  2. Announcements
  3. 💬 Log Parser
💬 Log Parser
27 Posts 17 Posters 11.0k Views 16 Watching
    @Wes,
    Here's a gist with the code for the log parser
    https://gist.github.com/henrikekblad/c1d652cce16eaf2ef6340eacaefc97b0
    • wesW
      wesW
      wes
      wrote on last edited by wes
      @hek I believe this should fix the issue:
      https://gist.github.com/liwenyip/de6ff2a646ee417fcf2629eae64e6974/revisions#diff-a83c26f29ff664a062308cb4387554c0
      AFAIK you can't do a pull request on Github Gists.
      Hope that helps.
      Blog: https://www.wes.id.au/
      Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
      Gateway & Controller: Raspberry Pi 3 + Home Assistant
        Thanks, updated.
        • Nca78N
          Hello, it seems only the two rightmost columns are filled, I have the same problem with all the browsers.
          Example:
          https://www.mysensors.org/build/parser?log=TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A40 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A40 TSF%3AMSG%3AACK TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A45 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A45 TSF%3AMSG%3AACK TSF%3AMSG%3AREAD%2C0-0-255%2Cs%3D255%2Cc%3D3%2Ct%3D20%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A TSF%3AMSG%3ABC TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D21%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A0 TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A50 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A50 TSF%3AMSG%3AACK TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A55 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A55 TSF%3AMSG%3AACK
          • B
            B
            BoresExpress
            wrote on last edited by BoresExpress
            Seems like log parser incorrectly prints command types for signature messages (see picture):
            • G
              G
              gbsmith
              Just started MySensors 2.3 project. I have the same problem as Nca78 had 5 months again.
              Only the two right columns are filled. Better than nothing but not perfect as intended.
              And yes I tried running this code directly: https://gist.github.com/henrikekblad/c1d652cce16eaf2ef6340eacaefc97b0
              Is anyone maintaining this code?
              • G
                G
                gbsmith
                Clearly the debug log format has changed to something that this tool does not support.
                My log entries look like:
                228642 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                The old log entries looked like this:
                0;255;3;0;9;TSF:MSG:READ,12-4-0,s=18,c=1,t=16,pt=1,l=1,sg=0:1
                  The gist has now been updated to the lastest running on mysensors.org
                  A 1 Reply Last reply
                  • berkseoB
                    berkseoB
                    berkseo
                    think it's time to add passive node support :) ||| Unknown | ?TSF:MSG:SEND... | |
                    • W
                      W
                      willemx
                      No support for Gateway Transport messages?
                      GWT:TPS:TOPIC=mygateway1-out/19/255/3/0/21,MSG SENT
                        alphaHotel
                        @hek I was able to add support for stream message types to the log parser but can't perform a pull request against the gist. Here is my diff analysis if you're interested in this small update.
                        I also made a subsequent one line change to correct the issue that @BoresExpress noted a while back.
                          Thanks a bunch @alphaHotel, incorporated now!
                          • T
                            The Grue
                            Logparser is really a helpful tool. But is there a version that I can run offline on my computer?
                            • It is annoying to be forced to be online, just to interpret logs
                            • If I had it on my computer, I coult pipe the debug output through the parser and see the results life
                              @The-Grue
                              The page does not require internet to work (once it has been downloaded).
                              • J
                                J
                                Jens Jensen
                                I also found the logparser did not handle certain log entries, such as the logfile produced by the mysensors gateway on raspberry pi, e.g. prefixed with timestamps, etc.
                                Opened pull request to improve this, comments welcome, especially if you are able to test this locally (only need to copy the Logparser directory and open logparser.html locally in a browser):
                                https://github.com/mysensors/MySensors/pull/1468
                                • H
                                  H
                                  hypnos97
