  2. Announcements
  3. 💬 Log Parser
💬 Log Parser
27 Posts 17 Posters 11.0k Views 16 Watching
  • W
    W
    willemx
    No support for Gateway Transport messages?
    GWT:TPS:TOPIC=mygateway1-out/19/255/3/0/21,MSG SENT
      The gist has now been updated to the lastest running on mysensors.org
      A
      A
      alphaHotel
      @hek I was able to add support for stream message types to the log parser but can't perform a pull request against the gist. Here is my diff analysis if you're interested in this small update.
      I also made a subsequent one line change to correct the issue that @BoresExpress noted a while back.
        Thanks a bunch @alphaHotel, incorporated now!
        • T
          The Grue
          Logparser is really a helpful tool. But is there a version that I can run offline on my computer?
          • It is annoying to be forced to be online, just to interpret logs
          • If I had it on my computer, I coult pipe the debug output through the parser and see the results life
            @The-Grue
            The page does not require internet to work (once it has been downloaded).
            • J
              J
              Jens Jensen
              I also found the logparser did not handle certain log entries, such as the logfile produced by the mysensors gateway on raspberry pi, e.g. prefixed with timestamps, etc.
              Opened pull request to improve this, comments welcome, especially if you are able to test this locally (only need to copy the Logparser directory and open logparser.html locally in a browser):
              https://github.com/mysensors/MySensors/pull/1468
              • H
                H
                hypnos97
                This post is deleted!
