  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
    @user2684 Sorry for noob question but how do I get data from the sensors?
    I have registered sensors like this to test them out
    	nodeManager.setSleep(SLEEP, 10, MINUTES);
    	nodeManager.registerSensor(SENSOR_MOTION, 3);
    	nodeManager.registerSensor(SENSOR_BME280);
    	nodeManager.registerSensor(SENSOR_MCP9808);
    U
    U
    user2684
    @gohan since you have set a sleep interval of 10 minutes, what you should see in the logs (and in your gateway) is NodeManager starting up, presenting all the child nodes (one of more for each sensor), running SENSOR_BME280's and SENSOR_MCP9808's onLoop() and a bunch of messages set out with the measures and finally going to sleep for 10 minutes and waking up and sending out a V_TRIPPED message if SENSOR_MOTION triggers.
    Generally speaking you can get the measures in the serial output, in the controller or by sending the node a REQ message to each of the child ids. Do you see something different?
      Ok, I mean from code like if I want to use them to show on local LCD
      U 1 Reply Last reply
        U
        U
        user2684
        @gohan never thought about it but it is a good idea to add some "output" capabilities. Tracking this with https://github.com/mysensors/NodeManager/issues/95 but would require some time since it has a few dependencies. Thanks!
          I'll give you a feedback sooner or later... I lost so many hours trying to figure out what was wrong with my test sensor but at the end it was a fried nrf24 module that was working since some time ago
          • U
            U
            user2684
            I've added a rain gauge out-out-the-box sensor for the latest dev release called 1.5-dev5 (https://github.com/mysensors/NodeManager/tree/126812a9d01311640416222be8225fdcca1e7266). This is intended to be the last enhancement for the upcoming v1.5 version but of course I'll wait for some additional days to collect (and fix) any issue all the new sensors might have.
            The implementation of the rain gauge sensor has to be different than the one from the build section for a good number of reasons and limitations. All the details here: https://github.com/mysensors/NodeManager/issues/90.
            • mar.conteM
              mar.conteM
              mar.conte
              Sorry but the name of the sketch can be different both in the node and in the gateway?
              M.C.
                Sure, that's for your use to know what software is running on each sensor
                mar.conteM 1 Reply Last reply
                  mar.conteM
                  mar.conteM
                  mar.conte
                  @gohan
                  Should the gateway have the right nodemamager sketch?
                  Tanks
                  M.C.
                    Why do you need nodemanager on gateway?
                      mar.conteM
                      mar.conteM
                      mar.conte
                      wrote on last edited by mar.conte
                      #150
                      @gohan
                      User2694 say:"Setup MySensors
                      Since NodeManager has to communicate with the MySensors gateway on your behalf, it has to know how to do it. Place on top of the config.h file all the MySensors typical directives you are used to set on top of your sketch so both your sketch AND NodeManager will be able to share the same configuration. For example:"
                      link text
                      M.C.
                        He is referring on the node side, on the gateway you can just run the default sketch
                          mar.conteM
                          mar.conteM
                          mar.conte
                          @gohan
                          Ok Tanks 😉
                          M.C.
                          • mar.conteM mar.conte
                            @gohan
                            Tanks
                            U
                            U
                            user2684
                            @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
                            Just to confirm what already discussed: a node/sensor with NodeManager running does not require a gateway with NodeManager on it. Generally speaking, there are two situations in which you may want use NodeManager on a gateway as well (available starting from v1.5):
                            • It as to run on a Sonoff device which requires to be configured as a gateway
                            • The gateway has sensors attached to it so you may want to use NodeManager's capabilities to configure your sensors in an easy way
                            There is also a third situation: you are just lazy and have NodeManager already open in the arduino IDE so you just configure the gateway's settings in config.h and upload the sketch :P
                            • U user2684
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @user2684
                              M.C.
                              • U
                                U
                                user2684
                                Last chance guys to report any issue for those who had tested the dev version of v1.5 :-)
                                The final version will be out in a day or two otherwise.
                                Thanks!
                                  I am waiting for the LCD mod :D
                                    U
                                    U
                                    user2684
                                    @gohan LCD unfortunately has to wait for the another release (https://github.com/mysensors/NodeManager/issues/95), I would like to find a way to provide the info on the LCD without the need for the user to configure it for every sensor but this would require investigating on the best generic approach and will take some time :-)
                                      If you could provide a method to retrieve sensor data from main loop(), it is quite easy for everyone to print it to LCD
                                        U
                                        U
                                        user2684
                                        @gohan I wonder if something can be done even right now based on what you're saying. In the main sketch, after invoking nodeManager.loop(), you can actually retrieve the instance of each sensor and do something. The last "value", depending on the type of the sensor, is stored in a variable (e.g. _value_int) BUT it is private. I'll add a getValue() function so you can get out this value. Not ideal but I think it can be a workaround I can easily add before releasing 1.5 (https://github.com/mysensors/NodeManager/issues/104)
                                          The problem is how do I know the name of the instance of the sensors
