  3. Create multiple instance in a for() loop: a C++ question
10 Posts 4 Posters 6.7k Views 1 Watching
  • BulldogLowellB
    BulldogLowellB
    BulldogLowell
    wrote on last edited by BulldogLowell
    my goal is to use a for() loop later in the sketch to check for messages, incrementing through the NUMBER_OF_VALVES. I want a scalable program based on a single #define
    So, I want to be able to create multiple instances of the MyMessage class, based on the #define:
    void (*msg1valve[ NUMBER_OF_VALVES + 1 ] )();
    void (*var1valve[ NUMBER_OF_VALVES + 1 ] )();
    void (*var2valve[ NUMBER_OF_VALVES + 1 ] )();
    MyMessage msg1valve0(0,V_LIGHT);
    MyMessage var1valve0(0,V_VAR1);
    MyMessage var2valve0(0,V_VAR2);
    MyMessage msg1valve1(1,V_LIGHT);
    MyMessage var1valve1(1,V_VAR1);
    MyMessage var2valve1(1,V_VAR2);
    MyMessage msg1valve2(2,V_LIGHT);
    MyMessage var1valve2(2,V_VAR1);
    MyMessage var2valve2(2,V_VAR2);
    //etc... etc...
    how can I do that programmatically versus copying the constructor many times?
    Something like this:
    for (int i = 0; i <=MUMBER_OF_VALVES; i++)
      MyMessage msg1valve[i](i,V_LIGHT);
      MyMessage var1valve[i](i,V_VAR1);
      MyMessage var2valve[i](i,V_VAR2);
    any suggestions?
      //etc... etc...
      any suggestions?
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @BulldogLowell so I tried this... suggestion by Nick Gammon:
        for (int i = 0; i <= NUMBER_OF_VALVES; i++)
          msg1valve[i] = new MyMessage (i,V_LIGHT);
          var1valve[i] = new MyMessage (i,V_VAR1);
          var2valve[i] = new MyMessage (i,V_VAR2);
      still doesn't compile:
      Sprinkler_V2.0_MySensors_V1.4.1.ino: In function 'void setup()':
      Sprinkler_V2.0_MySensors_V1.4.1.ino:103: error: cannot convert 'MyMessage*' to 'void ()()' in assignment
      Sprinkler_V2.0_MySensors_V1.4.1.ino:104: error: cannot convert 'MyMessage
      Sprinkler_V2.0_MySensors_V1.4.1.ino:105: error: cannot convert 'MyMessage
      ' to 'void (*)()' in assignment
        meanpenugin
        Try this...
        #include <SoftSPI.h>
        #define NUMBER_OF_VALVES  4
        MyMessage *msg1valve[ NUMBER_OF_VALVES + 1 ] ;
        MyMessage *var1valve[ NUMBER_OF_VALVES + 1 ] ;
        MyMessage *var2valve[ NUMBER_OF_VALVES + 1 ] ;
          // put your main code here, to run repeatedly:
        Edward
        • tbowmoT
          tbowmoT
          tbowmo
          Why instantiate so many variables up front? IMHO it's a waste of memory.
          You can do like in the temperature demo sketch:
          #define MAXSENS 3
          MyMessage msg1valve(0,V_LIGHT);
          MyMessage var1valve(0,V_VAR1);
          MyMessage var2valve(0,V_VAR2);
          void sendMsg() {
                 for (int i=0; i<MAXSENS; i++) {
                 gw.send(msg1valve.setSensor(i).set(VALUE));
                 gw.send(var1valve.setSensor(i).set(VALUE));
                 gw.send(var2valve.setSensor(i).set(VALUE));
          • M meanpenugin
            Try this...
            Edward
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @meanpenugin
            yes!
            got it from Nick too.
            Thanks!!
            • tbowmoT tbowmo
              #define MAXSENS 3
              void sendMsg() {
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              #define MAXSENS 3
              void sendMsg() {
              it is an irrigation controller that will extend to 16 valves.
              I am creating multiple devices so that an irrigation controller can turn on/off any zone, so I need NUMBER_OF_VALVES Vera devices.
              I had to working pretty well with the old MySensors version, I had to dust it off and update it so I wanted to make the program as extensible as possible and post it to the forum... almost done.
              • tbowmoT
                tbowmoT
                tbowmo
                @BulldogLowell
                Still, instantiate 16+ variables up front, instead of just 1, where you set sensor child number when you send it?
                • BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  So maybe its the jet lag... I cannot see what I am doing wrong here...
                  MyMessage msg(0,1);
                    gw.process();
                    gw.send(msg1valve[0].set(true));
                    while(true)
                  compiler complains:
                  Arduino: 1.0.6 (Mac OS X), Board: "Arduino Uno"
                  sketch_nov14a.ino: In function 'void loop()':
                  sketch_nov14a:28: error: request for member 'set' in 'msg1valve[0]', which is of non-class type 'MyMessage*'
                    This compiles.
                    MyMessage msg1valve[ NUMBER_OF_VALVES + 1 ] ;
                    MyMessage var1valve[ NUMBER_OF_VALVES + 1 ] ;
                    MyMessage var2valve[ NUMBER_OF_VALVES + 1 ] ;
                    MyMessage msg(0,1);
                      gw.process();
                      while(true)
                    //compiler complains:
                    • BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      thanks @hek
                      lemme work with that for a while
