  3. Relay Actuator with momentary (pulse) action
7 Posts 6 Posters 3.2k Views 6 Watching
  • drradkinD Offline
    drradkinD Offline
    drradkin
    What do I need to edit in the relay actuator sketch in order to turn the relay on for about .5 seconds then turn it immediately back off?
     * Version 1.0 - Henrik Ekblad
    #define MY_REPEATER_FEATURE
    void before()
            pinMode(pin, OUTPUT);
            present(sensor, S_BINARY);
        if (message.type==V_STATUS) {
            // Change relay state
            // Store state in eeprom
            // Write some debug info
            Serial.print(message.sensor);
    • drradkinD drradkin
      void before()
      @drradkin change
      to
      if (message.getBool() == RELAY_ON) {
      digitalWrite(message.sensor-1+RELAY_1, RELAY_ON);
      wait(500);
      digitalWrite(message.sensor-1+RELAY_1, RELAY_OFF);
      and
      to
      if (loadState(sensor) == RELAY_ON) {
      digitalWrite(pin, RELAY_ON);
      wait(500);
      digitalWrite(pin, RELAY_OFF);
      A 1 Reply Last reply
        @drradkin change
        to
        wait(500);
        and
        to
        wait(500);
        A Offline
        A Offline
        Andrea_J
        @mfalkvidd Hello, today I used your suggestion, but in the meanwhile the code of RelayActuator.ino has changed a little bit.
        So this is what has changed and how I adjusted. This could be useful to another beginner like me.
        Change:
        digitalWrite(message.getSensor()-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        to:
            digitalWrite(message.getSensor()-1+RELAY_PIN, RELAY_ON);
            wait(500);
            digitalWrite(message.getSensor()-1+RELAY_PIN, RELAY_OFF);
        • alowhumA Offline
          alowhumA Offline
          alowhum
          Here is my code, which I used to hack my dishwasher so I can turn it on via my smart home system. The code is designed to work well with the Mozilla WebThings gateway and the Candle project, which is based on MySensors. But it but should work just fine with any smart home controller that supports MySensors.
           * Only sends a quick pulse via a relay. Useful to hack other devices with push
           * buttons. In my case, a cheap IKEA dishwasher that didn't have a timer functionality.
          #define DEBUG
          #define LOOP_DURATION 1000                          // The main loop runs every x milliseconds. This main loop starts the modem, and from then on periodically requests the password.
          #define SECONDS_BETWEEN_HEARTBEAT_TRANSMISSION 120  // The smart lock might not send any data for a very long time if it isn't used. Sending a heartbeat tells the controller: I'm still there.
          //#define RF_NANO                                     // RF-Nano. Check this box if you are using the RF-Nano Arduino, which has a built in radio. The Candle project uses the RF-Nano.
          #ifdef RF_NANO
          // If you are using an RF-Nano, you have to switch CE and CS pins.
          #define MY_RF24_CS_PIN 9                            // Used by the MySensors library.
          #define MY_RF24_CE_PIN 10                           // Used by the MySensors library.
          #define MY_RADIO_RF24
          // Mysensors advanced settings
          #define MY_TRANSPORT_WAIT_READY_MS 10000            // Try connecting for 10 seconds. Otherwise just continue.
          //#define MY_RF24_CHANNEL 100                       // In EU the default channel 76 overlaps with wifi, so you could try using channel 100. But you will have to set this up on every device, and also on the controller.
          //#define MY_RF24_DATARATE RF24_1MBPS                 // Slower datarate makes the network more stable
          //#define MY_RF24_DATARATE RF24_250KBPS             // Slower datarate increases wireless range
          //#define MY_NODE_ID 10                             // Giving a node a manual ID can in rare cases fix connection issues.
          //#define MY_PARENT_NODE_ID 0                       // Fixating the ID of the gatewaynode can in rare cases fix connection issues.
          //#define MY_PARENT_NODE_IS_STATIC                  // Used together with setting the parent node ID. Daking the controller ID static can in rare cases fix connection issues.
          #define MY_SPLASH_SCREEN_DISABLED                   // Saves a little memory.
          //#define MY_DISABLE_RAM_ROUTING_TABLE_FEATURE      // Saves a little memory.
          // Mysensors security
          //#define DEBUG_SIGNING
          //#define MY_ENCRYPTION_SIMPLE_PASSWD "changeme"      // Be aware, the length of the password has an effect on memory use.
          //#define MY_SECURITY_SIMPLE_PASSWD "changeme"      // Be aware, the length of the password has an effect on memory use.
          //#define MY_SIGNING_SOFT_RANDOMSEED_PIN A7         // Setting a pin to pickup random electromagnetic noise helps make encryption more secure.
          //#define MY_REPEATER_FEATURE
          #define PULSELENGTH 500 // How long the pulse should last (how long the button should be pressed).
          #define RADIO_DELAY 100                             // Milliseconds delay betweeen radio signals. This gives the radio some breathing room.
          MyMessage relay_message(RELAY_1, V_STATUS); // A generic boolean state message.
          boolean desiredState = false;
          boolean send_all_values = 1;
          void before()
            pinMode(RELAY_1, OUTPUT);
          	digitalWrite(RELAY_1, LOW);
          	sendSketchInfo(F("Dish washer"), F("1.0")); wait(RADIO_DELAY);
            present(RELAY_1, S_BINARY, F("Power") ); wait(RADIO_DELAY);
            send_all_values = true;                           // Whenever a new presentation is requested, we should also send the current values of the children.
            Serial.begin(115200);
            Serial.println(F("Hello world, I am a relay."));
          void send_values()
          #ifdef DEBUG
            Serial.println(F("Sending button states"));
            send(relay_message.set(desiredState)); wait(RADIO_DELAY); // Send initial state
            if( send_all_values ){
          #ifdef DEBUG
              Serial.println(F("RESENDING VALUES"));
              send_all_values = 0;
              send_values();
            // Pulse the relay
            if(desiredState == 1){
              digitalWrite(RELAY_1, RELAY_ON);
              Serial.println(F("Turning on"));
              wait(PULSELENGTH);
              digitalWrite(RELAY_1, RELAY_OFF);
              Serial.println(F("Turned off"));
              desiredState = 0;
              send(relay_message.setSensor(RELAY_1).set(desiredState)); // Send off state
            static unsigned long last_loop_time = 0;          // Holds the last time the main loop ran.
            static byte loop_counter = 0;                     // Count how many loops have passed (reset to 0 after at most 254 loops).
            if( millis() - last_loop_time > LOOP_DURATION ){ // Runs every second
              last_loop_time = millis();
              wdt_reset();                                  // Reset the watchdog timer. If this doesn't happen, the device must have crashed, and it will be automatically rebooted by the watchdog.
              if( loop_counter >= SECONDS_BETWEEN_HEARTBEAT_TRANSMISSION ){ // If a couple of minutes have passed, tell the controller we're still here
                loop_counter = 0;
                Serial.println(F("Sending heartbeat"));
                sendHeartbeat();
            if( message.isAck() ){
          #ifdef DEBUG
              Serial.println(F("- Echo"));
            else if (message.type==V_STATUS) { // We only expect one type of message from controller. But we better check anyway.
              Serial.print("Incoming change for child:");
              desiredState = message.getBool(); //?RELAY_ON:RELAY_OFF;
              send(relay_message.setSensor(message.sensor).set(desiredState)); // Send on state
          • A Offline
            A Offline
            adds666
            Morning all,
            I'm smashing together 3 types of sketches here (3 x Dimmer, 4 x Button, 2 x relay) and am struggling with this 'momentary' relay action. The relays do not fire at all.
            Everything is presented to the controller (Openhab) via an RS485 gateway, and the dimmer and buttons work and feedback their states. The log output shows that this device is receiving a 0 and 1 from Openhab on its relay nodes (7 and 8) however, still no actuation.
            I wonder if someone was able to take a cursery glance at my code. The relay sections of code are bracketed with // Relay
             * Version 1.0 - February 15, 2014 - Bruce Lacey
             * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
             * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
             * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
             * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
             * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
             * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
             * to the LED negative terminal and the MOSFET Source pin is connected to ground.
            // Button
            // The below includes 4 buttons using code examples from here:  https://forum.mysensors.org/topic/9538/multiple-switch-inputs/8
            // Button
            // Relay
            // The below includes 2 relays from https://www.mysensors.org/build/relay
            // https://forum.mysensors.org/topic/5906/relay-actuator-with-momentary-pulse-action/2
            // Relay
            //#define MY_RADIO_RF24
            //#define MY_RADIO_NRF5_ESB
            //#define MY_RADIO_RFM95
            // Enable RS485 transport layer
            #define MY_RS485
            // Define this to enables DE-pin management on defined pin
            #define MY_RS485_DE_PIN 2
            // Set RS485 baud rate to use
            #define MY_RS485_BAUD_RATE 9600
            #define MY_NODE_ID 4
            // Button
            #include <Bounce2.h>
            #define SN "N004"
            #define SV "1.0"
            #define noLEDs 2
            const int LED_Pin[] = {5, 6};
            #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
            static int currentLevel1 = 0;  // Current dim level...
            static int currentLevel2 = 0;  // Current dim level...
            MyMessage dimmer1Msg(1, V_DIMMER);
            MyMessage light1Msg(1, V_LIGHT);
            MyMessage dimmer2Msg(2, V_DIMMER);
            MyMessage light2Msg(2, V_LIGHT);
            // Button
            #define FIRST_BUTTON_ID 3
            #define MAX_BUTTON 4
            const uint8_t buttonPin[] = {4, 10, 11, 12};   //  switch around pins to your desire
            Bounce debouncer[MAX_BUTTON];
            MyMessage buttonMsg(0, V_TRIPPED);
            bool oldButton[MAX_BUTTON] = {false};
            // Button
            // Relay
            #define FIRST_RELAY_ID 7
            #define MAX_RELAY 2
            const uint8_t relayPin[] = {3, 7};  // Pins of relays
            MyMessage relayMsg(0, V_STATUS);
            #define RELAY_ON 1
            #define RELAY_OFF 0
            // Relay
            void before()
             * Dimmable LED initialization method
              // LEDS
              // Pull the gateway's current dim level - restore light level upon sendor node power-up
            for (int sensor=1; sensor<=noLEDs; sensor++){
              request( sensor, V_DIMMER );
            // Button
            for (uint8_t i = 0; i < MAX_BUTTON; i++) {
                debouncer[i] = Bounce();                        // initialize debouncer
                debouncer[i].attach(buttonPin[i], INPUT_PULLUP);
                debouncer[i].interval(5);
                oldButton[i] =  debouncer[i].read();
            // Button
            // Relay
            for (uint8_t i = 0; i < MAX_RELAY; i++) {
              pinMode(relayPin[i], OUTPUT);
              //digitalWrite(relayPin, loadState(i)?RELAY_ON:RELAY_OFF);
              if (loadState(i) == RELAY_ON) {
            digitalWrite(relayPin, RELAY_ON);
            wait(500);
            digitalWrite(relayPin, RELAY_OFF);
            // Relay
            void presentation() {
             present(sensor, S_DIMMER);
             wait(2);
            // Button
             for (int i = 0; i < MAX_BUTTON; i++) { //i < numSensors &&
                present(FIRST_BUTTON_ID + i, S_DOOR);
             // Button
            // Relay
            for (int i = 0; i < MAX_RELAY; i++)   {
              present(FIRST_RELAY_ID + i, S_BINARY);
            // Relay
              sendSketchInfo(SN, SV);
             *  Dimmable LED main processing loop
            // Button
              bool button[MAX_BUTTON];
                debouncer[i].update();
                button[i] = debouncer[i].read();
                if (button[i] != oldButton[i]) {
                  send(buttonMsg.setSensor(FIRST_BUTTON_ID + i).set( button[i])); // Send tripped value to gw
                  oldButton[i] = button[i];
              // Button
              if (message.type == V_LIGHT || message.type == V_DIMMER) {
                if (message.sensor == 1) {
                int requestedLevel1 = atoi( message.data );
                requestedLevel1 *= ( message.type == V_LIGHT ? 100 : 1 );
                // Clip incoming level to valid range of 0 to 100
                requestedLevel1 = requestedLevel1 > 100 ? 100 : requestedLevel1;
                requestedLevel1 = requestedLevel1 < 0   ? 0   : requestedLevel1;
                 fadeToLevel1( requestedLevel1, message.sensor );
                send(light1Msg.set(currentLevel1 > 0 ? 1 : 0));
                send(dimmer1Msg.set(currentLevel1) );}
               if (message.sensor == 2) {
                int requestedLevel2 = atoi( message.data );
                requestedLevel2 *= ( message.type == V_LIGHT ? 100 : 1 );
                requestedLevel2 = requestedLevel2 > 100 ? 100 : requestedLevel2;
                requestedLevel2 = requestedLevel2 < 0   ? 0   : requestedLevel2;
                fadeToLevel2( requestedLevel2, message.sensor );
                send(light2Msg.set(currentLevel2 > 0 ? 1 : 0));
                send(dimmer2Msg.set(currentLevel2) );}
            // Relay
                if (message.sensor == 7)  {
                    digitalWrite(message.getSensor()-1+relayPin, RELAY_ON);
                    wait(500);
                    digitalWrite(message.getSensor()-1+relayPin, RELAY_OFF);
                if (message.sensor == 8)  {
                    wait(500);
            // Relay
             *  This method provides a graceful fade up/down effect
            void fadeToLevel1( int toLevel1, int ledid1 ) {
              int delta1 = ( toLevel1 - currentLevel1 ) < 0 ? -1 : 1;
              while ( currentLevel1 != toLevel1 ) {
                currentLevel1 += delta1;
                analogWrite(LED_Pin[ledid1-1], (int)(currentLevel1 / 100. * 255) );
                wait( FADE_DELAY );
            void fadeToLevel2( int toLevel2, int ledid2 ) {
              int delta2 = ( toLevel2 - currentLevel2 ) < 0 ? -1 : 1;
              while ( currentLevel2 != toLevel2 ) {
                currentLevel2 += delta2;
                analogWrite(LED_Pin[ledid2-1], (int)(currentLevel2 / 100. * 255) );
                wait( FADE_DELAY );
            BearWithBeardB 1 Reply Last reply
            • A adds666
              Morning all,
              // Button
              // Button
              // Relay
              // Relay
              #define MY_RS485
              // Button
              #define SN "N004"
              #define SV "1.0"
              #define noLEDs 2
              // Button
              // Button
              // Relay
              #define MAX_RELAY 2
              #define RELAY_ON 1
              #define RELAY_OFF 0
              // Relay
              void before()
                // LEDS
              // Button
              // Button
              // Relay
              wait(500);
              // Relay
               wait(2);
              // Button
               // Button
              // Relay
              // Relay
              // Button
                // Button
              // Relay
                      wait(500);
                      wait(500);
              // Relay
                  wait( FADE_DELAY );
                  wait( FADE_DELAY );
              BearWithBeardB Offline
              BearWithBeard
              @adds666 In receive(), note how you use relayPin:
              relayPin is an array (const uint8_t relayPin[] = {3, 7};). If you use it without specifying an index, like you do here, you get a pointer to the first element, not the value of an element.
              Something like digitalWrite(relayPin[message.getSensor()-7], RELAY_ON) should work here. getSensor() returns 7, because you already checked for that two lines above. 7 - 7 = 0, which results in relayPin[0] and toggles the relay on pin 3.
              Also, note that you load the current relay state from EEPROM positions 0 and 1 in setup():
              But you save the state to byte 7 in receive():
              Hope this helps you out!
              • A Offline
                A Offline
                adds666
                @BearWithBeard said in Relay Actuator with momentary (pulse) action:
                Many thanks for coming back @BearWithBeard, its a huge help.
                So my logic for correcting the State problem at the bottom would be to do the same calculation to get them in to 0 and 1.
                saveState(message.getSensor()-7, message.getBool());
                Compiled correctly and then uploaded and it works! Fantastic. The following sketch has 3 dimmers, 4 buttons and 2 relay outputs.
                Thank you very much - I'm learning ;)
                // Button
                // Button
                // Relay
                // Relay
                #define MY_RS485
                // Button
                #define SN "N004"
                #define SV "1.0"
                #define noLEDs 2
                // Button
                // Button
                // Relay
                #define MAX_RELAY 2
                #define RELAY_ON 1
                #define RELAY_OFF 0
                // Relay
                void before()
                  // LEDS
                // Button
                // Button
                // Relay
                wait(500);
                // Relay
                 wait(2);
                // Button
                 // Button
                // Relay
                // Relay
                // Button
                  // Button
                // Relay
                        //digitalWrite(message.getSensor()-1+relayPin, RELAY_ON);
                        digitalWrite(relayPin[message.getSensor()-7], RELAY_ON);
                        wait(500);
                        //digitalWrite(message.getSensor()-1+relayPin, RELAY_OFF);
                        digitalWrite(relayPin[message.getSensor()-7], RELAY_OFF);
                        wait(500);
                // Relay
                    wait( FADE_DELAY );
                    wait( FADE_DELAY );
                12.2k
