  3. combining button with dht11 issue
2 Posts 1 Posters 1.4k Views 2 Watching
  • el tigroE
    el tigroE
    el tigro
    wrote on last edited by el tigro
    Hi.
    I have put a dht11 sensor on my arduino nano light switch. The hardware switch is incase no UI or ALEXA down. I don't need the humidity component so I removed it.
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 5
    #include <elapsedMillis.h>
    #include <Bounce2.h>
    #include <DHT.h>
    #define DHT_DATA_PIN 7
    #define RELAY_PIN  5
    #define BUTTON_PIN  3
    #define CHILD_ID 1
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 5000;
    static const uint8_t FORCE_UPDATE_N_READS = 1;
    Bounce debouncer = Bounce();
    bool state = false;
    bool initialValueSent = false;
    #define CHILD_ID_TEMP 3
    unsigned long interval=10000; // the time we need to wait
    unsigned long previousMillis=0; // millis() returns an unsigned long.
    float lastTemp;
    uint8_t nNoUpdatesTemp;
    bool metric = true;
    MyMessage msg(CHILD_ID, V_STATUS);
    DHT dht;
      sendSketchInfo("kitchen switch", "1.1");
      present(CHILD_ID, S_BINARY);
      metric = getConfig().isMetric;
      pinMode(BUTTON_PIN, INPUT_PULLUP);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(10);
      pinMode(RELAY_PIN, OUTPUT);
    if (!initialValueSent) {
        send(msg.set(state?RELAY_ON:RELAY_OFF));
        Serial.println("Requesting initial value from controller");
        request(CHILD_ID, V_STATUS);
        wait(5000, C_SET, V_STATUS);
        presentation();
      if (debouncer.update()) {
        if (debouncer.read()==LOW) {
          state = !state;
        send(msg.set(state?RELAY_ON:RELAY_OFF), true);
     if ((unsigned long)(currentMillis - previousMillis) >= interval) {
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
     previousMillis = millis();
      if (message.isAck()) {
          Serial.println("Receiving initial value from controller");
          initialValueSent = true;
        state = (bool)message.getInt();
    my problem is that the temp shows ok, the switch sends commands when tripped but is not on the Home Assistant UI or in entities. I need this switch to show up to set triggers.
    Any help appreciated
    Pi3 Home assistant + mosquitto
    esp8266 wireless gateway
    nano nodes Nrf2401 radios
    • el tigroE
      el tigroE
      el tigro
      sorted works a treat now. My bad, used a sketch I had tinkered with in the past. sketches melded now. Finished sketch below for them that might need. The sketch is for domestic light swith.
      #include <DHT.h>
      #define CHILD_ID 3
      #define CHILD_ID_TEMP 1
      static const uint8_t FORCE_UPDATE_N_READS = 2;
      float lastTemp;
      unsigned long interval = 5000;
      unsigned long previousMillis = 0;
      int oldValue = -1;
      bool metric = true;
      MyMessage msg(CHILD_ID, V_LIGHT);
      DHT dht;
        sendSketchInfo("kitchen Lights", "1.1");
        present(CHILD_ID, S_LIGHT);
        pinMode(BUTTON_PIN, INPUT);
        digitalWrite(BUTTON_PIN, HIGH);
        debouncer.interval(5);
        debouncer.update();
        int value = debouncer.read();
        if (value != oldValue) {
          send(msg.set(value == HIGH ? 1 : 0));
          oldValue = value;
            if (!metric) {
            nNoUpdatesTemp = 0;
      #ifdef MY_DEBUG
          } else {
            nNoUpdatesTemp++;
