  3. Sleep function breaks code
6 Posts 3 Posters 2.2k Views 2 Watching
  • martinsM
    martinsM
    martins
    Re: [💬 Door](Window and Push-button Sensor)
    As soon as I use the sleep function with this door-sensor-code it breaks it. Works awhile and then gone.
    sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
    Serial output:
    !TSM:UPL FAIL, SNP
    TSM:FPAR
    TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    And there it dies ! Any suggestions?
    Thanks,
    Martin
    • martinsM martins
      Serial output:
      !TSM:UPL FAIL, SNP
      TSM:FPAR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      Thanks,
      Martin
      @martins which Arduino are you using? Which pin are you using? Which sketch are you using? (I am unable to find a sketch that references PRIMARY_BUTTON_PIN, searched through the code for the library and the MySensorsArduinoExamples reporistory). How are you powering the sensor?
      There have been some threads about problems with CHANGE:
      https://forum.mysensors.org/topic/5552/pin-change-interrupt-not-firing-with-mysensors/
      https://forum.mysensors.org/topic/5807/interrupt-and-sleep/
      martinsM 1 Reply Last reply
      • martinsM
        martinsM
        martins
        Thanks. I'm trying these 2 but both givers the same results:
        • The MySensors Arduino library handles the wireless radio link and protocol
        • between your home built sensors/actuators and HA controller of choice.
        • The sensors forms a self healing radio network with optional repeaters. Each
        • repeater and gateway builds a routing tables in EEPROM which keeps track of the
        • network topology allowing messages to be routed to nodes.
        • Created by Henrik Ekblad henrik.ekblad@mysensors.org
        • Copyright (C) 2013-2015 Sensnology AB
        • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
        • Documentation: http://www.mysensors.org
        • Support Forum: http://forum.mysensors.org
        • This program is free software; you can redistribute it and/or
        • modify it under the terms of the GNU General Public License
        • version 2 as published by the Free Software Foundation.
        • DESCRIPTION
        • Simple binary switch example
        • Connect button or door/window reed switch between
        • digitial I/O pin 3 (BUTTON_PIN below) and GND.
        • http://www.mysensors.org/build/binary
        // #define MY_RADIO_NRF24
        #define MY_RADIO_RFM69
        #define MY_IS_RFM69HW
        #if F_CPU == 8000000L
        #define MY_BAUD_RATE 38400
        #include <Bounce2.h>
        #define CHILD_ID 3
        #define BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
        Bounce debouncer = Bounce();
        int oldValue=-1;
        int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
        unsigned long SLEEP_TIME = 60000; // sleep time between reads (seconds * 1000 milliseconds)
        int oldBatteryPcnt = 0;
        #if defined(AVR_ATmega2560)
        analogReference(INTERNAL1V1);
        #else
        analogReference(INTERNAL);
        // Setup the button
        pinMode(BUTTON_PIN,INPUT);
        // Activate internal pull-up
        debouncer.attach(BUTTON_PIN);
        debouncer.interval(5);
        void presentation() {
        present(CHILD_ID, S_DOOR);
        sendSketchInfo("Door Sensor", "1.0");
        // Check if digital input has changed and send in new value
        debouncer.update();
        // Get the update value
        int value = debouncer.read();
        if (value != oldValue) {
        // Send in the new value
        send(msg.set(value==HIGH ? 1 : 0));
        oldValue = value;
             // get the battery Voltage
        #ifdef MY_DEBUG
        Serial.println(sensorValue);
        #ifdef MY_DEBUG
        float batteryV = sensorValue * 0.003363075;
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
        // sleep(SLEEP_TIME);
        sleep(BUTTON_PIN-2, CHANGE, SLEEP_TIME);
        • DESCRIPTION
        • Interrupt driven binary switch example with dual interrupts
        • Author: Patrick 'Anticimex' Fallberg
        • Connect one button or door/window reed switch between
        • digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
        • one in similar fashion on digital I/O pin 2.
        • This example is designed to fit Arduino Nano/Pro Mini
        //#define MY_RADIO_NRF24
        #define BATTERY_SENSE_PIN A0
        #define SKETCH_NAME "Binary Sensor"
        #define SKETCH_MAJOR_VER "1"
        #define SKETCH_MINOR_VER "0"
        #define PRIMARY_CHILD_ID 3
        //#define SECONDARY_CHILD_ID 4
        #define PRIMARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
        //#define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
        #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
        #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
        //#if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
        //#error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
        //#endif
        //#if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
        //#error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
        //#endif
        //#if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
        //#error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
        //#endif
        MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
        //MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
        // Setup the buttons
        pinMode(PRIMARY_BUTTON_PIN, INPUT);
        // pinMode(SECONDARY_BUTTON_PIN, INPUT);
        // Activate internal pull-ups
        digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
        // digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
        sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
        // Register binary input sensor to sensor_node (they will be created as child devices)
        present(PRIMARY_CHILD_ID, S_DOOR);
        // present(SECONDARY_CHILD_ID, S_DOOR);
        uint8_t value;
        static uint8_t sentValue=2;
        //static uint8_t sentValue2=2;
        //attachInterrupt(0, wakeUp, LOW);
        //sleep(5);
        value = digitalRead(PRIMARY_BUTTON_PIN);
        if (value != sentValue) {
        // Value has changed from last transmission, send the updated value
        sentValue = value;
        // value = digitalRead(SECONDARY_BUTTON_PIN);
        // if (value != sentValue2) {
        // // Value has changed from last transmission, send the updated value
        // send(msg2.set(value==HIGH ? 1 : 0));
        // sentValue2 = value;
        // Sleep until something happens with the sensor
        sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SLEEP_TIME);
        delay(2000);
        Regards,
        Martin
          martinsM
          martinsM
          martins
          @mfalkvidd
          It's almost as if the RFM69 radio is not transmitting anymore:
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          What does TNR mean ? Transmitter Not Ready ? I looked through the serial API but can't find any reference. Neither in the sensor API nor library API. Any suggestions ?
          Thanks,
          Martin
          • D
            D
            DavidZH
            first of all you should change the delay(2000) right after the sleep to wait(2000). Effect is exactly the same, but this will not stop your Arduino from doing anything. For the rest I'm not sure why the communication between your Arduino and radio stops. TNR is indeed "Transport not ready"...
            • martinsM
              martinsM
              martins
              OK it's working. Main fix I think is I used the new 2.1.1 library and all comms to the RFM69 radio seems to be fixed.
              Current code:
              • DESCRIPTION
              #define CHILD_ID 3
              int oldValue=-1;
              // Setup the button
              sendSketchInfo("Binary Sensor", "1.0");
              int value = digitalRead(BUTTON_PIN);
              #ifdef MY_DEBUG
              Serial.println("Sensor Value");
              Serial.println(value);
              sleep(BUTTON_PIN-2, CHANGE, 0);
              Thanks,
              Martin
