id=3051336336-18, service=turn_on>
                        17-01-22 23:31:05 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-18>
                        17-01-22 23:31:05 mysensors.mysensors: Sending 0;1;1;0;2;1
                        17-01-22 23:31:05 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-17>
                        17-01-22 23:31:05 mysensors.mysensors: Received 0;1;1;0;2;1
                        17-01-22 23:31:05 homeassistant.components.mysensors: Update sensor_update: node 0
                        17-01-22 23:31:05 homeassistant.components.mysensors: Gateway 0 0: value_type 23, value = 0
                        17-01-22 23:31:05 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=sensor.gateway_0_0, new_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:05.320905+01:00>, old_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:02.205818+01:00>>
                        17-01-22 23:31:05 homeassistant.components.mysensors: Gateway 0 1: value_type 2, value = 1
                        17-01-22 23:31:05 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=switch.gateway_0_1, new_state=<state switch.gateway_0_1=on; friendly_name=Gateway 0 1, battery_level=0, node_id=0, V_STATUS=on, description=, device=192.168.1.66, child_id=1 @ 2017-01-22T23:31:05.384134+01:00>, old_state=<state switch.gateway_0_1=off; friendly_name=Gateway 0 1, battery_level=0, node_id=0, V_STATUS=off, description=, device=192.168.1.66, child_id=1 @ 2017-01-22T23:31:02.299902+01:00>>
                        17-01-22 23:31:07 homeassistant.components.http: Serving /api/services/homeassistant/turn_on to 192.168.1.8 (auth: True)
                        17-01-22 23:31:08 homeassistant.core: Bus:Handling <Event call_service[L]: domain=homeassistant, service_data=entity_id=light.kallarvaggen_2_0, service_call_id=3051336336-19, service=turn_on>
                        17-01-22 23:31:08 homeassistant.core: Bus:Handling <Event call_service[L]: domain=light, service_data=entity_id=['light.kallarvaggen_2_0'], service_call_id=3051336336-20, service=turn_on>
                        17-01-22 23:31:08 mysensors.mysensors: Sending 2;0;1;0;2;1
                        17-01-22 23:31:08 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-20>
                        17-01-22 23:31:08 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-19>
                        17-01-22 23:31:10 mysensors.mysensors: Received 2;0;1;0;2;1
                        0;1;1;0;2;0
                        2;0;1;0;3;100
                        17-01-22 23:31:10 homeassistant.components.mysensors: Update sensor_update: node 2
                        17-01-22 23:31:10 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=light.kallarvaggen_2_0, new_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:01.989013+01:00>, old_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=off, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:01.989013+01:00>>
                        17-01-22 23:31:10 homeassistant.components.mysensors: Update sensor_update: node 0
                        17-01-22 23:31:10 homeassistant.components.mysensors: Gateway 0 0: value_type 23, value = 0
                        17-01-22 23:31:10 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=sensor.gateway_0_0, new_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:10.311148+01:00>, old_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:05.320905+01:00>>
                        17-01-22 23:31:10 homeassistant.components.mysensors: Gateway 0 1: value_type 2, value = 0
                        17-01-22 23:31:10 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=switch.gateway_0_1, new_state=<state switch.gateway_0_1=off; friendly_name=Gateway 0 1, battery_level=0, node_id=0, V_STATUS=off, description=, device=192.168.1.66, child_id=1 @ 2017-01-22T23:31:10.407123+01:00>, old_state=<state switch.gateway_0_1=on; friendly_name=Gateway 0 1, battery_level=0, node_id=0, V_STATUS=on, description=, device=192.168.1.66, child_id=1 @ 2017-01-22T23:31:05.384134+01:00>>
                        17-01-22 23:31:10 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=light.kallarvaggen_2_0, new_state=<state light.kallarvaggen_2_0=on; brightness=255, V_PERCENTAGE=100, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:10.508762+01:00>, old_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:01.989013+01:00>>
                        17-01-22 23:31:10 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, new_state=<state group.all_lights=on; friendly_name=all lights, hidden=True, order=5, entity_id=('light.toan_nere', 'light.kallarvaggen_2_0'), assumed_state=True, auto=True @ 2017-01-22T23:31:10.570169+01:00>, old_state=<state group.all_lights=off; friendly_name=all lights, hidden=True, order=5, entity_id=('light.toan_nere', 'light.kallarvaggen_2_0'), assumed_state=True, auto=True @ 2017-01-22T23:31:02.060892+01:00>>
                        17-01-22 23:31:12 homeassistant.components.device_tracker.netgear: Scanning
                        17-01-22 23:31:12 pynetgear: Get attached devices
                        17-01-22 23:31:13 homeassistant.components.http: Serving /api/services/homeassistant/turn_off to 192.168.1.8 (auth: True)
                        17-01-22 23:31:13 homeassistant.core: Bus:Handling <Event call_service[L]: domain=homeassistant, service_data=entity_id=light.kallarvaggen_2_0, service_call_id=3051336336-21, service=turn_off>
                        17-01-22 23:31:13 homeassistant.core: Bus:Handling <Event call_service[L]: domain=light, service_data=entity_id=['light.kallarvaggen_2_0'], service_call_id=3051336336-22, service=turn_off>
                        17-01-22 23:31:14 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-22>
                        17-01-22 23:31:14 mysensors.mysensors: Sending 2;0;1;0;2;0
                        17-01-22 23:31:14 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-21>
                        17-01-22 23:31:16 mysensors.mysensors: Received 2;0;1;0;2;0
                        0;1;1;0;2;0
                        2;0;1;0;3;0
                        17-01-22 23:31:16 homeassistant.components.mysensors: Update sensor_update: node 2
                        17-01-22 23:31:16 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=light.kallarvaggen_2_0, new_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=100, V_STATUS=off, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:16.136777+01:00>, old_state=<state light.kallarvaggen_2_0=on; brightness=255, V_PERCENTAGE=100, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:10.508762+01:00>>
                        17-01-22 23:31:16 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, new_state=<state group.all_lights=off; friendly_name=all lights, hidden=True, order=5, entity_id=('light.toan_nere', 'light.kallarvaggen_2_0'), assumed_state=True, auto=True @ 2017-01-22T23:31:16.236923+01:00>, old_state=<state group.all_lights=on; friendly_name=all lights, hidden=True, order=5, entity_id=('light.toan_nere', 'light.kallarvaggen_2_0'), assumed_state=True, auto=True @ 2017-01-22T23:31:10.570169+01:00>>
                        17-01-22 23:31:16 homeassistant.components.mysensors: Update sensor_update: node 0
                        17-01-22 23:31:16 homeassistant.components.mysensors: Gateway 0 0: value_type 23, value = 0
                        17-01-22 23:31:16 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=sensor.gateway_0_0, new_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:16.321401+01:00>, old_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:10.311148+01:00>>
                        17-01-22 23:31:16 homeassistant.components.mysensors: Gateway 0 1: value_type 2, value = 0
                        17-01-22 23:31:16 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=light.kallarvaggen_2_0, new_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=off, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:16.136777+01:00>, old_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=100, V_STATUS=off, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:16.136777+01:00>>
                        17-01-22 23:31:18 homeassistant.components.http: Serving /api/services/homeassistant/turn_on to 192.168.1.8 (auth: True)
                        17-01-22 23:31:18 homeassistant.core: Bus:Handling <Event call_service[L]: domain=homeassistant, service_data=entity_id=light.kallarvaggen_2_0, service_call_id=3051336336-23, service=turn_on>
                        17-01-22 23:31:18 homeassistant.core: Bus:Handling <Event call_service[L]: domain=light, service_data=entity_id=['light.kallarvaggen_2_0'], service_call_id=3051336336-24, service=turn_on>
                        17-01-22 23:31:18 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-24>
                        17-01-22 23:31:18 mysensors.mysensors: Sending 2;0;1;0;2;1
                        17-01-22 23:31:18 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=3051336336-23>
                        17-01-22 23:31:20 mysensors.mysensors: Received 2;0;1;0;2;1
                        0;1;1;0;2;0
                        2;0;1;0;3;100
                        17-01-22 23:31:20 homeassistant.components.mysensors: Update sensor_update: node 2
                        17-01-22 23:31:20 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=light.kallarvaggen_2_0, new_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:16.136777+01:00>, old_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=off, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:16.136777+01:00>>
                        17-01-22 23:31:20 homeassistant.components.mysensors: Update sensor_update: node 0
                        17-01-22 23:31:20 homeassistant.components.mysensors: Gateway 0 0: value_type 23, value = 0
                        17-01-22 23:31:20 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=sensor.gateway_0_0, new_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:20.335924+01:00>, old_state=<state sensor.gateway_0_0=0; friendly_name=Gateway 0 0, battery_level=0, node_id=0, V_LIGHT_LEVEL=0, unit_of_measurement=%, description=, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:16.321401+01:00>>
                        17-01-22 23:31:20 homeassistant.components.mysensors: Gateway 0 1: value_type 2, value = 0
                        17-01-22 23:31:20 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=light.kallarvaggen_2_0, new_state=<state light.kallarvaggen_2_0=on; brightness=255, V_PERCENTAGE=100, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:20.488962+01:00>, old_state=<state light.kallarvaggen_2_0=off; V_PERCENTAGE=0, V_STATUS=on, friendly_name=Källarväggen 2 0, battery_level=0, node_id=2, description=, supported_features=145, device=192.168.1.66, child_id=0 @ 2017-01-22T23:31:16.136777+01:00>>
                        17-01-22 23:31:20 homeassistant.core: Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, new_state=<state group.all_lights=on; friendly_name=all lights, hidden=True, order=5, entity_id=('light.toan_nere', 'light.kallarvaggen_2_0'), assumed_state=True, auto=True @ 2017-01-22T23:31:20.548609+01:00>, old_state=<state group.all_lights=off; friendly_name=all lights, hidden=True, order=5, entity_id=('light.toan_nere', 'light.kallarvaggen_2_0'), assumed_state=True, auto=True @ 2017-01-22T23:31:16.236923+01:00>>
                        17-01-22 23:31:24 homeassistant.components.http: Serving /api/error_log to 192.168.1.8 (auth: True)
                        • martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          You have to filter out messages that are coming from other nodes to the gateway, but is meant for the controller. You can check Message.sender in receive. Messages from nodes will from Message.senderreturn the node id of the nodes, but from the controller it will be 0, ie the same as the node id of the gateway. So only respond to messages where Message.sender is 0 in the receive function of the gateway.
                          • xydixX
                            xydixX
                            xydix
                            Okay. I Think i understand.
                            Didn't find much about Message.sender
                            But after searching the forum I found something I hope.
                            Shall I change this ?
                            To this?
                              if (message.type == V_STATUS && Message.sender == 0) {
                            • martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              if (message.type == V_STATUS && message.sender == 0) {
                              should work.
                              • xydixX
                                xydixX
                                xydix
                                Tried it.
                                Now i can't change the state of the relay anymore.
                                I am checking my log again (Post 11 i think.)
                                I added an "arrow" in the log below. Is that right?
                                0;1;1;0;2;0   <<<--------- Is this right????? Where does it come from?
                                2;0;1;0;3;100
                                • martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  That message must come from the gateway, from the receive function. That's why we have to filter messages in the receive function. Please post you latest sketch, so I can have a look. I'm thinking there might be a bug in the message getter that you're using, since the gateway always sends a turn off message. If the getter would be working it should change the state of the payload according to the message received from node 2.
                                  • xydixX
                                    xydixX
                                    xydix
                                    EDIT!!!!!!!!
                                    I am sorry. I had several sketches on my computer, trying different stuff.
                                    When i added && message.sender == 0) { I did this in a sketch where i tried to switch the ON / OFF
                                    #define RELAY_ON 0
                                    #define RELAY_OFF 1
                                    This is the error.
                                    The reason i did this is that I am controlling a wall outlet and want it to be ON even if I remove my GW or if it fails.
                                    I changed this and got it working now.
                                    The relay changes state and keep this even if i turn node 2 on or off.
                                    Sorry for this and thank you for all help.
                                    I read the serial protocol and the API in the MySensors site but couldn't find anything about message.sender stuff.
                                    ------ Original Post-------
                                    Hi.
                                    At first, the gateway switch was turning on when i tuned node 2 on, then off when i turned node 2 off.
                                    Then i updated node 2 to 2.1.1 as it was still on 2.0.0.
                                    I added MY_REPEATER_FEATURE to node2 as it was planned.
                                    After this i behaivs as i said in post 11.
                                    Before i did this gateway switch "followed" the state of node 2.
                                    Now it will only turn off if it is on.
                                     * LED purposes:
                                    #define MY_SOFTSPI
                                    // Enable to UDP
                                    #define SV "1.0"
                                    #define RELAY_PIN 3
                                    #define RELAY_ON 0
                                    #define RELAY_OFF 1
                                    bool state = false;
                                    int lastLightLevel;
                                      wait(WAIT_TIME);
                                    This is my gateway sketchright now with
                                    With && message.sender == 0 I can't change the state of the relay at all
                                    • xydixX xydix
                                      EDIT!!!!!!!!
                                      #define RELAY_ON 0
                                      #define RELAY_OFF 1
                                      This is the error.
                                      Hi.
                                       * LED purposes:
                                      #define MY_SOFTSPI
                                      // Enable to UDP
                                      #define SV "1.0"
                                      #define RELAY_PIN 3
                                      #define RELAY_ON 0
                                      #define RELAY_OFF 1
                                      bool state = false;
                                      int lastLightLevel;
                                        wait(WAIT_TIME);
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @xydix
                                      Great that you got it working! I didn't follow exactly what you did or didn't do to get it working, though. :smile:
                                      Unfortunately the API doesn't contain exactly everything about the message object. Maybe we can ask @hek to add this?
                                      message.sender
                                      message.destination
                                      message.last
                                      message.type
                                      message.sensor
                                      Should probably be added.
                                      • xydixX
                                        xydixX
                                        xydix
                                        When i change
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                        to
                                        #define RELAY_ON 0
                                        #define RELAY_OFF 1
                                        The relay stops working.
                                        Seems strange, but I tried this even before I discovered the problem with node 2.
                                        When I change it back, the relay works.
                                        If i want to present my relay as light,
                                        Should i use S_DIMMER and V_LIGHT?
                                        • martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          When you invert the defines for relay, you are not only inverting how the relay will react on digitalWrite, you are also inverting how the state of the relay is reported back to home assistant. This is where the problem gets introduced. As home assistant on turn on action always sends a 1 as payload to the device, the device will now send a 0 back as state feedback. This will tell home assistant that the state should be off, instead of on. So it will be impossible to turn the relay on from home assistant.
                                          If you do want to invert the high/low behavior of the relay, you need to decouple the high/low defines from the state reporting 1/0, ie use different defines.
                                          If you want the device to be shown as a light in home assistant you need to present the device as S_DIMMER and send both V_PERCENTAGE and V_STATUS, in mysensors version 2.*. S_BINARY and S_LIGHT will be shown as a switch.
