  3. Problem with Serial Gateway equipped with RFM69W and 1st sensor
4 Posts 2 Posters 1.6k Views 2 Watching
  • moumout31M
    moumout31M
    moumout31
    I'm french, so my english might be strange sometimes...
    I use RFM69W to communicate between Arduino Nano Serial Gateway and prototype sensor, based on Arduino Duemilanove.
    As it's written in the title it doesn't work.
    You can see here below the gateway log:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    0;255;0;0;18;2.1.1
    0;255;3;0;11;Thermostat Meuble NAS-Box
    0;255;3;0;12;1.0
    0;0;0;0;6;
    0;1;0;0;3;
    0;2;0;0;6;
    0;3;0;0;6;
    0;255;3;0;9;MCO:BGN:STP
    And herebelow, the sensor log:
    0 MCO:BGN:INIT REPEATER,CP=RRNRA--,VER=2.1.1
    3 MCO:BGN:BFR
    5 TSM:INIT
    6 TSF:WUR:MS=0
    8 TSM:INIT:TSP OK
    9 TSM:FPAR
    139 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2146 !TSM:FPAR:NO REPLY
    2148 TSM:FPAR
    2278 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4285 !TSM:FPAR:NO REPLY
    4287 TSM:FPAR
    4417 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6424 !TSM:FPAR:NO REPLY
    6426 TSM:FPAR
    6556 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8563 !TSM:FPAR:FAIL
    8564 TSM:FAIL:CNT=1
    8566 TSM:FAIL:PDT
    Of course, both have the same MySensors library version (2.1.1, also tested with 2.1.0 and 2.0.0).
    47uF capacitor has been added between 3.3V and GND in sensor and gateway.
    3.3V is provided by Arduino Nano in gateway and Arduino Duemilanove in sensor.
    In order to adapt arduino voltage, an "8 Channel I2C IIC Logic Level Converter Module Bi-Directional for Arduino" bought on eBay is used to convert 5V <=> 3.3V for RFM69W I/O.
    I've browsed forum topics find on Google, but nothing works.
    Of course, I've started by following the page "Debugging Sensors and the Gateway"
    I've just made a strange observation, when I connect the sensor and the gateway on my computer USB, if I connect or disconnect the gateway USB from my computer, the LED "L" on my arduino duemilanove (sensor) blinks several times before recovering its initial state.
    Could you help me please ?
    If I can give you more informations, do not hesitate.
    Thanks in advance for your help !
    • moumout31M moumout31
      0;255;0;0;18;2.1.1
      0;255;3;0;12;1.0
      0;0;0;0;6;
      0;1;0;0;3;
      0;2;0;0;6;
      0;3;0;0;6;
      3 MCO:BGN:BFR
      5 TSM:INIT
      6 TSF:WUR:MS=0
      8 TSM:INIT:TSP OK
      9 TSM:FPAR
      2148 TSM:FPAR
      4287 TSM:FPAR
      6426 TSM:FPAR
      8563 !TSM:FPAR:FAIL
      8564 TSM:FAIL:CNT=1
      8566 TSM:FAIL:PDT
      @moumout31 welcome to the MySensors community, and thanks for the detailed description.
      How far is between the gateway and the sensor? If it is less than 2m, try to increase the distance. If it is >10m, try to decrease the distance.
      From the logs we can see that both nodes are happy with the radio connection, so everything seems to be correctly wired.
      The gateway does not "hear" the message from the node, which is a bit strange.
      • moumout31M
        moumout31M
        moumout31
        Thanks for your answer. For tests the sensor and the gateway are separated by nearly 4m... I tried to move them but it doesn't work.
        • moumout31M
          moumout31M
          moumout31
          I also precise that first I didn't use a level shifter to reduce 5V Arduino to 3,3V for RFM69W pins. Thus when I tried again, I used new RFM69W chips.
